Old Jan 12, 2013, 06:59 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
***speechless***
Keenan smith is offline Find More Posts by Keenan smith
Old Jan 12, 2013, 07:10 PM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
Originally Posted by Kevin Greene View Post
Joe---Do you just visualize these planes and build them or what???......VERY good job and thanks for posting your designs...What thickness Depron do you use???
Kevin
thanks Kevin,
yeah pretty much visualize what I want to do and approximate the size and wing area with an eye to fan shroud size. I have found once a good airframe is made to fly I can usually follow the same size parameters to build others.
the foam I use is just Dollar Tree "Ready Board" foam board with the paper peeled off, very lite stuff, it is 5mm thick after de-papering. I love it, havent used depron since finding out about this stuff, its a Dollar for a 20" X 30"sheet, I usually buy 10-12 sheets at a time that much depron would probably be $50-$75 depending on where you get it with shipping.
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Jan 12, 2013, 07:15 PM
sloperjoe's Avatar
Joined Mar 2012
forgot to add, I have the fan/servos/Rx installed and I think this thing has enough poop to fly on 2s so thats what I'll do the first flight on...at least I "think" it "should" do it
colder than out here right now, so cant say when the maiden will be, if it warms up some hopefully maybe tomorrow
Joe
Old Jan 12, 2013, 07:37 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Joe
Weird weather---73* here today---Record high temps but calling for snow in 1 1/2 days...
THANKS for the heads up on the Dollar Tree foam!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jan 12, 2013, 10:16 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Joe, this is just and amazing job on a jet that is hard to duplicate. The Mig and the Saber were very nice, but you`ve knocked the ball out of the park with this one!! I better see some paint on this beauty.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jan 13, 2013, 12:06 AM
sloperjoe's Avatar
Joined Mar 2012
thanks Lee!
might spend the next day painting it, all depends on the weather...if it warms up I would like to maiden it before paint, either way I should have "something" new to post tomorrow
Joe
Old Jan 13, 2013, 06:42 PM
sloperjoe's Avatar
Joined Mar 2012
well, it was c c c c ooooldd outside today...but I did attempt a maiden, definitely enough power even on just 2s, unfortunately during glue-up of the fuse I messed up the tail incidence....with the balance just right it wants to nose dive, even moving the batts way back it would mush then turn nose down, luckily the damage isnt to big of a deal, and hopefully I will get it repaired and get the tail re-oriented to the correct angel which should be zero degrees....then I'll give her another go.
it did fly straight ahead so at least that part is stable
so stay tuned I'll get er, even if I gotta build another
good thing I didnt paint this one yet
Joe
Old Jan 14, 2013, 12:48 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
When I now go back and look at the tail surface in the photo's, it does seem to have way too much incidence.
Sucker got airborne? Good enough first flight for me Joe! LOL )
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 14, 2013, 02:03 AM
sloperjoe's Avatar
Joined Mar 2012
confirmed tail incidence problem, I analyzed my plans and build sequence and concluded I should have done the bottom planking in three sections instead of one big slab, apparently the pull of the stressed foam bottom pulled the tail boom down and out of alignment, so... I will build another one and correct my build method.
yep, it did get airborne, seemed to have plenty of poop to fly, and it did go nice and straight, just no pitch control....touch the elevator and down she would go, moved the CG well back from where I know it should've been and still, even tail heavy doin the tail wag, push down a touch on the elevator and instantly it would head straight for the grass. so even though the maiden wasnt perfect I am sure I can get the next one flying
Joe
Old Jan 14, 2013, 07:24 PM
sloperjoe's Avatar
Joined Mar 2012
have all the new parts layed out and should have them cut, laminated, and the shaping started by tonight
decided to go with a 2 layer verticle stab on this one to help keep the tail incidence correct. should have version #2 ready for a weekend maiden if the weather cooperates, was snowing...now its like freezing rain....temps have been in the very low 20's and teens at night..... B B b bbbrrrrrrrr..
Joe
Old Jan 15, 2013, 05:17 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Funny how you are freezing over there and I am sweating over here with an expected temp of 110° tomorrow.
Old Jan 15, 2013, 05:28 PM
Joined Mar 2007
75* here 3 days ago with floods (6" of rain) and now we are under an ice storm warning for up to 1/2" of ice......Emergency management just became activated......What I would give for 85* and sunny skies!!!......
Great job Joe on the Harrier!!!...Looking forward to the vids of your flights...
Kevin
Old Jan 15, 2013, 08:24 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Kevin-- What region are you in? That's crazy weather.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Jan 15, 2013, 11:00 PM
sloperjoe's Avatar
Joined Mar 2012
holly smokes Dave...I dont mind warm weather but 110 is a bit toooooo warm
Joe
Old Jan 16, 2013, 04:21 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I know, and 116° forecast for today.... I think most of us will hide indoors if we can.
Help! Scorpio hawker hurricane mk1 diddsie Electric Warbirds 0 Apr 16, 2012 05:00 PM
Discussion Hobbyking Hawker HARRIER 70mm Jump Jet! jbc Foamy EDFs 10 Jun 09, 2011 08:37 PM
Wanted RCM 2-1984 Hawker Harrier nero1156 Aircraft - General - Miscellaneous (FS/W) 0 Jan 28, 2011 07:30 PM
Build Log 24" span Hawker Hunter Mk1 rcminiman Foamy EDFs 59 Aug 07, 2007 09:47 AM
