Old Jan 12, 2013, 09:18 AM
wepoo is offline
Find More Posts by wepoo
gettin' there
wepoo's Avatar
Australia, WA, Perth
Joined Jan 2011
Noob Help - Installing an outrunner on HT-FPV
Hi all,
I've been trawling youtube and forums to get an understanding of how to install an outrunner on a HT-FPV (actually a clone: spacewalk 550).
I'm noob enough to be surprised that it seems the big part of the motor spins (very different from my RC cars!).
So I have attached two photos. The first is how I think it should go together. The second includes some parts (at the bottom) that I am not sure where they belong.
Any help here would be greatly appreciated. How do I install an outrunner on the HT-FPV frame?
wepoo is offline Find More Posts by wepoo
Old Jan 12, 2013, 12:07 PM
2dogrc is offline
Find More Posts by 2dogrc
2dogrc's Avatar
United States, NC, Vass
Joined Apr 2005
Hello,
Yes that is the correct setup. As far as the parts on the bottom:
1)The black circles are prop adapters incase the prop hole is too big for your shaft.
2)The other piece is another prop adapter.
3)The black X is a motor mount. This is usually used for airplanes mounting to a firewall. You won't need it on this frame.
THe three wires coming from the motor go to your ESC. If your motor spins backwards, swap 2 of the 3 wires. DO NOT swap the red and black from the ESC to the Battery. Swap the wires from ESC to Motor.
hope that helps.
2dogrc
2dogrc is offline Find More Posts by 2dogrc
Site Sponsor
Latest blog entry: How to braid motor wires!
Old Jan 12, 2013, 05:32 PM
wepoo is offline
gettin' there
wepoo's Avatar
Joined Jan 2011
Excellent. Thank you very much!
Question Help an FPV noob with his doubts? vineet_p FPV Talk 7 Nov 16, 2012 02:15 PM
Found Got an extra HT-FPV HoverThings Frame??? KiTCyclic Aircraft - Electric - Multirotor (FS/W) 20 Jul 14, 2012 07:23 PM
Discussion How Should i Install An Outrunner on an EasyStar? kgdnelly Beginner Training Area (Aircraft-Electric) 3 Sep 17, 2007 10:59 PM
How do I install an outrunner on a Shock Flyer? tinsink Foamies (Kits) 0 Sep 27, 2005 04:11 PM
