Old Jan 12, 2013, 03:21 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Can someone explain motor ratings?
I understand kv, amps etc, but what does it mean when a motor is listed as 2826, 3025, 2836.........what do those numbers denote??
Thanks anyone!
ripmax is offline Find More Posts by ripmax
Old Jan 12, 2013, 03:24 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
It's stator's diameter and length.
2826 = Diameter 28mm, length = 26mm
http://www.rcgroups.com/forums/showthread.php?t=319860
Mortimer is offline Find More Posts by Mortimer
Old Jan 12, 2013, 09:30 PM
Raj Quest is offline
Find More Posts by Raj Quest
Joined Aug 2004
Also, Some older plans show "speed-300-motor" OR "Speed-400-motor"
how do I find the best brushless equivalent - Is there a conversion chart or something?
Raj Quest is offline Find More Posts by Raj Quest
Old Jan 13, 2013, 03:45 AM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Thanks, its been bugging me for a while now!
Old Jan 13, 2013, 07:06 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
It is not always stator size although that is the most common. Some manufactures such as Leopard use the overall motor dimensions which can get confusing and hard to compare to other brands.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 15, 2013, 08:28 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Only the last two digits are sure, the length of stator or magnets.
The first two digits you can't bet without an explicit specification from the manufacturer, it can be external bell diameter as well as internal stator diameter.
2212 for example I am pretty sure means 22mm stator diameter, because I know these motors, but otherwise... what is more confusing is the fact that the same manufacturer can label the same motor as 2212 or 2830... the later being the external bell dimensions.
There are several classes, quite well standardized:
- 22mm stator = 28mm external diameter
- 28mm stator = 35mm external diameter
- 35mm stator = 42mm external diameter
etc...
As you can see, one class external diameter size is the internal stator size for the next class.
renatoa is offline Find More Posts by renatoa
Discussion Can someone explain this? FTA_FTW Batteries and Chargers 23 Mar 04, 2012 01:56 AM
Discussion Can someone explain the C rating more clearly? nerys Power Systems 25 Dec 09, 2010 03:00 PM
Discussion Can someone please explain how to setup a rate gyro with a JR radio? delamar Micro Helis 4 May 19, 2006 06:49 PM
Can someone explain KV ratings for brushless motors. Brutus Power Systems 7 Oct 14, 2004 05:46 AM
Can someone explain "dual rates" Windysurfer Radios 4 Jan 06, 2003 09:19 PM
