Old Jan 12, 2013, 09:28 AM
Marcos Sallua is offline
Find More Posts by Marcos Sallua
Joined Sep 2012
Question
Air Field Programming Card and Quick Connect
The green light is blinking but don't have red light's
The red LEDs come on only after pressing the button to select a setting first???
Any help please
Marcos Sallua is offline Find More Posts by Marcos Sallua
Old Jan 16, 2013, 02:34 AM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Any help please
Need more information...
What ESC are you using?
What firmware are you using?
How are you powering the RX?
Clintstone is offline Find More Posts by Clintstone
Old Jan 16, 2013, 07:57 AM
Joined Sep 2012
I make two test , one in a CC 120HV and other CC 160HV both with v3.27 firmware
No power in the RX
Thanks in advance
Old Jan 17, 2013, 05:13 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
No power in the RX
Thanks in advance
What are you using for RX POWER as the Castle HV does not have a BEC?
Also you can remove the quick link to eliminate it as a problem while testing....
Old Jan 17, 2013, 08:12 AM
Joined Sep 2012
I have a 2S Lipo, all the electronics is HV, Futaba S-Bus HV RX, Outrage Torq 9080 y 9188, BeastX.
I make some test without quick link and report later
Thanks!
Old Jan 17, 2013, 11:00 AM
Joined Sep 2012
Thank you Clint, solved!
I was connecting incorrectly, was using it as a castle link, I made ​​a connection on Y and now is working OK.
thank you!
Found Castle Creations Field Link Portable Program Card r0beert0 Aircraft - Electric - Power Systems (FS/W) 1 Oct 10, 2012 02:20 PM
Sold Castlecreations ice 120hv v2 10 flights field programming card included! whippo Aircraft - Electric - Power Systems (FS/W) 1 Oct 01, 2012 07:37 PM
Sold Castlecreations ice 120hv v2 10 flights field programming card included! whippo Aircraft - Electric - Airplanes (FS/W) 0 Sep 30, 2012 08:36 PM
Sold Castlecreations ice 120hv v2 10 flights field programming card included! whippo Aircraft - Electric - Jets (FS/W) 0 Sep 30, 2012 08:35 PM
Sold Castlecreations ice 120hv v2 10 flights field programming card included! whippo Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2012 08:34 PM
