Old Feb 11, 2013, 02:15 PM
shinck is online now
Find More Posts by shinck
Utah, USA
Joined Jun 2007
Thanks Don.
I was thinking while doing it about the heavier ply and the Lite wheel!
Maybe they will even out...
Scott
shinck is online now Find More Posts by shinck
Old Feb 11, 2013, 02:50 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Scott,
I can laser cut some 1/32" G-10 for you.
Brian
cpdude is offline Find More Posts by cpdude
Old Feb 11, 2013, 02:55 PM
Utah, USA
Joined Jun 2007
Hey Brian,
maybe on the next one
Scott
Old Feb 13, 2013, 11:52 AM
Utah, USA
Joined Jun 2007
Nose Skid
My interpretation of the skid follows, with help from the Charlesworth plans; see the PDF for details
1/32" ply sub-skid base
Skid itself is 3/8" wide at front, 7/8" at back, straight taper
Laminate skid from 3 layers of 1/16 ply with stainless steel or hard aluminum glued to bottom after covering gap (hard landing strips). If flying from grass, you can laminate or use 3/16" spruce steamed and bent to shape and forget the metal.
Solid hardwood front skid block and back support.
Rubber heater hose at single suspension point; screw into fuselage and floating against skid. Not exactly scale suspension holder, but no one will see it as the gap will be covered, as per full size.
The skid is allowed to slide at the back during compression.
For whatever reason, the PDF file ended up as the last picture in this post, instead of the third, and I can't get it to move. Oh well.
Last edited by shinck; Feb 16, 2013 at 09:28 AM. Reason: heater hose attachment changed per SZD16
Old Feb 15, 2013, 10:58 AM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Looks good! I would recommend attaching the rubber hose with something more then just epoxy......they tend to take a beating overtime. I screw mine to the fuse and let them just flout against the skid.....
SZD16 is offline Find More Posts by SZD16
Old Feb 15, 2013, 02:16 PM
Utah, USA
Joined Jun 2007
I had thought about that also. Thanks for the practical suggestion, which I will use.
I have edited Post #80 to include that information.
Scott
Old Feb 17, 2013, 11:51 AM
Utah, USA
Joined Jun 2007
Tail Skid
The tail skid is being made now in order to get most of the fuselage completed. It won't be fitted and installed until the last piece of bottom rear sheeting is in place, which won't be done until the pull-pull wire exit is determined, which can't be done until the fin and rudder are made and the rudder horn can be positioned on the fuselage to determine where the wires need to exit for a straight-line connection.
In short, I just wanted to do it now.
Parts need to be cut and laminated together, then sanded to outline; ply inset fitted and glued; and sides angled. Fitting will require sanding to conform to the rounded fuselage bottom, tapering the back to match the rudder base, and tapering the front to nicely fair into the fuselage.
Old Feb 17, 2013, 12:56 PM
Utah, USA
Joined Jun 2007
Glue line question
I'm looking forward to finishing the fuselage, and am having a problem with the glue lines being harder than the balsa. I can't get it smooth because of this; you can feel (and will see) the "faceted" glue lines. I have thought of hardening the skin with a coat of finish--epoxy--so it all sands about the same?
I was going to finish the fuselage with polycrylic and Sig Koverall, as used by both dgliderguy and NoStep. So I would like a fix that won't mess me up using this finish.
Scott
Old Feb 17, 2013, 07:45 PM
dgliderguy is offline
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
Scott,
If you don't mind a lot of dust and handwork, you could butter up the entire fuselage with sandable spackle and let it dry overnight, then cross-sand (alternate criss-cross pattern) down to the first sign of wood. A rubber sanding block, like you find at the auto body supply stores, is good for this kind of work. It requires more patience than I have, which is why my Schweizer 1-26 has some facets here and there. The guys I fly with won't beat me up over it (I hope!).
dgliderguy is offline Find More Posts by dgliderguy
Old Feb 17, 2013, 09:09 PM
Utah, USA
Joined Jun 2007
Lite spackle or the regular/heavy stuff?
Old Feb 17, 2013, 09:58 PM
Where's the lift?
dgliderguy's Avatar
Joined Mar 2001
I'd recommend the regular, myself, to keep from oversanding, and baby it down with finer grades of sandpaper as you go. I used to do auto body work in my college years, and the experts taught me how to slow down as you get closer to net shape. I had a hard time learning that one! I was always applying more filler, to hide my scratches and overgrinds.
Build Log Olympia 2b 1/4 Scale Build Log ShaneW Scale Sailplanes 7 Oct 14, 2010 02:03 AM
Discussion Flightpower Eon vs Eon-X Seahawk82 Batteries and Chargers 89 Jan 14, 2010 06:34 PM
Discussion Kranich 2B Plans scervetto Scale Sailplanes 1 Aug 04, 2008 12:16 PM
Wanted Wanted:Cliff Charlesworth Olympia 2B (DFS Meise) WarBirdCrazee Aircraft - Sailplanes (FS/W) 1 Feb 07, 2008 03:06 PM
Eon Olympia? Tominator Scale Sailplanes 2 Dec 20, 2004 02:34 PM
