Joined Sep 2011
![]() The top wing has been filled and sanded. I have not glued the center wing brace in yet, but I'll have that done this week. Got started on the bottom wing; got the ribs, bottom and top spar, and le glued in. I got the dihedral rib glued in at the 3 degree angle. Stopping at the wing dowel balsa block........ Pics tomorrow. Long day..........ready to call it a night. |
Joined Sep 2011
Well, I pulled an all-nighter at work Thursday; went in at 6 in the morning and didn't leave until 6 the next morning. Unexpected things happen and sometimes you just have to go with them. Needless to say, I didn't get anything done Thursday.
Friday I got the wing dowel balsa block in, the top sheeting, the sheeting on the te, the spar spacers, and the cap strips done. Flipped it over and pinned it back down. |
I use tips like these. I stick them on a new bottle of CA and never take them off. When I'm done with gluing I just stick a piece of masking tape or blue painters tape over the tip. They very seldom are plugged, and if they do plug I just nip off the very tip.
Saves allot of glue. I remember my first build. I spent more on CA than the plane. LOL. OOPS, EDIT,....Forgot to add the link. Gettin old. LOL http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNXD4&P=7 |
Joined Sep 2011
Lol, I've cut so much off the end to keep it from clogging that I dump a ton of glue on whatever I need to glue.....gonna run out of a $11 bottle quick if I don't do something. |
Joined Sep 2011
MAJOR SCORE!
Went back home yesterday. Made a trip to my local HT and guess what I found? The engine mount I wanted; check out the price!! ![]() ![]() This engine mount is regularly $50. Stoked!! Got some glue tips, some gap-filling CA, a remote glow ignitor, and an engine mounting tool that lets you find the center of the engine mount holes. Now I can start the fuse! |
Joined Sep 2011
Joined Sep 2011
Well, not so major score.....the engine mount price sticker said .50-.90, but the package reads up to .70 2 Stroke.....the engine mount won't hold the engine because it's not long enough to hold the engine and carb of the four stroke. The carb won't slide in between the mounting locations........back to square one.
I will do some research and see if the bolt patterns are the same for the larger mount; if so, I can at least use it for the firewall building and engine placement. Got in from the long trip from home, unloaded the car, and crashed..... |
Joined Sep 2011
Got stuff done!
I made the servo trays in the lower wings. Instead of cutting the rails to the length of the openings between the te and le sheeting, I decided to wrap them under the te sheeting for some extra support. Here you can see how I shaped the rails; I just cut the upper nib off the length that it goes under the te and slid it under the te sheeting. ![]() I also got the hatch covers down to size. I didn't add the servo mounts yet because I want to cover the hatch covers first. After that, I got the wings all spackled up. Here's what I used, it's very lightweight and pretty easy to handle. It does get everywhere though........ ![]() That was done Tuesday night. Wednesday night I was able to get the wing halves sanded and the dihedral brace fit. I am now waiting on some slow cure epoxy, which I hope to get tonight.
Joined Sep 2011
I took the paper tube advice (thanks tacx) and used part of the plan to do it.....relax, it was just a copy!
![]() I cut two pieces of paper and wrapped them around the 7/16" brass tube I bought to drill out the top wing mounting holes. I used just enough to get a wrap and a half around the tube; I found that any more and it was harder to get through the holes in the ribs, because the paper wanted to unravel. Once I got them where I wanted them, I cut them down to where I thought was plenty running through the holes and then put a bit of CA to hold them firm.
| Thread Tools | |
| Question A few questions for items to build sig hog bipe | Ultra Boom | Fuel Plane Talk | 27 | Aug 05, 2012 09:13 AM |
| For Sale Sig Hog Bipe with Saito .80 4 Stroke LPU | Commander4 | Aircraft - General - Miscellaneous (FS/W) | 0 | Apr 17, 2012 09:38 AM |
| Sold Sig hog bipe | happybird | Aircraft - Fuel - Airplanes (FS/W) | 2 | Apr 15, 2012 11:34 PM |
| For Sale Hog Bipe kit NIB | cherokeenut | Aircraft - Fuel - Airplanes (FS/W) | 1 | Mar 20, 2012 10:45 PM |
| Sold NIB Hog bipe kit! Never opened | chrisrain | Aircraft - Fuel - Airplanes (FS/W) | 7 | Mar 15, 2012 03:12 PM |
