Old Jan 11, 2013, 04:53 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
Build Log
"Box Fuse" Hawker Siddeley Harrier GR MK1
For my next adventure in "box fuse" building I wanted to try something that probably most wouldnt think possible with this method of construction...a Harrier
I have been wanting to do a Harrier for quite some time now, but couldnt think of a way to get all the complex curves without some convoluted complicated foam bending, or some serious hot wire action. Then it hit me...do a multi stage "box" and sand it to shape
Well here it is, and I'am very happy how this one came out, just about how I envisioned it. Believe it or not it came out extremely lite too, and "should" fly good.
I will be powering this one with a little SkyAngels "9000kv" motor mounted into an ArtTech 30mm fan unit with six blades...a little testing with this set-up tells me it should have plenty of poop to get it moving through the sky
So here are the specs:
WS..............12" (wing area about the same as the Mig-17)
Fan..............30mm
Servos.........2 X 3.5g
Cntrl.............Tailerons
Batts............3s 460mah 45c NanoTech
Foam...........Dollar Tree Ready Board
Wght............? dont know, dont care...but its lite
Here are the build pic sequence and plans, again this is actually a fairly simple build, I spent more time laying out the parts, cutting them out and laminating them together than I did sanding, the sanding was actually the easy part this time. I still have some LW spackling and finish sanding to do, then just need to add the "make it go" stuff...Iam chomp'in at the bit
here you go, enjoy
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Jan 11, 2013, 07:41 AM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Simply AMAZING, STUNNING, BRILLANT. How did you visualize this. Who's your Geanie.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Jan 11, 2013, 08:40 AM
au117 is offline
Find More Posts by au117
Joined Jun 2010
very nice Joe
au117 is offline Find More Posts by au117
Old Jan 11, 2013, 12:49 PM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
Here we go again! XD
man you should sell your plans to a brand like dynamic foamy or something like that ;-)
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Jan 12, 2013, 01:23 AM
sloperjoe's Avatar
Joined Mar 2012
Ksqm
hey thanks Ksqm, no genie, just trying to think "inside the box"
Originally Posted by au117 View Post
very nice Joe
thank you very much
well thanks Robert, I wouldnt object to getting my hobby to pay for itself, but till then I dont mind posting my plans free for all to build with, be cool to see somebody build one of them, that would be pay enough for me
maybe I should change my user name to "JoeBoxer"
Joe
Old Jan 12, 2013, 01:56 AM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
wow The first foamy edf harrier I've seen, love it
minimicrorc is offline Find More Posts by minimicrorc
Old Jan 12, 2013, 02:04 AM
sloperjoe's Avatar
Joined Mar 2012
thanks man,
HK sells a foamy Harrier, but its 70mm and a bit big for my flying area, so this one should cure my Harrier "jones"
Joe
Old Jan 12, 2013, 04:26 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Daaaaangg!!! I can't keep up!!!
Like I don't have enough half finished models lying around that I keep telling myself to complete and you post this one Joe!
Love the Harrier and have been planning a micro version for ages. This one this looks great!
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 12, 2013, 05:34 AM
sloperjoe's Avatar
Joined Mar 2012
thanks Dave!
well..., now you can build one
just got through mounting the the "make it go stuff", just need to add the pushrods and should be ready to maiden on Sunday....if it aint snow'in anyway
Joe
Old Jan 12, 2013, 10:26 AM
jumo004 is offline
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
Way COOL !!!
Can't wait to see what's next ...
Could you go into some detail on where you get your initial views from and how you scale them up (or down). It looks hand drawn but do you use any CAD in the process ?
Thanks.
jumo004 is offline Find More Posts by jumo004
Old Jan 12, 2013, 01:04 PM
sloperjoe's Avatar
Joined Mar 2012
Originally Posted by jumo004 View Post
Way COOL !!!
Thanks.
thanks jumo004,
I find 3-views either in one of the many aircraft books In my library or pull them off the net, then sit down with a calculator and run #'s till I find the %'age that looks good and then start laying it out on 1" grid paper. I draw all my plans by hand, I dont do cad. I also get photos of the full scale versions for reference while drawing and shaping to help get a good "scale looking" appearance
Joe
Old Jan 12, 2013, 01:58 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
That is really a beautiful model. You're quite a sculptor. Looking forward to seeing the EDF and radio gear installed.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Jan 12, 2013, 05:00 PM
sloperjoe's Avatar
Joined Mar 2012
thank you very much,
dont really need to be a sculptor, all it really takes is to be able to round off the corners, anyone that can shape a canopy out could do this easy
Joe
Old Jan 12, 2013, 05:51 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Joe---Do you just visualize these planes and build them or what???......VERY good job and thanks for posting your designs...What thickness Depron do you use???
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Jan 12, 2013, 06:10 PM
Joined Mar 2007
Kevin
Help! Scorpio hawker hurricane mk1 diddsie Electric Warbirds 0 Apr 16, 2012 05:00 PM
Discussion Hobbyking Hawker HARRIER 70mm Jump Jet! jbc Foamy EDFs 10 Jun 09, 2011 08:37 PM
Wanted RCM 2-1984 Hawker Harrier nero1156 Aircraft - General - Miscellaneous (FS/W) 0 Jan 28, 2011 07:30 PM
Build Log 24" span Hawker Hunter Mk1 rcminiman Foamy EDFs 59 Aug 07, 2007 09:47 AM
