Old Jan 12, 2013, 07:06 PM
PRNDL is offline
Find More Posts by PRNDL
Power Glide
PRNDL's Avatar
United States, NJ
Joined Jan 2013
Help!
Mini Sky Surfer Build
Hi all this is my first post and I am a real newbie. I'm in the process of building a Mini Sky Surfer. My problem is with the provided receiver. There is no description of the pin out....what plugs into which set of pins. Does it make a difference or can someone tell me based on the pic I took which set of pins the speed controller and servos plug in. Thanks in advance for any help.
PRNDL is offline Find More Posts by PRNDL
Old Jan 13, 2013, 05:14 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Can you post which Mini Sky Surfer you have, as a search on the web came up with a few different suppliers, and different receivers.
eflightray is offline Find More Posts by eflightray
Old Jan 13, 2013, 08:36 AM
PRNDL is offline
Power Glide
PRNDL's Avatar
United States, NJ
Joined Jan 2013
Yes its the 4 CH BlitzRCWorks Mini Sky Surfer RC Trainer Airplane RTF
http://www.bananahobby.com/mini-sky-...1806-prd1.html
Old Jan 13, 2013, 10:49 AM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
This is the rx that is suppose to come with the plane
mcnowhere is offline Find More Posts by mcnowhere
Old Jan 13, 2013, 11:58 AM
PRNDL is offline
Power Glide
PRNDL's Avatar
United States, NJ
Joined Jan 2013
Thanks, I just found that on BH's website...guess I'll be giving them a call Monday.
Old Jan 13, 2013, 12:07 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I would recommend contacting the supplier, (Banana Hobby ?), and ask for information on that receiver.
If it is Banana Hobby, they do have a 'Vendors' forum here on RCGroups - http://www.rcgroups.com/banana-hobby-560/
You may also find other helpful threads there regarding the Sky Surfer.
Also, does the transmitter have a name and number ?
Old Jan 13, 2013, 12:33 PM
PRNDL is offline
Power Glide
PRNDL's Avatar
United States, NJ
Joined Jan 2013
No name...it has printed on it RX-CH4-V2.0. Beneath that it looks like 2011 obscured number/letter.24
Old Jan 14, 2014, 12:41 AM
notny41 is offline
Find More Posts by notny41
United States, MN, Cottage Grove
Joined Feb 2005
Pretty funny - I purchased an FMS A-1 SkyRaider 750mm in the RTF format. It came with this exact same receiver. I was trying to find out which radios might be compatible with it because the one that came with the plane does not have any expo or dual rates settings on it.
Anyway, the receiver just has a sticker on it that shows the channels and the model number on the receiver says FR-4.
The sticker on mine indicates that the three pins at the top of your picture (nearest to the minus sign in marker) is channel 1 and so on down to channel 4 where your plus sign in marker is.
As far as the pins go, the ones closest to the edge (furthest from the antenna) are negative, the ones in the middle of each channel are positive, and the ones closest to the white line on your circuit board are for signal. So your plugs should all have the black or darkest color wire towards the edge of the rx (furthest from the antenna).
How coincidental that I would be looking for info regarding the exact same rx on almost the same day as you... Correction... apparently this post is a year old. I'm sure you have found your answer by now - or at least have a different rx in your plane...
Here are some pics of mine - mine has the 90 degree bent pins... hope that helps
notny41 is offline Find More Posts by notny41
New Product Mini Sky Surfer gooby Foamies (Kits) 13 Nov 14, 2014 09:56 AM
Build Log Sky surfer, newbie FPV build Redmist FPV Talk 19 Sep 04, 2011 03:41 PM
Discussion How to Build Own 'Chute for Sky Surfer nebg9 Parkflyers 1 Dec 02, 2008 12:34 PM
