I think it will be way too translucent. Right now it looks sort of like wax paper with splotches that are more transparent that that. Over a white substrate it would look great.
Since I'm considering trying printing on the Guillows tissue it won't be a big deal to try the Michael's stuff too just to see. Heck, I've been wrong before and could be now too! Looks like I need to make a couple more test frames. Good thing I have a large box of scrap wood... Thanks for the offer, but if that tissue works well I'll have to wait all year until they stock holiday supplies! I'm really stoked the automotive lacquer works so well! Thanks Fuzz!!! Glenn |
Great news, Glenn! Who'd have thought you could keep the suspense going for so long!
![]() I've used the Michael's coloured tissue before, but only applied over a silkspan covering (Guillow's, as it happened) to add colour trim. If it's strong enough for covering itself, that's good news, 'cause it's cheap (like me). I wonder if it's lighter than the Guillow's silkspan? Perhaps only by a couple of grams per square foot, not really enough to impact a small RC model, but maybe enough of a difference to be significant for small free flight models, especially once paint is factored in. That's the problem with scientific enquiry; it usually leads to more questions than answers... Steve |
Well guys, I've reached a point of indecision.
I would really like to continue with the printed tissue experiments,,, but.. I have plenty of the 'Celebrate" tissue that shrinks well but goes very translucent when coated. I have just enough Guillows tissue to cover the model. One partial sheet is nowhere near enough to print all the graphics on due to the way the graphics have to be arranged to fit the printer. Guess I could wait until my order of Guillows tissue arrives and try printing on that, but it will take at least 3 sheets to print everything. The last option is cover in the Guillows tissue then apply the printed tissue on top of that. This would result in good color contrast of the finished covering. The downsides would be the weight of double covering and difficulty of application to get a smooth surface. Guess the graphics tissue could be cut and overlapped in areas needed to get it to lay down smooth without shrinking. This would require more experimentation and frankly, I'm about experimented out and am ready to get this one done! Glenn |
I went to the auto parts store to get a quart can of the Rustoleum lacquer.
Turns out the stuff in the quart cans is 'spray ready' and is pre-thinned to the viscosity of water. They also had Duplicolor lacquer in quart cans but it too is pre-thinned. The lacquer in the spray can seems thicker, so guess I'll have to decant it into bottles. Glenn |
Received my order of tissue from Guillows yesterday.
I have two more experiments to try. Experiment #1. Dope the printed gift tissue onto the pre-shrunk and doped Guillows tissue. The idea is the Guillows is not too translucent and will act as a white base. This will add some weight but I think it won't be much more than a coat of paint. I need to take some pics of the doped gift and guillows tissues to show the difference in translucency. Experiment #2. Print directly onto the Guillows tissue. Attach it with the heat activated white glue method described earlier. Shrink the tissue with alcohol and dope it with the rustoleum auto lacquer. Have a lot of non hobby stuff (chores) to do today, maybe I can get to these experiments later. Glenn |
I hate to give up, did you see Pete Rake's printed tissue on his Sperry Monoplane? It looks really good!
After these last two attempts, I'm done screwing around and if the results are not good enough, it's cover and paint time! I have learned a thing or two out of all this so it was a worthwhile effort. Most important is we have discovered that Rustoleum Automotive Acrylic Lacquer is a locally available and inexpensive dope substitute. Thanks to Fuzz for telling us that Aerogloss is not dope, but auto lacquer. That put me on the trail.... Glenn |
Today I started with experiment #2.
Printed onto the Guillows tissue. Removed it from the carrier sheet and let the ink dry for over an hour. While the tissue was drying, I made yet another horizontal stab test frame.(#5) Coated the test frame with white glue and while that dried, cut out the tissue. As soon as the tissue was cut from the main sheet, the graphics curled into a tube. Humm, that's odd, none of the other tissues I printed onto did that. Ironed the tissue onto the frame. The tissue was misted with alcohol and allowed to... Shrink? Well not really. Wet it a few more times and it finally did shrink enough without bleeding the ink. Took it out to the shop and just like the other tissues, it went limp..... Sprayed it with alcohol again and let it dry out in the shop. It shrunk up ok but still not really tight. Put a coat of lacquer on and the tissue relaxed, and stayed that way after the lacquer dried. Somehow the printed tissue just won't work for me. Could be the ink, humidity or a number of things. Bottom line is, I'm done. I tried, hard, but after weeks of this I have just had enough. The sound you hear is me throwing in the towel. I give up. I'm covering this sumbitch with Guillows tissue, water shrinking it then coating it with lacquer and painting it. Time to go back to what I know works and get this one done! Now I will go back to getting the airframe ready for covering. Still have to hinge the surfaces and make up a tail skid. Glenn |
| Thread Tools | |
| Sold 2 Guillows Kits. B-25 / Sopwith Camel New Price. | Cphipps0826 | Aircraft - Electric - Micro & Indoor Airplanes | 4 | Sep 06, 2012 10:34 PM |
| Sold Guillows Sopwith Camel | FlyWW1 | Aircraft - Electric - Airplanes (FS/W) | 4 | Jun 11, 2012 06:59 AM |
| Discussion Free plan: Sopwith Camel - 21 in span, 1934 plans by Peerless | planeman | Free Flight | 0 | Jun 24, 2010 08:55 PM |
| Discussion Atom - my 8" span Sopwith Camel | Slider2732 | Indoor and Micro Models | 1 | Dec 07, 2009 05:44 PM |
| 1ST Flight Guillows Sopwith Camel | Warren Jones | Scale Electric Planes | 15 | Dec 29, 2002 08:12 PM |
