Old Jan 14, 2013, 07:25 PM
4 wheels move a body; 2 a soul
Saratoga, Ca
Joined Feb 2004
For a slope racer I am OK with 60 on the flaps I think. When I did my Precision wing was marked for placement but I still had to adjust before final install to get what I wanted. I will be much more "scientific" on the Needle RDS install but still expect to do a bit of placement tweaking before final install.
Walter
glderguy is offline Find More Posts by glderguy
Old Jan 15, 2013, 01:46 AM
Don't milquetoast me!
satinet's Avatar
Warwickshire, England
Joined Sep 2006
My fs3 has about 60 degrees of slop, never mind travel!
satinet is online now Find More Posts by satinet
Old Jan 15, 2013, 07:39 AM
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
My experience with RDS in F3B has been positive, I have flown 5 planes with self installed RDS systems since 2007 and I have never experienced any issues. After multiple seasons, the slop in the system is also not excessive, compared to my experience with conventional linkages. The planes have been under stupid line tension in strong wind and if there were any weakness or flutter, it should have shown then.
In contrast, I have seen many Ceres and Shooter with those mini flap and aileron control horns that fluttered violently on launch in strong wind conditions. To be fair I hate small control horns on any surface, so I am biased. But from what I have heard, planes with LDS have been solid so far, owing to the beefier linkage.
Nevertheless, if I want to hide a linkage in a competition plane, my preference is RDS. If I want a heavy duty linkage for big slope days, then I make a conventional linkage with large control horns on the surfaces. But to each its own.
Best,
Reto
RetoF3X is offline Find More Posts by RetoF3X
Old Jan 15, 2013, 07:46 AM
RetoF3X's Avatar
Joined Mar 2009
I also swapped a servo at a contest within some minutes. The frames I have installed in my planes allow the servo to slide back when the screws are loosened, which makes a servo change extremely simple with RDS. Current LDS systems seem to be more of a pain to uninstall.
I got the frames from here:
http://www.rcsolutions.ch/index.php?show=64
Best,
Reto
Latest blog entry: Gator F3B and IHLGF
Old Jan 15, 2013, 10:15 AM
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
I have the same experience as Reto. The slop (not too excessive) in my FS4 are from deformed pockets in the surface. I am thinking about shimming them, or heating them back into place and reinforcing them.
djklein21 is offline Find More Posts by djklein21
Old Jan 15, 2013, 01:59 PM
Saratoga, Ca
Joined Feb 2004
The slop in my Precision flaps is also no worse than conventional linkages on my other planes, their slop is very little as is the RDS Precision which is more than acceptable to me.
I am looking at purchasing a set of RDS where the servo will travel a bit to give movement. I was wondering on Daves RDS pockets being deformed......as I am going to soon be installing RDs pockets in my Needle, perhaps completely surrounding the top/bottom/sides of pocket with spooge mixture may prevent this?? Weight not as critical as the 124 will be used for slope/racing only.
Old Jan 15, 2013, 02:57 PM
UK
Joined Aug 2007
Very little slop in my RDS Cyril, the tiny amount in one of the flaps seems to be from the Futaba 3150 servo gear train, the ailerons are solid (3150's all round). It has the least slop out of all my gliders which have conventional linkages and small horns apart from a D60 which also has very little slop running big horns on linkages with Hyperion DS095 servos. Going to try MKS servos on my next install.
Tom
Rooster-X is offline Find More Posts by Rooster-X
Old Jan 15, 2013, 04:29 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Don't use spooge, but rather carbon tow to remove any gap between the pocket ans skins, this will add stiffness.
Old Jan 15, 2013, 04:54 PM
I'm your huckleberry
Doc Holiday48's Avatar
USA, CA, Gardena
Joined Jun 2004
I just fix some pockets on my ailerons for my Explorer. Yes I have a form of RDS built into the main panel that extends out of the end of the center panel and goes into a slot in the Ailerons. This was a Tuan setup. The pockets were sloppy to the rods and I had some thin carbon servo cover material that was just the right thickness. I used gage blocks to check the size of the slot and miked the rod and found almost .020 of an inch difference in size. So I cut a piece of the servo cover material that was .010 thick and smeared Vaseline on a gage block the same size as the rod and used that to hold the servo cover material in place on the gage block. I then added epoxy to the slot and and inserted the gage block with the servo cover material into the slot. Once the epoxy was dry, I slid out the gage block and had a solid pocket for the rod. This worked really well, and I have a solid link again from my servo to the aileron. Of course it helps to have some of these kinds of special tools to make this fix.
Bob
Doc Holiday48 is online now Find More Posts by Doc Holiday48
Old Jan 15, 2013, 04:56 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
I have heard of using cheap feeler gauges from the auto parts store as shim material as well.
Old Jan 15, 2013, 04:58 PM
Saratoga, Ca
Joined Feb 2004
Ok. So should I wrap pockets with tow until a snug fit in aileron then glue in place
or.......????
Thxs
Walter
Old Jan 15, 2013, 05:05 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
That is not a bad solution.
Old Jan 15, 2013, 07:39 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Anything that you can do to prevent the pockets from spreading is a good plan...
I think that the Harley designed RDS pockets come with a mounting "blank" such as what Doc Holliday was talking about.
If you are going through the trouble to do a scratch RDS install, I would definitely go to the trouble of making these install blanks that hold the pocket sides parallel during the glue in process.
R,
Target
target is offline Find More Posts by target
Latest blog entry: Stork 4 Pro X-tail from...
Old Jan 15, 2013, 09:47 PM
Saratoga, Ca
Joined Feb 2004
The Baudis RDS pockets are flexible. I will have to make sure they will not flex after installation. Instead of spooge maybe I could make a dam on either side of pocket, center pocket in aileron with shims, grind up the cf tow to make a cf/epoxy mix then fill in around pocket. I think I have used this cf/epoxy mix before and it was very strong. Still thinking on this.
Old Jan 15, 2013, 11:55 PM
Avaldes's Avatar
United States, CA, Paso Robles
Joined Aug 2006
Great comments from all. My RDS experience is strictly limited to the Radical and it is very well executed by MartinW. It is the stiff style but I get a reasonable amount of flap throw. Those airplanes have not generated any slop over the course of a couple years.
I know that he makes the pockets out of a CF sock that is molded around a mandrel. Then it is spooged in place when the wing is closed. It doesn't hurt that the skins are double carbon on the Radical. I think that combination of a beefy pocket and beefy skins, along with a really well polished rod make the whole thing work and fairly long lived, compared to others.
I too have a couple FS4's on order and Franz recommended the LDS for me. That is why I solicited opinions from others on the TUDM systems.
Avaldes is offline Find More Posts by Avaldes
Discussion Brand New Freestyler 4 - LDS System David Olson Multi Task F3X 33 Oct 01, 2012 08:43 AM
Discussion LDS (Mormon) Timpanogus Temple, American Fork, Utah JONBOYLEMON Aerial Photography 2 Oct 09, 2007 11:15 AM
Discussion Are you LDS and do you fly on Sunday.. fly4fun Life, The Universe, and Politics 21 Jan 02, 2007 07:55 AM
Discussion The new LDS Temple California Condor Aerial Photography 16 Aug 20, 2006 07:45 PM
RDS vs. servocity? fprintf Thermal 8 Feb 20, 2005 06:44 PM
