Old Jan 12, 2013, 05:09 PM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Build Log
Guillows 18" span Sopwith Camel
This is my build of one of the long discontinued Guillows WW series of 18" span WWI models. The laser cut short kit is from Aero-werks, http://dpcmodels.homestead.com/SRKS.htm
I highly recommend Dave's kits. You get the laser cut parts and a CD that contains all kinds of useful info including the plans and decals files.
I actually started this one a while ago but stalled due to repairs/upgrades to models flown (and crashed ) regularly, and a build of a micro Ugly Stick.
The plan was to utilize a removable equipment tray that could be transferred from model to model. This proved to be problematic and the idea was abandoned. The tray still slides out for equipment access and it might be incorporated into another model later. For now it is dedicated to the Camel due to the cowl shape.
Glenn
glewis is offline Find More Posts by glewis
Old Jan 12, 2013, 05:34 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
The control linkages will be connected by small magnets. This allows them to disconnect when the tray is removed. I 'borrowed' this idea from Paul Bradley's Comet Stinson build. http://www.rcgroups.com/forums/showt...=comet+stinson
It is now being used in the whim series of Parkscale Models kits too. http://www.parkscalemodels.com/shop/....aspx?catid=23
My model will be powered by the parkzone um P-51 8.5mm motor/gearbox and powered by a single 160mAh cell.
Old Jan 12, 2013, 06:01 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
My plan for covering/decorating is printed tissue from a RoF skin. Been thoroughly aggravated and humbled trying to figure out how to re size the graphics in Paint Shop Pro. That is the most confusing, counterintuitive piece of,,,, piece of,,, software I have ever encountered. I burned through half a Saturday and have nothing to show for it. I would be better off starting over and just using MS Paint.
Might just toss in the towel on the graphics and go with painted tissue.
Glenn
Old Jan 12, 2013, 06:20 PM
Steve85 is offline
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Glenn,
Wow, lots of cool stuff here! A discontinued Guillows, sliding equipment tray, magnetic control linkages and printed tissue....
I'm subscribed!
Steve
Steve85 is offline Find More Posts by Steve85
Old Jan 12, 2013, 06:49 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Hi Steve.
Well, maybe printed tissue....
I have to work night shift next week so I might be able to work on the graphics there, after the day shift goes home.
Here's a pic of the linkages on the servo tray. The magnet couplings are a short length of 1/8" dowel with a 0.020 through hole, then a 1/16" hole drilled 1/16 deep. The dowel was lined up on the wire and the magnet put in place then everything fixed with thin CA.
The AR6400 is glued to the balsa with canopy glue after a couple of pockets were cut in the balsa for the taller components to fit down into.
The pushrod guides are balsa. A rectangular hole was cut in the tray and the guides slid in with 1/16" protruding out the other side. 1/16 square strips are glued on to support the guides and everything glued up with yellow glue. The holes in the guides were drilled then hardened with thin CA.
Linkage retainers are 0.015 wire and are not in the proper position yet. They go on top of the pushrod wire and are pulled into position with tweezers. This locks everything in securely.
Glenn
Old Jan 12, 2013, 09:20 PM
Shnokey is offline
Find More Posts by Shnokey
Closed Account
Joined May 2004
Originally Posted by glewis View Post
Hi Steve.
PM Sent.... We will set you up.. - cool build!! -
Shnokey is offline Find More Posts by Shnokey
Old Jan 12, 2013, 09:35 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Thanks Man. PM replied.
Nose insert planked to provide a grip area when pulling the tray out.
The wing saddle area needed some work. The curvature didn't match the ribs. I wanted to reduce the bottom wing incidence anyway so slivers of wood were cut and glued in to provide a proper mounting for the wing. Also not shown in the pic is the pushrod exit plates at the rear. They were cut from 1/32 sheet and fit between the stringers.
Glenn
Old Jan 12, 2013, 09:48 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Here are pics of the pushrod connections and exit plates.
The wing saddle has been shimmed to lower the incidence to about 2 degrees.
Next up, the wings.
Glenn
Old Jan 12, 2013, 09:55 PM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Glenn,
What are you using to hold your pushrod keepers in place? It looks like 1/2A fuel tubing. Does it matter if you use the 90* bend as the keeper? From what I can see, you're using a separate piece of wire for the 90* bend. I ask because I'm having some difficulty with my AR6400 linkages and it looks like you really have it figured out.
Kody
PiperCub49 is offline Find More Posts by PiperCub49
Old Jan 12, 2013, 10:05 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
It's heat shrink tubing. A 90 degree bend won't stay in. A 'Z' bend works best, but once the pushrods are on they are hard to remove without a lot of trouble. The keeper is a separate piece of 0.015 wire.
The keeper wire isn't glued into the heat shrink to give it the flexibility needed to 'lock and unlock' them.
Glenn
Old Jan 13, 2013, 07:35 AM
danrc is offline
Find More Posts by danrc
danrc's Avatar
Rockford Illinois
Looking great Glenn. I have the N28 sitting by that I was trying to figure when to jump on. May have to try the removeable tray idea as well! Love watching you work!
danrc is offline Find More Posts by danrc
Old Jan 13, 2013, 09:07 AM
mtflyr is online now
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Looks great Glenn.
Pete
mtflyr is online now Find More Posts by mtflyr
Old Jan 13, 2013, 02:54 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Hi Pete and Dan, thanks for the comments.
Here's a pic of the top wing. Standard stuff here. I added !/8" dihedral to each panel and increased the bottom wing dihedral the same amount.
Also added some 1/16 sq strips to form a pocket for the struts and give something for the tissue to adhere to.
Still need to add the tip support strips and the top wing will be ready for sanding.
Glenn
Old Jan 13, 2013, 05:03 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Top wing tip supports done. This assembly is now ready for sanding.
On to the bottom wing.
Old Jan 13, 2013, 05:43 PM
meltor is offline
Find More Posts by meltor
AKA Jagdpanther9
meltor's Avatar
Joined Jun 2012
neat build Glenn.
meltor is offline Find More Posts by meltor
Sold 2 Guillows Kits. B-25 / Sopwith Camel New Price. Cphipps0826 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 06, 2012 11:34 PM
Sold Guillows Sopwith Camel FlyWW1 Aircraft - Electric - Airplanes (FS/W) 4 Jun 11, 2012 07:59 AM
Discussion Free plan: Sopwith Camel - 21 in span, 1934 plans by Peerless planeman Free Flight 0 Jun 24, 2010 09:55 PM
Discussion Atom - my 8" span Sopwith Camel Slider2732 Scratchbuilt Indoor and Micro Models 1 Dec 07, 2009 06:44 PM
1ST Flight Guillows Sopwith Camel Warren Jones Scale Kit/Scratch Built 15 Dec 29, 2002 09:12 PM
