Old Jan 25, 2013, 06:33 PM
in the air
in the air
Joined Aug 2006
DP cool!
and the hook goes to the BACK! back o slot club member
just wondering since I B a RDS virgin.
looks great
but more pictures glider po.n do not hold out DP
thanks
MB3
THE EYE is offline Find More Posts by THE EYE
Old Jan 25, 2013, 06:35 PM
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Lol... Jiri doesn't know me well enough to know that when I give him a hook position.... That's THE most aft usable position.
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Jan 25, 2013, 07:37 PM
R.M. Gellart's Avatar
Joined Nov 2005
I thought that you never reached a rearward position?
Thanks for answering the RDS bend question, I saw those straight rods and wondered what was up.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Jan 25, 2013, 11:31 PM
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Originally Posted by Daryl Perkins View Post
Mark, Jiri usually prebends the rods. The length and angles haven't been defined yet, so I'm bending them. It'll get 55 degree bend on the flaps, then probably 40 ish and 35 ish...
Daryl, the ATX 809 servo can travel 160 degrees. Knowing you, you are not going to limit it to just the typical 90-100 degrees total are you .
If it was me I would use as much as the TX/RX combo would allow and perhaps bend the flap rds rods 45 degrees, middle ail 25-30, tip ail 20-25.
I posted a simple RDS excel calc here for some ideas.
The only negative thing then is to dial in the speed of the TE deployment so the whole TE travels up/down at same speed ( if you want to get that anal-ick-tickle).
With just a 45 bend, at 15 degrees of flap (for launch) you can go up the line at least 85mph and be well within the servos dynamic torque specs. I say at least because I know the chord of Vixen's flaps is not as big as what I am used to. What is the AR on that thing 20+?
And thanks for taking the time to do a build log on a pre-production model. Takes confidence in the builder and manufacturer to do such as you will be exposed to much scrutiny! But, that is one of the best ways to advance quickly. I really appreciate it! Thank you!
fnnwizard is offline Find More Posts by fnnwizard
Old Jan 26, 2013, 11:34 AM
Joined Aug 2006
Vixen F5J?
Will that fuse work for F5J?
Frederick_r is offline Find More Posts by Frederick_r
Old Jan 28, 2013, 06:45 PM
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
OK, DP... Let me be the one to ask the really DUMB question... With 6 servos in the wing, are there 4 flaps or 4 ailerons?
Jack... AKA Darth Seriously Interested...
schrederman is offline Find More Posts by schrederman
Latest blog entry: The BEST!
Old Jan 28, 2013, 06:58 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Yes. 6 ailerons or 6 flaps.
;-P
R,
Target
target is offline Find More Posts by target
Latest blog entry: Stork 4 Pro X-tail from...
Old Jan 28, 2013, 07:09 PM
Joined Mar 2007
Actually, Jack. There are 4 ailerons and 4 flaps.... The inboard ailerons work as both. I'll try to post a video of my trailing edge set up in all the flight modes. But my entire trailing edge is always working.
Old Jan 28, 2013, 07:47 PM
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Sounds like a 10G advertisment
djklein21 is offline Find More Posts by djklein21
Old Jan 28, 2013, 08:41 PM
Crestview, Florida
Joined Dec 2005
Won't an aileron suffer an identity crisis if it doesn't know whether it's an aileron or a flap?
Tappet is offline Find More Posts by Tappet
Old Jan 28, 2013, 08:42 PM
Joined Nov 2005
Or David, a DX-18, whatever your flavor.
Marc
Old Jan 28, 2013, 08:54 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
We are all flaperons, deep down.
Old Jan 28, 2013, 09:16 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Marc
Yep, that thing is a powerful beast
Old Jan 28, 2013, 10:58 PM
Joined Nov 2002
OK, That's what I was thinking... Thanks...
Not sold on RDS but it appears that's the direction everything is headed.
Darth Gotta Have One... SOON!!!
Old Jan 28, 2013, 11:08 PM
in the air
in the air
Joined Aug 2006
pictures of the wing install????
Build Log 70mm Delta "Vixen XD1" Lt599 Scratchbuilt EDFs 90 Feb 22, 2013 01:27 PM
Discussion News - HK DH110 Sea Vixen.. anlucas Foamy EDFs 513 Nov 23, 2012 07:55 AM
Cool **** A great retired competition F3J plane NYX F3J! DS**** Phil Davy Multi Task F3X 0 Aug 15, 2012 09:59 PM
For Sale Wattage Sea Vixen Wings & Booms Jcopter Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2012 03:49 PM
Wanted Wattage Sea Vixen Elevator Jcopter Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2012 03:46 PM
