Old Jan 11, 2013, 01:21 AM
cloud_9 is offline
Find More Posts by cloud_9
Jim in the Desert
United States, NM, Las Cruces
Joined Aug 2007
Confused - prop size vs motor size vs thrust
I have been looking at threads on picking a power system, etc., and am confused.
If you use a smaller prop, say a 9x4.7 on a slow stick, you get more RPM. If you switch to a larger prop, say 11x4.7, you get less RPM. But the prop pulls more air, being bigger. So which one is going to move you through the air better, the bigger prop at lower RPM, or the small prop at more RPM? And which will put more straing on the electrical system and motor?
I know if the motor has high Kv you can burn it up with too big a prop. But that doesn't make sense to me. Why doesn't the higher RPM put just as much strain and heat on the motor?
Jim
cloud_9 is offline Find More Posts by cloud_9
Old Jan 11, 2013, 01:42 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi Jim!
A running electric motor works also as a generator, generating a voltage opposed to the voltage of the battery. If you run the motor without a prop, it spins fairly fast, creating a voltage that is almost as high as the battery's. The resulting voltage differenc is only small, resulting in very little (idle) current through the motor.
If you reduce the RPM by mounting a propeller, the generated voltage is smaller, the voltage difference to the battery higher, the resulting current bigger.
If the motor is blocked, it does not generate any voltage, and the resulting current is the highest. Almost a short circuit, if it would not be for the little resistance the motor windings have.
More current always means more heat.
This is why a bigger prop translates to more current with everything else being equal.
Generally, a bigger prop has a better efficiency than a small one. But a small propeller can keep it's efficiency in a wider speed range.
If you put a big prop on your plane, the acceleration will be better, but you will not be able to fly very fast. When your airspeed approaches the flow speed of the propeller, the efficiency declines.
If you put the same power in a smaller propeller, it will spin faster, allowing for higher speeds because of the higher flow speed. But you will have less acceleration, less "pull".
Think of it like the gears in a car. 1st gear is fairly good for acceleration, but you can't drive very fast with it. 2nd gear is better in this regard, but it won't allow for quick acceleration.
Thus, it makes alway sense to choose the propeller according to the desired speed range of your plane.
It does not makes things simpler that electric motors typically are more efficient at higher RPMs.
Julez is offline Find More Posts by Julez
Old Jan 11, 2013, 01:55 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
You've managed to bottle up a whole lot of big questions in that one little post
Let's start with the props... For a given motor, you're working with a relatively small band of its RPM range (about the top 25% of Kv*Vin). The reduced diameter of the 9" prop means it requires less power to spin but also produces substantially less thrust for a given RPM. Since the motor's maximum RPM is a finite number and its "minimum RPM" is going to be ~75% of Kv*Vin (where the motor will generally be drawing its max current), you'll end up simply using less power and getting less thrust overall. This is less demanding for the power system, but obviously now you have less thrust on hand.
As for the motors burning up, that one tends to trip folks up who aren't used to how this stuff works. The motor is drawing the lowest current when there's no load on the shaft because it can spin just about as fast as it wants to (approximately RPM = Kv * Vin). This means that the back voltage is almost dead equal with the input voltage, meaning that the motor draws very little current. It's happy. NOW... We place a prop on the shaft and that motor is forced to slow down by some amount, which means that the back voltage drops while the input stays about the same. This makes the motor draw more current. It's working harder and using more energy to keep that prop spinning, and some of the energy it takes in is wasted as pure heat. That heat warms the motor up, and if there's too much of it then the motor fries.
I apologize if none of this makes sense, by the way. It's been a long day and I've been trying to program pitch curves on my old DX6 for the past two hours. My brain's got a bit of a sputter in its ticktock... Someone else will probably be along soon to explain it better
Piece is offline Find More Posts by Piece
Old Jan 11, 2013, 01:56 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
Oh, goody. Looks like Julez has you covered
Old Jan 11, 2013, 08:26 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Jim,
For the same input power, if you want maximum thrust go for large diameter, low pitch... if you want speed go for smaller diameter, higher pitch.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 11, 2013, 12:52 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Jim, as a suggestion you could tell us what motor and airframe you are trying to fit. A high wing trainer will have a different set up than a pylon racer or a glider.
JimNM is offline Find More Posts by JimNM
Old Jan 11, 2013, 01:52 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Thanks Julez, C4H10 and Dr. Kiwi.
Jim, I am looking at this motor on a GWS slow stick, built lightly, 800-1500mah 3S but wondering also about 2S.
http://www.headsuprc.com/servlet/the....8oz%2C/Detail
However, I want to understand the principles in general because I have several planes I plan to get to.
Say, I notice you live in Las Cruces. Wonder if we've met at the field? I stopped flying when I got my motorcycles 5 years ago but am getting back in. Forgive me if I'm making a gaffe, at least it's in very slow motion :-).
Jim
Old Jan 11, 2013, 02:46 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
It's all good. I am hard to fly with on any schedule due ro work and family. I do not fly at NMSU at this time and I rarely get out to the club field. I applaud your knowledge quest and will be happy to explore it with you. PM me and we can exchang contact info.
Old Jan 11, 2013, 05:11 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Jim, I fly my SlowStick with an AXI 2212/34 (~740Kv) on 3s and an 11x7 GWS HD.. draws about 10A... so your FirePower 400 will have just a bit more get up and go.
Cheers, Phil
Old Jan 11, 2013, 06:31 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Cheers, Phil
Why so overpowered? I fly mine with an AXI 2212/34 on 3s and an 11x5.5 APCe. Draws about 7 amps at 5000 ft altitude. Flies just great even at the lower atmospheric pressure of my field altitude.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jan 11, 2013, 07:38 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I'm bringing my driver to your place to see how far I can hit a golf ball!
Old Jan 11, 2013, 10:24 PM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Do that. We have a great golf course. Of course, right now it is under six inches of snow.
Old Jan 11, 2013, 11:56 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Phil and Larry, well I would have gone with that motor had I known about it, but I just called Jesse at Heads Up and asked for recommendations. I want to fly as slow as possible.
May I ask why you use props with 7 and 5.5 pitch? I bought 11x4.5 and 11x3.8, thinking it would let me fly slower. But maybe the bigger bite slows the RPMs more so you fly slower with your props than I would. I need to get my Dr. Kiwi engine stand and Medusa gear set up so I can explore this. This is one of the funnest conundrums in RC, and why I bought Phil's lovely stand to begin with.
BTW I am at 4000 to 5000 feet, depending on where I fly around here.
Jim
Old Jan 12, 2013, 09:37 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Larry, I'll bring some yellow or orange golf balls (sorry, I don't do pink).
Old Jan 12, 2013, 04:43 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
C9, minimum flight speed isn't related to the power system. Regardless of which prop you run, the plane's minimum flight speed will remain the same because it's a function of wing loading and other characteristics of the plane itself, so reducing pitch won't "let the plane fly slower". It will only force you to fly slower at full throttle.
Higher pitch means higher top speed (at the cost of more power), so you have a broader speed range available. Depending on the setup, you may be able to cruise at the same speed using less power because you don't need the RPMs to be as high.
Discussion motor KV vs Amps vs Thrust grant31781 Power Systems 10 Nov 08, 2012 02:35 PM
Discussion Confused! Scorpion 2221-8 + sting ray. Prop Size? scotti Power Systems 6 Apr 24, 2012 01:30 PM
Discussion Fan thrust vs prop thrust; why the difference? PlaneFan Electric Ducted Fan Jet Talk 3 Mar 04, 2012 10:55 AM
Question How much more thrust from a Aeronaut 14x8 folding prop vs 13x6.5 hog2soar Power Systems 3 Mar 02, 2012 11:09 PM
Thrust vs weight and prop sizing BlueSkyBlack___? Electric Plane Talk 2 Sep 06, 2005 08:00 PM
