Old Jan 12, 2013, 08:20 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
LDS vs. RDS
So now that the FS3/FS4 with LDS has been out for a while, how are they holding up? Are people still happy with them or is anyone wishing they had bought RDS instead?
-Aaron
Avaldes is offline Find More Posts by Avaldes
Old Jan 12, 2013, 09:47 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
What is LDS?
jaizon is offline Find More Posts by jaizon
Old Jan 12, 2013, 09:58 PM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
I ordered my latest 2 FS4s with LDS, although I think that there is room for improvement in the current LDS system.
djklein21 is offline Find More Posts by djklein21
Old Jan 12, 2013, 10:17 PM
Brandon is offline
Find More Posts by Brandon
Brandon's Avatar
Riverside, California, United States
Joined Feb 2004
Both FS4's I flew at the worlds are equipped with LDS. As Dave stated I also believe there is room for improvement. I can say that the LDS system has zero slop. You must be sure there is no binding as this can cause problems. With the LDS system on the FS4's there is no way to change out a servo quickly (at the field). The retaining pin, must be removed and the pressure fit can be a bit tricky as well. I still prefer the LDS system to that of the past RDS system.
Brandon
Brandon is offline Find More Posts by Brandon
Old Jan 12, 2013, 11:22 PM
IHAVAWDY is offline
Find More Posts by IHAVAWDY
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Originally Posted by jaizon View Post
What is LDS?
Latter-day Saints?
linear drive systems
drug for dyslexic's LSD
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Jan 13, 2013, 06:43 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
RDS?
I dunno, but LDS can't be worse than some of the RDS systems I have seen.
My own FS3 was crap and my mate's Extasy is worse than that.
The baudis models I have seen seem okay with RDS.
A good RDS is okay, a bad one stinks.
satinet is offline Find More Posts by satinet
Old Jan 13, 2013, 04:51 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Aaron-
I know of one pilot that told me he wished they all had conventional linkages, like the low profile Ceres linkages....
As you are aware, there are pro's and con's to both, but it seems to me that if you have sloppy RDS, that is harder to remedy than a sloppy conventional linkage.
RDS needs to have some give for abundant bind free flap travel, IMO. Telescoping is good.
R,
Target
target is offline Find More Posts by target
Old Jan 13, 2013, 07:41 PM
glderguy is offline
Find More Posts by glderguy
4 wheels move a body; 2 a soul
Saratoga, Ca
Joined Feb 2004
Looking at the Baudis RDS stuff I have the servo doesnt move or telescope, at least it appears it wont.....yet they seem to work. Beats me.
glderguy is offline Find More Posts by glderguy
Old Jan 13, 2013, 08:43 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Yes, the Baudis RDS is perfectly executed for a stiff system....
But in order to get flap travel that is normally used for TD planes, you technically need the wiper to telescope a bit to keep the bend centered over the bisected angle of the surface deflection (don't ask me to explain that one!)....
Its similar to putting centered torque rod linkages into an aileron, and then bottom hinging it; the hinge plane and the torque rod plane are no longer lined up. It will bind unless the torque rod is able to slide in and out of the aileron....
R,
Target
Old Jan 13, 2013, 09:20 PM
tewatson is offline
Find More Posts by tewatson
Team JR Air
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Or, the mfrs can start molding flaps as separate parts and knuckle-hinge them...
Tom
tewatson is offline Find More Posts by tewatson
Old Jan 13, 2013, 11:31 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That's totally true, but then you still would have problems with surface wipers and lots of down flap....
That just proves that nearly everything is a compromise.
R,
Target
Old Jan 14, 2013, 11:34 AM
mrfski is offline
Find More Posts by mrfski
Martin
USA, CA, Piedmont
Joined May 2005
RDS v LDS
I have seen a number of RDS systems and have been surprised at how they can be improperly installed by the best of builders.
I have a RDS FS3 & 4. The FS3 RDS on the flaps is OK but not great. I thought the FS4 RDS would be better but in fact the flap RDS system was installed totally wrong and flap travel is terrible, less than 45 degrees. I was able to get it to just over 50 degrees but I had to move the coupler and servo forward towards the spar almost 3/8".
I friend has just bought the new Crossfire II with RDS and the flap travel is huge, almost 80 degrees as installed.
Bottom line is anything is only as good as how it is put togehter and some of the best builders can make mistakes.
Mart
mrfski is offline Find More Posts by mrfski
Old Jan 14, 2013, 02:02 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Glad I never put an FS 3 or 4 together.....
R,
Target
Old Jan 14, 2013, 03:41 PM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
R,
Target
the freestyler 3 or 4 RDS is about the easiest model to build there is. The wing install consists of screwing the servos in to the RDS couplers. You can do it in a few minutes no problem.
the trouble is it is "what it is". You can't do a lot to make it better, if it's not good.
Old Jan 14, 2013, 06:36 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I just wanted to make sure that Martin know that the one he saw built wrong wasn't built wrong by me (this time!).
R,
Target
Discussion Brand New Freestyler 4 - LDS System David Olson Multi Task F3X 51 Jun 09, 2013 10:56 PM
Discussion LDS (Mormon) Timpanogus Temple, American Fork, Utah JONBOYLEMON Aerial Photography 2 Oct 09, 2007 11:15 AM
Discussion Are you LDS and do you fly on Sunday.. fly4fun Life, The Universe, and Politics 21 Jan 02, 2007 07:55 AM
Discussion The new LDS Temple California Condor Aerial Photography 16 Aug 20, 2006 07:45 PM
RDS vs. servocity? fprintf Thermal 8 Feb 20, 2005 06:44 PM
