Old Jan 13, 2013, 10:11 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Originally Posted by efflux RC View Post
Hey Joe,
Someone once inquired about putting the JS 1400 into the Mach 70. It can be done, but at nearly 4000KV it's to high for this EDF for high power setups.
Gary, is that a custom standoff adapter mounting the big outrunner to the 28mm Mach fan?
I like the feelings in my head generated by a 36mm motor in that Mach.
Oh, and 4000kv would make a GREAT 5S setup! Why not??
murdnunoc is offline Find More Posts by murdnunoc
Old Jan 13, 2013, 10:28 PM
efflux RC is online now
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by PikeStaff View Post
This is good to know. Happy to hear that there is indeed a way to do it.
Since this is lees thread about his custom motors, I'm moving my off topic stuff to here.
http://www.rcgroups.com/forums/showt...6#post23807220
I commented there.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jan 13, 2013, 10:33 PM
efflux RC's Avatar
Joined Aug 2009
Yes, It's the standoff that came with (Little Screamers) JS1400. I "turned down" the motor mounting flange with dremel to fit the motor housing of the mach fan. The motor "fairing" was a one quickie fiberglass one that I made.
The shaft on that motor was bent during a test with another fan years earlier. I never got a replacement shaft, and support from LS was no longer available.
The problem I see spinning outrunnners at 70+K.
Site Sponsor
Old Jan 13, 2013, 11:00 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by sneu View Post
Just because "thats the way it is done" does not make it good engineering practice
Steve
Well, there sure are plenty of fans out there with stand off motors. It seems that doing it wrong is working well in spite of itself.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Jan 13, 2013, 11:03 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
While we are discussing engineering--you don't have nearly thick enough iron behind the magnets--you can get away with less iron when you have high pole counts and small gaps between the poles but when the pole count goes down the steel needs to get thicker to close the magnetic path. I am guessing that your outer ring will have a lot of flux leakage. I would guess that you need at least double the steel and maybe more. Yes it will run---but you are not making the best use of the magnet strength.
Steve
I guess you are guessing wrong, because I don't have big gaps between the magnets. Sounds like you need to go back and read the whole thread.
Old Jan 14, 2013, 03:05 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Does a paperclip stick to the outside of the motor?
Odysis is offline Find More Posts by Odysis
Old Jan 14, 2013, 07:12 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I don't know, I don't have any paperclips.
Old Jan 14, 2013, 07:40 AM
HURRICANE FANS is offline
Find More Posts by HURRICANE FANS
HURRICANE FANS's Avatar
United States, NC, Grifton
Joined Nov 2012
That's funny right there.
HURRICANE FANS is offline Find More Posts by HURRICANE FANS
Old Jan 14, 2013, 10:10 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
If your pictures are any indication-- you do have large gaps between the magnet poles. Try the paper clip test and see if they stick to the outside of the motor bell when assembled. If you can't find one then any small steel scrap will do.
The fewer the poles the more back iron that is needed. to close the magnetic paths. Don't have to take my word for it--take the design and check it using FEMM (http://www.femm.info/wiki/HomePage)
Steve
sneu is offline Find More Posts by sneu
Old Jan 14, 2013, 10:37 AM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
I myself do not know a whole lot about motor construction but I would like to know about paper clip sticking to can, I have a few outrunners that they do stick to, what does that mean?
fh64_lucky is offline Find More Posts by fh64_lucky
Old Jan 14, 2013, 11:11 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
It means they aren't perfect.
Old Jan 14, 2013, 11:35 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
It means that they have not done a good job in designing the magnetic components of the motor. It also means that the motor constants are not as good as they could be and that the efficiency is less than it could be.
Steve Neu
Old Jan 14, 2013, 11:36 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Well in order to be more efficient, could you get another bell or open ended piece of tube or pipe and just wrap it and glue it to get the additional metal?
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jan 14, 2013, 11:39 AM
fh64_lucky's Avatar
Joined May 2005
Thank you for answers, learn something new alot on these threads....
Old Jan 14, 2013, 11:55 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
The goal is to get the right amount of steel to contain the flux. Another steel tube could be put over the bell--but it needs to be a tight fit with no gaps.
Steve Neu
Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor Dave Barrow Aircraft - Electric - Jets (FS/W) 0 Aug 10, 2012 07:58 PM
Discussion Game Change mortato Life, The Universe, and Politics 0 Apr 17, 2012 02:31 AM
Mini-Review 64mm SF Shroud, 64mm RClander rotor, and HET 2W-20 motor zach_dad Electric Ducted Fan Jet Talk 2 Jun 12, 2010 10:04 AM
