Old Jan 11, 2013, 01:17 AM
cloud_9 is offline
Find More Posts by cloud_9
Jim in the Desert
United States, NM, Las Cruces
Joined Aug 2007
Gonna charge up some six year old lipos
I got out of the hobby about 5 years ago, but came to my senses and am building up a slow stick. I have about 15 lipos that were about a year old when I got out in 2008. I stored them a few years at half charge in the fridge, but since then they have been in various places. I figured they were goners, but a 800mah enerland just charged up fine on my Thunder Power TP-1010C. A couple of the others are puffy. I'm charging them in the middle of the back yard with the battery in an ammo box (top not sealed but laid loosely on).
How will I know if they are OK? Guess I'll just try them....
BTW, the TP can do CC or CV, but I don't know how to control it. Anybody know? And should I just go with the default CC?
Jim
cloud_9 is offline Find More Posts by cloud_9
Old Jan 11, 2013, 01:26 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi!
Charge them slowly and balance them in the beginning. If they are not puffy, check if they still can deliver the current needed for your application.
A normal Lixx charge algorithm is CC/CV, not sure what your chargers functionality is...
Julez is offline Find More Posts by Julez
Old Jan 11, 2013, 09:33 AM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Wow, they seem to be charging up just fine. I always heard over 2 years old, throw them away. This is great if they work. I'll try doing the puffy ones later today when I can watch closely. But I don't know if I should keep them.
Jim
Old Jan 11, 2013, 09:54 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
The puffed ones are prob shot.
The Tug is offline Find More Posts by The Tug
Old Jan 11, 2013, 02:08 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Charging the big puffy one now, a 2200 mah enerland 3S.
Old Jan 11, 2013, 02:09 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
One of the 800mah 3S is not puffy but it has a bunch of blue-greenish-whitish gunk all over the Dean's connector. Is this not a good thing?
Jim
Old Jan 11, 2013, 02:15 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Originally Posted by Julez View Post
Hi!
Julez, what do you mean by this? Chargers like mine usually do CC then switch to CV? It talks about both but there is no setting in the menu sequence to pick one or the other?
It does say in the manual that in CV mode the amps can ramp down. In CC mode the voltage varies and you can select that, from .25 amps to 125% of 1C.
Old Jan 11, 2013, 02:31 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Batteries are cheap, I would dispose of the "big puffy one" and just buy another battery.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Jan 11, 2013, 02:50 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Well to some they are cheap, to others who have less money not so much. But in either case they are cheaper then an airplane!
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 11, 2013, 03:10 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Perhaps I missed it but do they have balance taps and did you perform a balance charge?
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 11, 2013, 03:14 PM
Mike_Then's Avatar
Joined Apr 2001
No 6-year old "big puffy battery" is worth the risk of setting one's airplane (or house) on fire. With the proliferation of cheap batteries from overseas dealers, batteries have become more affordable for almost any modeler, regardless of budget.
Old Jan 11, 2013, 04:11 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Hm, the puffy one acts as though it charged up fine, no fire, but it's scary looking, I'll reap the connectors and toss it and the other puffy one. I'll need to look up how to properly dispose of these. But I hope all the others are OK, I'm kinda scared of them too thought they look fine. Yes, I was balance charging them with the TP-210V balancer.
Jim
Old Jan 11, 2013, 05:28 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Jim
Sounds like corrosion from moisture and battery voltage; they don't play well together.
I would use them on the ground, not in the air, until you know you get the power you want/need and the run time too.
I would toss the puffy packs.
I would then replace any connector on any pack that survived your testing as any with corrosion will have a short life, maybe cause you to fall out of the sky from an OPEN connection.
Rick
rampman is offline Find More Posts by rampman
Old Jan 11, 2013, 05:38 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Car , Truck & tank crashes are usually not in a field of dry burning grass hundreds of feet away with no fire fighting equipment. Swap with some car guys...............Never mind that. They sometimes run those packs hard & below empty.
Save some Aluminum cans for newer batteries.
Good Luck
cyclops2 is offline Find More Posts by cyclops2
Old Jan 12, 2013, 05:29 AM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Heh, yeah, well it hasn't come to aluminum cans yet thankfully.
Thanks all.
Jim
Question Old 1500mAh Lipo now at 1200mAh capacity -- Do I still charge at 1.5A setting? James Frolik Batteries and Chargers 6 Sep 05, 2012 10:20 PM
Question Newbie with Two Year old 8S lipo's, Pictures (edit, its also an e-bike) drebsdorf Batteries and Chargers 10 Sep 02, 2012 02:08 PM
Discussion Six days in a tree and I gonna make it home tonight. everydayflyer Batteries and Chargers 12 Mar 24, 2012 09:16 PM
Discussion Safe to charge a 5 year old LiPo? WrongwayFeldman Batteries and Chargers 5 Aug 20, 2010 12:48 PM
How about pictures of some old radio (20 years old or more)? FLYRCM Radios 9 Dec 02, 2005 10:53 AM
