This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Jan 11, 2013, 03:59 PM
unclegeorge is online now
Find More Posts by unclegeorge
Trader Rating: 211
unclegeorge's Avatar
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 211
For Sale
Throttle and Choke arms for Gas Engine Walbro Carbs.
If you have ever struggled with trying to make a new arm for your throttle or choke on your gas engine carborator out of nose gear steering arms---Here finally is a solution!
Hundreds of these have been ordered and everyone tells me there is nothing on the market like them, better order yours soon!
Note that there is a difference in the height of each are so they can pass each other without any interferrence.
They are CNC machine of 6061-T6 Aluminum so they can be taped for a 4-40 ball or you can use a nylon clevis if you like for hook up.
These arms are build to slide on to the brass shafts on your carborator and are held in place with 2 set screws. I recommend that you file a flat on the shaft after determning what angle is best for hook up and then use thread lock on the set screws.
Specs:
1. CNC machined 6061-T6 aluminum in a brilliant red anodized finish.
2. Perfect for all carbs using standard 3/16" (0.1875") throttle and choke shafts.
3. May be drilled out for larger carbs using 7/32" (0.2187") throttle or choke shafts.
4. Offset heights provide enough linkage clearance for your servo mounting preferences.
5. The multiple 1/16" arm holes located at 1/2", 3/4" and 1" provide mounting flexibility and changes in mechanical advantage.
Sold in pairs only. One tall and one short. Includes 4mm set screws
I sell them for $14.50 a pair plus $2.00 S&H by first class. Priority mail is now $6.00. Buy two for $13.00 Each plus shipping!!!
Please give me your mailing address and please refer to the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase. My account in Pay Pal is under uncgeorge@comcast.net
unclegeorge is online now Find More Posts by unclegeorge
Old Jan 13, 2013, 06:56 PM
steveblackwell is online now
Find More Posts by steveblackwell
Trader Rating: 6
steveblackwell's Avatar
United States, TX, Robinson
Joined Nov 2010
Trader Rating: 6
control arms
george , sent paypal for two sets ,check pm's
steveblackwell is online now Find More Posts by steveblackwell
For Sale Throttle and Choke arms for Gas Engine Walbro Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 08, 2015 08:33 PM
For Sale Buy 2 deal!-Throttle and Choke arms for Gas Engine Walbro Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Aug 04, 2012 12:48 PM
For Sale Throttle and Choke arms for Gas Engine with Walbro Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 20, 2012 11:11 AM
For Sale Throttle and Choke arms for Gas Engine Walbro Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 07, 2012 06:34 PM
Sold Throttle and Choke arms for Gas Engine Walbro Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 23, 2012 09:05 AM
