Old Jan 12, 2013, 09:36 AM
blooper is offline
Find More Posts by blooper
Joined Dec 2012
topgun rapier 450 fault?
recently purchased a topgun rapier 450 helicopter to get me back into the swing of things andafter only 3 x 4 minute flights well hovers i find that the main drive gear and motor pinnion gear has worn away to the extent that i have to by replacement parts ,just wondering if this is a common fault or an i just unlucky.i thought i would of atleast got more flight time with this,anyone else had the same problem
blooper is offline Find More Posts by blooper
Old Jan 12, 2013, 09:48 AM
WOS is offline
WOS
Find More Posts by WOS
WOS
United States, IN, Michigan City
Joined Nov 2003
Sounds like your pinion to main gear lash was to far away. Use some rolling papers or something close to that and put it between the pinion and main gear for good lash gap
WOS is offline Find More Posts by WOS
Old Jan 12, 2013, 10:31 PM
PcChip is offline
Find More Posts by PcChip
PcChip's Avatar
Joined Sep 2012
Your gear mesh is either so tight it's binding the motor and pushing the motor shaft, or it's so loose it's chipping off pieces of the plastic gear teeth
PcChip is offline Find More Posts by PcChip
Old Jan 13, 2013, 05:30 PM
blooper is offline
Joined Dec 2012
thx guys the heli is less than 3 weeks old i did check the gear mesh and thought it was ok so will have to waiy for new parts now
Old Apr 12, 2013, 08:12 AM
blooper is offline
Joined Dec 2012
right got the parts used a cigarette paperto get the mesh right and it just strips the main drive gear after 3 flights this has been repaired 4 times now getting rather sickof it so gonna replace the parts yet again and sell on going back to nitro power as never had this much trouble before
Old Apr 12, 2013, 06:16 PM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
Quite annoying, I've been there and done that.
Solution:
This helicopter is a clone of the Dynam E-Razor 450 which was notorious for its garbage pinion which would dissolve and then start chewing up the main gear. Can bet the brass pinion is causing your problem.
This along with proper gear mesh will solve the problem. Also, when you set the mesh, set it to where you can feel a tid tid bit of play of the main gear before it connects with the pinion..You will never strip a main gear again unless you bite the dust. Good to go.
http://helidirect.com/rhino-gear-ult...450-p-6694.hdx
ASTREA1 is offline Find More Posts by ASTREA1
Old Apr 13, 2013, 06:23 AM
blooper is offline
Joined Dec 2012
yeh i'm guessing its the brass pinion gear causing the trouble thx again will give it another go
Wanted I missed the boat! (Jetex/Rapier) Alien_Tech Aircraft - Fuel - Engines and Accessories (FS/W) 12 Jan 19, 2013 11:47 AM
Help! Blade 450 Mechanical Fault? B450guy Electric Heli Talk 5 Jan 02, 2013 05:07 PM
Discussion Rapier Missile system for Olympics... your Funjet might become a target! Iboxx83 FPV Talk 3 May 03, 2012 09:33 PM
Discussion Blade 450 or Top Gun Rapier 450 zippyshutt Electric Heli Talk 4 Oct 10, 2011 07:29 AM
Question T-Rex 450 SE V2 Metal Tail Drive Gear Assembly design fault? Arven Mini Helis 16 Jun 07, 2009 11:38 AM
