Old Jan 11, 2013, 01:52 PM
RayR is offline
Find More Posts by RayR
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Aeromarine Avenger36 - Team Believer
Presenting the new Aeromarine “Team Believer”
Well, it’s not really a “New” boat. Just an existing boat with a new hatch.
I was speaking with Brian Watts at Rocket City Racing several months ago and the subject migrated to the “SprintCat” hull from Aeromarine. I mentioned that the Sprint Cat .40/80 was a great boat, but left a lot to be desired in terms of conversion to an electric boat. The biggest issue with the SprinCat is that all of the electrics need to be mounted on the tunnel floor. There is not enough room to fit conventional packs into the sponsons.
The “Team Believer” hull on the other hand, with the same bottom as the SprintCat, has plenty of room to put batteries in the sponsons, but the hatch is virtually impossible to tape and leaves much to be desired in terms of “Aesthetics”.
I mentioned to Brian that the hatch opening for the Team Believer was only an inch shorter and an inch narrower than the hatch opening for the 42” Avenger Pro hull which is one fantastic looking boat.
Since Brian is one of the larger dealers for Aeromarine, I asked if he could speak with Remy at Aeromarine about modifying the Avenger Pro hatch to fit the Team Believer hull.
Here are some preliminary pics – I should have boat in hand shortly for more detailed photos.
RayR is offline Find More Posts by RayR
Old Jan 12, 2013, 03:00 PM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Boat just arrived. Dimensions are a little different than the SprintCat. This boat is actually the advertised 36" length with a 14.5" beam. Here's a few more pics.
Old Jan 12, 2013, 08:43 PM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
What is that discoloration at the bottom of the sponsons Ray?
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing F-14 Tomcat Build
Old Jan 13, 2013, 04:40 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Just some masking tape to protect the sponson bottoms.
Old Jan 13, 2013, 04:42 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
The skinny little Mystic hulls sure are pretty, but there is something to be said for a little "ROOM"!
Bill, I need to find out where you are getting all that foam you have been using!
Old Jan 13, 2013, 05:29 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'm in full agreement with you on the "room" factor Ray. It makes building and placing equipment so much easier.
Unfortunately, the foam is a thing of the past. Chris was getting it from the dumpster of a business that was along his delivery route, and the business moved to parts unknown.
Old Jan 15, 2013, 05:26 PM
ron1950 is offline
Find More Posts by ron1950
ron1950's Avatar
United States, MS, Brandon
Joined Jun 2011
your not done with that build yet ray? heck u have had it for two days now lol...what motor is going in there anyway?
ron1950 is offline Find More Posts by ron1950
Old Jan 19, 2013, 10:11 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Finally got around to mounting the strut and rudder this morning Ron. Hey, seven days to drill 8 holes ain't bad. Well, I did have to build the standoff for the lip, and file down the shoebox lip to make everything flat.
The motor is a 1527/1Y.
Old Jan 19, 2013, 12:22 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
On the good side, you have another whole week to finish up before our next scheduled run.
Old Jan 19, 2013, 09:00 PM
ron1950 is offline
ron1950's Avatar
Joined Jun 2011
looks good as usuall ray...got home last night about 10pm ...long drive ...missied all the snow as it melted wed.....now to fix my little hydro and p mono
Old Jan 20, 2013, 07:02 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Got the hole drilled and stuffing tube dam built. Gotta wait for the hardware store to open, don't have any JB Weld.
Old Jan 20, 2013, 10:48 AM
ron1950 is offline
ron1950's Avatar
Joined Jun 2011
quick question ray....do u actually drill a hole then use a dremel cutting blade? or another way? ive always had trouble with the fiberglass cracking with a drill bit etc.....
Old Jan 20, 2013, 01:02 PM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Actually I use a butchs block as a drill guide and run the bit in reverse too avoid chipping
Old Jan 23, 2013, 04:18 AM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
It might be done by Sunday. Still alot to do.
Old Jan 26, 2013, 05:29 PM
RayR is offline
@SiestaKey.calm
RayR's Avatar
United States, FL
Joined Aug 2006
Still have to attach the rudder and charge packs, but she's ready to maiden. Likely no graphics.
Sold aeromarine team beleiver and a ofna ld3 blastfrmdapast Boats (FS/W) 2 Jul 14, 2010 03:28 PM
For Sale aeromarine team beleiver 36" nitro and nitro ld3 blastfrmdapast Non R/C Items (FS/W) 0 Jul 14, 2010 01:12 AM
For Sale RTR Aeromarine Team Believer Cat Gas Boat Tugboatjoe Boats (FS/W) 5 Aug 29, 2008 09:36 PM
For Sale Team Believer 36" Cat hebner Boats (FS/W) 1 Apr 13, 2007 07:24 AM
I can't believe the home team! windsurfer Life, The Universe, and Politics 6 Jun 15, 2001 11:11 PM
