Old Jan 13, 2013, 06:41 PM
paulskyone is offline
Find More Posts by paulskyone
STEM+C
paulskyone's Avatar
United States, AZ, Gilbert
Joined Sep 2012
Description:
Also today I used packaging tape on the tops of the elevarons. I dont intend on buying any hinges. Just packaging tape and the styrofoam that is already there. Now all I have to do is make one cut between the elevaron and the fusalge and the elevaron will move freely. Plan on connecting the servos next weekend.
Also glued the black foam stips between the wing tips and the elevarons, some touch up green paint on the bottom of the wing tips.
STAY TUNED!!
1/13/2013
paulskyone is offline Find More Posts by paulskyone
Old Jan 26, 2013, 05:12 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Bench test of servos. Had to play with the elevon mixing on the controller.
Old Jan 26, 2013, 05:27 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
The reciever with the servos attached and the ESC.
I have mine set up so that channel 1 is attached to elevon 1
channel 2 is elevon 2
channel 3 goes to esc which is throttle
notice the orange wire from the servo corresponds to the (s) signal input on the reciever.
the red wire from the servo is the positive
the brown wire from the servo is the negative
When you attach the servo wire extensinions to the reciever, just make sure they connect the wires to the controller as mentioned above.
Old Jan 26, 2013, 05:32 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Description:
The push rods were to big to fit through the servo arms.
Had to drill out the predrilled holes on the servo arms. Used a 1/16" bit. Worked perfectly. In this picture they are not drilled out yet. I drilled out the top two holes on the arm.
Old Jan 26, 2013, 05:39 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Description:
Here it is. glued up waiting for it to dry before I play around with the elevons some more.
Had to cut away a little styrofoam to instll the servos.
used gorilla glue to glue servos in place as well as the elevon horns.
also after installing the servos and the horns, I cut the airlerons free.
Had to cut a little between the elevons and the wing in order for the elevon to move more freely. Not using "Hinges" on the elevons as of yet. Just using packaging tape and segments of styrofoam to hinge the elevons to the wings.
Old Jan 26, 2013, 05:45 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Turnigy 9x elevons setup for f22 rcpowers (7 min 51 sec)
Excellent you tube video on setting up the Turnigy 9x controller for elevon mixing!
Old Jan 26, 2013, 05:50 PM
flyingfitz737 is offline
Find More Posts by flyingfitz737
United States, IL, Edwardsville
Joined Dec 2011
Looks great Paul. Call if you have any questions. I have been at this for 32 years!
flyingfitz737 is offline Find More Posts by flyingfitz737
Old Jan 26, 2013, 08:31 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Thanks Scott!
Old Jan 26, 2013, 08:34 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Name: wing cut out.jpg
Description:
This is the cut you need to make to free the elevon. I did this after the servos were insatlled with the pushrods connected to the elevon horns. Also took away a little styrofoam on the elevon between the elevon and the wingtip just to give it a little more room.
Old Jan 26, 2013, 08:40 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Name: wing slits.jpg
Description:
Made seveal slits along the elevon in order to gain more freedom of movement. Leaving all of the styrofoam attached between the elevon and the wing caused to much resistence for the servos. I would say there is a total of about 3.5 to 4 inches on elevon still attached to the wing with styrofoam and packing tape. This seems to be just about right. Remember I am not using any after market hinges on this airplane as of yet. just the styrofoam and packing tape.
Old Jan 26, 2013, 08:44 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Name: end points that work for me.jpg
Description:
These seem to be the right end points for my build. The only problem is I need to figure out how to save the settings. For some reason everytime I exit the screen, and then come back to that screen, the settings change to the default setting. Did this over a beer and no manual. In the morning Ill grab the manual and see what I am doing wrong. GOOD night!
Old Feb 10, 2013, 04:20 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Prop attached to motor using the accessory package. I think I have it set up right for a pusher configuration. Any comments out there?
Bench test it tomorrow.
Description:
Old Feb 10, 2013, 04:31 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by paulskyone View Post
Attachment 5483304
you have to hit the menu button after each change,then go to next one change it and hit menu so on . then when all done hit menu then exit.
fastfwd is offline Find More Posts by fastfwd
Old Feb 10, 2013, 04:33 PM
fastfwd is offline
Joined Mar 2012
Attachment 5526130
here is a picture that has helped me with the prop orientation
Old Feb 10, 2013, 09:18 PM
STEM+C
paulskyone's Avatar
Joined Sep 2012
Fastfwd,
Thanks for the picture.
I have it mounted so that when the prop spins it pulls the air from the front of the airplane and moves it aft. Now just make sure the ESC is hooked up the right way to spin the prop.
Bench test tomorrow, then mount on the airplane.
Has anyone put fixed gear on one of these delta wings? I am considering it.
Try to takeoff with gear instead of hand launch. I value my fingers.
If gear dont work, then I am going to build a catapult.
Discussion My Skywalker Build Thread Manc_Heli FPV Talk 32 Jul 26, 2011 02:28 AM
Pocketcam X Build Thread....It begins! ZRX Doug Aerial Photography 98 Nov 16, 2007 11:57 PM
