Old Feb 20, 2013, 02:53 AM
Deckie is offline
Find More Posts by Deckie
Deckie's Avatar
Australia, WA, Garden Island
Joined Nov 2010
Very strong but light-weight construction there!
Deckie is offline Find More Posts by Deckie
Old Feb 20, 2013, 01:44 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Xbow would be my choice as they have a certain apeal for that kind of work..
keith S is offline Find More Posts by keith S
Old Feb 22, 2013, 08:35 AM
mariner02 is offline
Find More Posts by mariner02
Brought to you by letter Arr!
mariner02's Avatar
United States, NC
Joined Sep 2009
Here is a link to the concept that seems to have the best chance of moving forward:
http://web.mit.edu/2n/events/DsgnSym...esentation.pdf
Looks like a commercial-based design again, which really comes as no surprise. This one is a variant of the UT-722L tug, which appears to have been designed by Rolls Royce Marine. Special features would include ice strengthening, diving support capabilities, and substantial towing/salvage capability (200 tons of bollard pull!).
These are obviously preliminary sketches, but I don't think the MIT guys have a complete grasp on towing ops. Take for instance the generator exhaust located on the fantail. Wouldn't take long for a towline to take that out. The location of the winches also looks odd to me, and I'm not sure that both a 35-foot workboat and a RHIB would be needed. It's a start anyway, and a whole lot more practical than the "bag of ass" trimaran concept if you ask me.
mariner02 is offline Find More Posts by mariner02
Old Feb 28, 2013, 02:33 PM
mariner02's Avatar
United States, NC
Joined Sep 2009
Back at it again after a week off in Florida....
I have been constructing the forward bulwark and shelter deck enclosure, which is a little tricky as you can see. I started with a styrene "skeleton", the top of which will support the actual shelter deck later. The skeleton then served as a guide to install the wood strips, and around they went. The tapered curve of the bow required lots of specially-cut planks, but it turned out well. Once the bow was enclosed, the styrene supports were removed with the exception of the shelter deck perimeter.
After the bulwark ribs were installed, the bulwarks were planked and faired into the bow enclosure. The hole for the large bow anchor will be cut later.
Now comes resin and glass; and lots of tedious sanding!
Old Feb 28, 2013, 04:02 PM
keith S is offline
bellingham, wa
Joined May 2006
very nice looking hull work
Old Mar 12, 2013, 09:09 PM
mariner02's Avatar
United States, NC
Joined Sep 2009
Well, the hull has been fiberglassed and thoroughly sanded. I haven't posted an update in awhile because frankly, this is an uneventful and tedious stage. She looks a little splotchy from the different layers of filler, but trust me, she is baby-smooth.
The very conspicuous hull rubbing strakes are up next, and once that is finished it will be time for a coat of primer to help spot any imperfections I've missed. It's just about time for shaft installation too.
Old Mar 13, 2013, 12:53 PM
tghsmith is online now
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
splotches are sign that things are getting sanded down well!!! she should prime-up great. looking throught the splotches and seeing a fine hull..
tghsmith is online now Find More Posts by tghsmith
Old Mar 13, 2013, 09:56 PM
desron48 is offline
Find More Posts by desron48
ADM. 48TH FLEET
oxnard ca.
Joined Jul 2007
looking great.....
joe
desron48 is offline Find More Posts by desron48
Old Mar 14, 2013, 12:15 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Absolutely!
Kmot is online now Find More Posts by Kmot
Old Mar 16, 2013, 10:00 AM
mariner02's Avatar
United States, NC
Joined Sep 2009
Thanks everyone.
I'm waiting for 3/16" half-round stock for the rubbing strakes to arrive, so I thought I might as well get the shafts and motors in.
I added two alignment blocks to ensure good shaft location, but the shafts will be glassed-in to really fix them in place. I have located the shafts in their scale locations, but because they are so low in the hull (and parallel to the keel) I was forced to mount the motors upside-down. The motors don't seem to mind. I made a base out of 1/4" ply, reinforced with basswood strips to prevent any sagging over time.
The nice thing about these MFA motors is that they come with high-quality detachable mounts, which were lined up and secured to the base while on the bench. After the motors were bolted-on, the whole assembly was flipped over and installed on pre-aligned bracing that had been glued to the inside of the hull. Once the alignment was verified, the base was fixed in place and two support posts added along the centerline to anchor the assembly to the keel.
Old Mar 16, 2013, 10:20 AM
mariner02's Avatar
United States, NC
Joined Sep 2009
And on to the bow thruster....
This tug has a complex fairing that must be tapered from the hull shell to the thruster outlets. Since the whole setup is on a compound curve and on the angled portion of the hull, the outline for the thruster opening cannot be transferred onto the model direct from the 2-dimensional profile drawing. Even though I have a handful of sectional drawings from Marinette Marine to aid in the process, there is still a lot of "eye-work" to make sure the opening is located and sized correctly.
Once I was satisfied with the shape of the opening sketched onto the hull, I transferred it to a piece of paper and reversed it for the opposite side. Then it was just a matter of cutting it out with the trusty Dremel and a tile-cutting bit.
I set the thruster in the hull just to make sure everything looked right, but the actual fairings will have to go in first.
Old Mar 16, 2013, 10:26 AM
jerry orfano is offline
Find More Posts by jerry orfano
jerry orfano's Avatar
USA, NY, Brooklyn
Joined Sep 2009
mariner02 very nice work on the atf very clean and organized just totally outstanding
Jerry
jerry orfano is offline Find More Posts by jerry orfano
Old Mar 17, 2013, 02:26 AM
capntroy is online now
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
She's progressing nicely, I'll be keeping an eye on this thread!
I was lucky enough to get a bit of stick time on one of the ScaleShips 1/48 T-ATF's a while back, they are very impressive on the water but keep an eye on the weight of materials and fittings above the main deck, it won't be hard at all to wind up with a boat that is top-heavy and tender.
capntroy is online now Find More Posts by capntroy
Old Mar 17, 2013, 09:06 AM
mariner02's Avatar
United States, NC
Joined Sep 2009
Originally Posted by capntroy View Post
....keep an eye on the weight of materials and fittings above the main deck, it won't be hard at all to wind up with a boat that is top-heavy and tender.
Yes it is a very tall superstructure with a lot of surface area. The hull has a fairly deep draft when ballasted correctly though, and I'll be trying to keep the weight as low as possible in the hull. That said, I'm planning to do a good amount of detailing above decks, both inside and out, so stability will have to be watched closely (I see a few "tub-tests" in my future).
The real ships don't ride that great either; they have a tendency to lurch rather than roll. We were in a good storm off Los Angeles once, and couldn't do more than 8 knots since we had a tow. The thing was jerking side to side so violently that I was thrown against the corridor bulkheads more than once. I woke up the next morning with bruised shoulders. And everyone was sick- even the "I don't get seasick" types. You know the guy; he'll be sitting at the lunch table with everyone saying "yeah it's a good storm, but I'm used to this sort of thing". Then you see him an hour later leaning over the bulwark where he thinks no one can see him, feeding the fishes.
Old Mar 17, 2013, 12:35 PM
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Copy that...
The ScaleShips 1/48 T-ATF came with a 7 piece fiberglass superstructure set and a whole gob of heavy polymer fittings such as the entire visor around the pilothouse roof. I think you should have no trouble making the major pieces out of a lighter material to leave yourself a little room for the weight of the other detailing that you want to do.
For Sale Built 1/48 Scale ATF Fleet Tug Sweeper Nut Boats (FS/W) 3 Jan 27, 2014 09:30 AM
Discussion Where to find 1/48 Modern USN Fittings nismoron Scale Boats 6 Aug 14, 2009 11:06 AM
Sold 1/48 ATF Fleet Tug Hull Sweeper Nut Boats (FS/W) 9 Jun 07, 2009 10:04 AM
For Sale Built ATF Fleet Tug 1/48 Scale Sweeper Nut Boats (FS/W) 3 May 09, 2009 12:42 PM
For Sale 1/48 ATF Fleet Tug Hull Sweeper Nut Boats (FS/W) 2 Jan 13, 2009 09:44 PM
