Old Jan 12, 2013, 12:23 AM
jonnystevens is offline
Find More Posts by jonnystevens
Joined Jun 2012
1700mm FMS P-47 connection for external BEC.
I'm not sure about the connection for the external BEC. It's wired into ESC, and has a red/black receiver type connector. Do I plug this connector to my receiver? And if so do I have to disconnect the red wire from the ESC throttle connector? My receiver is a 6 channel spektrum,and has a bind/data port available. Would this be where I plug the BEC into? Thanks for any help.
jonnystevens is offline Find More Posts by jonnystevens
Old Jan 12, 2013, 01:23 AM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Yes you have to take the red wire out , you need to use a Y connector and plug the esc into one and the BEC into the other and plug it into the throttle on your receiver. You also can Y it into other servos as well
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Jan 12, 2013, 11:28 AM
Joined Jun 2012
Thanks for the help.
Old Sep 10, 2013, 01:06 PM
benjack71 is offline
Find More Posts by benjack71
United States, IL, Cypress
Joined Sep 2013
Wait whoaaa if he is using a spectrum well anyway if you have a open bind/data port you just plug into that
benjack71 is offline Find More Posts by benjack71
Old Sep 10, 2013, 01:38 PM
Joined Sep 2004
I dont think you can do that. Your going to send it into bind mode
Old Sep 10, 2013, 05:06 PM
Joined Sep 2013
No, he wont, trust me that's how I set up mine. You have two options, you can either do the y connector, strip wire, etc. etc. or you can plug into your bind/data port. Remember all you are doing is using a separate power source for you control surfaces in case of an ESC failure you can still have "dead stick" control of ailerons, rudder, elevator and gear. Setting it up like I described is also called OPTO. http://www.rcgroups.com/forums/showthread.php?t=1410470. There is a good explanation of what I am talking about here.To send it into bind mode you would have to jumper a loop onto the port and also hit your bind key at the same time. You will not bind doing that because you are not using a "looped" jumper, aka a bind key and hopefully your not hitting your bind key, which if you did, would not bind anything because you are not using your bind key.
Old Sep 10, 2013, 05:20 PM
Mustang Racer 9 is offline
Find More Posts by Mustang Racer 9
Mustang Racer 9's Avatar
United States, AZ, Cave Creek
Joined Jul 2012
I use spectrum and mine is plugged in the bind/data port and it works just fine. And I didn't pull out the red wire for the ESC.
Mustang Racer 9 is offline Find More Posts by Mustang Racer 9
Old Sep 10, 2013, 05:30 PM
Joined Sep 2013
Exactly. You do not want to remove any wires for that. You did it exactly right. This is a true OPTO connection. In order for it to bind you must use a bind key which is a loop. You can power through any channel on your receiver. I have powered through aileron,aux,elevator in order to bind before. What you are doing is using your bind/data as the power port to your receiver, and creating a circuit that is independent of your ESC in case of power failure to your ESC/Motor.
New Product FMS P-47 1700mm wingspan!!! HLC SHOP Electric Warbirds 2608 Jan 25, 2016 10:51 PM
Discussion FMS 1700mm P-47 what is the CG on it. jonnystevens Electric Warbirds 5 Jan 11, 2013 12:42 PM
Discussion FMS P-47 1700mm otw! skiprCH Foamies (Kits) 2 Aug 26, 2012 11:34 PM
Sold TX LPU: MASSIVE 1700mm FMS P-47 Thunderbolt, PNP $190 Roswalt Aircraft - Electric - Airplanes (FS/W) 5 Jun 25, 2012 07:33 AM
