Emax 2210/30 excavation
I bought this little Emax 2210/30 a while back for testing and an then an autopsy.The motors literature advertises it as machine wound I was curios as to the pros and cons of "machine winding". http://www.headsuprc.com/servlet/the...ushless/Detail I first bench tested this motor and it squeaked buy meeting the advertised specs.
In a nut shell, 14T delta 3 strands 2mm/.008" (bare) .22/.009 1w/coating 64 and 3/8" long. Although one phase had a broken conductor near the center of the wind. No glue was used to secure the windings so the unwinding was a breeze. Although the lack of glue on the wires has visible consequences. Previous reviews of this motor in it's 1400Kv form clearly indicated marketing license was used when creating the advertised specs. At $25.00 bucks a copy it wasn't a great value. . The machine winding did a perfect turn count on each arm BUT there is allot of empty space on the stator.
Latest blog entry: Edge Walker
USA, ME, Ellsworth
Joined May 2008
Nice autopsy!
Thanks for that. That motor was the 2nd motor I ever rewound but I did not do as well or was not as lucky as you in getting the original windings off. I would up with a bare or any coatings stator and a stack of loose laminations. You can see the details here: http://www.rcgroups.com/forums/showthread.php?t=1248742 Good luck with it! Jack |
I think this a version/generation two Emax . Jack was the motor you did machine wound?
My plan is to wind it LRK with a Kv around 920. The last 2 ( LRK and a dLRK 2215) motors I wound using STC came out quite acceptable power wise but were higher or lower. Kv than I calculated, or tried to predict I may have messed up. My 6T dLRK star 2215 came out around 680Kv, takes a 12X3.8 to load to 200 watts good thrust but lacks snappy throttle response. I was aiming for 1000Kv. The LRK was allot closer to the 1K mark coming in at 1040Kv. Little to fast for my target 11"SF prop but it swings a 10X4.7 with a vengeance. I plan on doing a side by side with the 2215's against stock wind. Just need the rainy windy day and a few hours. I plan on posting my math before winding so if I get it wrong someone may point it out. When it's all together I'll test it and post the results. |
The Emax's of that era apparently were hand wound, Jack's tear down of one was a gooped up mess. This Emax was machine wound, not much wire BUT the turn count was a perfect 14 turns on each arm. This one is sold as a 1300Kv and when tested was within 20 rpm. It did perform to the specs available at Heads Up RC. Although at that power level it was heating up and would be a considered a burst verses a constant power level. The unwinding revealed a phase that one of the three conductors was broken., with that wire in tacked the motor would have done better.
E-maxed out
I'm thinking about mounting the motor with the wires hanging out so I can check the Kv terminated delta and star. Depending on which termination looks best for this motor. (I have a feeling it's going to be a Zero motor) I have a 3D or a Zero it will go into.
If I read the chart correctly this should be a 1382Kv terminated star
Once I had the bearings I hooked up the Emeter repeated the Io test ( run a few seconds on a half charged packed). Swapped out the bearings in about ten minutes and repeated the test w/ the new bearings. I have 3 2205's I'm running with these bearings (lube free) Emeter could detect no difference between stock bearings and ceramic. But in this case the OEM bearing's were bottom of the barrel and I installed the creme of the crop. I think that is why there is a detectable difference.
| Thread Tools | |
| For Sale EMax BL2210-30 NIP | darkside212 | Aircraft - Electric - Power Systems (FS/W) | 0 | Mar 15, 2007 06:54 PM |
| For Sale NIP 30 amp Emax Brushless ESC 2-4S fully programmable $30 each | The Don | Aircraft - Electric - Power Systems (FS/W) | 13 | Feb 20, 2007 08:05 PM |
| Sold NIP Himodel/Emax Professional Series 30 amp Brushless ESC 2-4S fully programmable | The Don | Aircraft - Electric - Power Systems (FS/W) | 4 | Nov 21, 2006 11:43 AM |
| Sold NIP Himodel/Emax Professional Series 30 amp Brushless ESC 2-4S fully programmable | The Don | Aircraft - Electric - Power Systems (FS/W) | 7 | Nov 07, 2006 12:20 PM |
| Alert E-Max 2210/25 and 2210/30 | Dr Kiwi | Power Systems | 0 | Oct 21, 2006 11:28 PM |
