Old Feb 22, 2013, 12:19 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Originally Posted by littlepiston View Post
Weight
Thanks alot :-)
How much did it set you back? I can not find the autostart on the crx web
henke is offline Find More Posts by henke
Old Feb 22, 2013, 12:34 PM
winkybone is offline
Find More Posts by winkybone
winkybone
United Kingdom, England, Lancs
Joined Mar 2007
Originally Posted by henke View Post
Only reson I can see is that he is not happy to have the engine tested. We can only guess if he has doubts in me or the engine.
Anyway I'm still happy to test it if he changes his mind.
Hi we have been out of the UK for a while on a USA tour , If a TEST is to be undertaken then it has to be with the Manufacturer Jet Joe themselves , I am simply not in a position to free issue engines to people , particularly people we have never met , we can get the engines tested with people here in the UK if that was the case, the products good . Business is good so why do I need to do this ??? at my cost ?? we sell enough products right across Europe and are happy with things the way they are
winkybone is offline Find More Posts by winkybone
Old Feb 22, 2013, 01:05 PM
littlepiston is offline
Find More Posts by littlepiston
USA, NM, Carlsbad
Joined May 2002
Teaser
Here is a still shot of my jr running
littlepiston is offline Find More Posts by littlepiston
Old Feb 22, 2013, 05:41 PM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
nice... if you have it up at full power, and it's only at ~520 c.... it's good to go.
So... what are you putting it in?
Dr Honda is offline Find More Posts by Dr Honda
Old Mar 14, 2013, 02:12 AM
henke is offline
henke's Avatar
Joined Jan 2001
It's been a couple of weeks and I just wonder if you gotten to test the engine out yet? Maybe even fly it?
Looking forward to a review with a little more data and video :-)
Old Mar 14, 2013, 12:17 PM
USA, NM, Carlsbad
Joined May 2002
Ran it some but been busy I did recive a new tail exhaust cone or what ever its called. Got my Xicoy FADEC. Maybe this weekend
Old Mar 14, 2013, 07:00 PM
mr_matt_II is offline
Find More Posts by mr_matt_II
Is the Xicoy a replacement? Did it come with a Xicoy to begin with or did you swap it out at your own cost?
520 C is very cool running. Most turbines I have seen will not make full power at that temp so make sure and check the thrust.
mr_matt_II is offline Find More Posts by mr_matt_II
Old Mar 14, 2013, 09:09 PM
USA, NM, Carlsbad
Joined May 2002
I chose to use the xicoy.
Old Mar 15, 2013, 11:13 AM
Can you still buy JJ without an ECU at all so you can get a Xicoy and not double pay for ECUs?
Old Mar 15, 2013, 01:32 PM
LJE4357 is offline
Find More Posts by LJE4357
Closed Account
Joined Jun 2002
No support hardware
You can still all the JJ turbines only, without the support hardware, except for the JJ Jr. The ECU is modified, and at this point it's the only ECU that will work.
LJE4357 is offline Find More Posts by LJE4357
Old Mar 15, 2013, 06:20 PM
Wow I am confused. I thought you got a Jet Joe junior and bought an aftermarket Xicoy. Is it the Xicoy that is modified or the JetJoe Junior ECU youare referring to?
Old Mar 15, 2013, 06:31 PM
USA, NM, Carlsbad
Joined May 2002
I bout the turbine with th ecu but I returned it and got my money back and then let see ok so ok so lets see here I got the xicoy V 10 FADEC ECU
Old Mar 15, 2013, 07:14 PM
LJE4357 is offline
Closed Account
Joined Jun 2002
All the Jet Joe turbines will work with other ECU's as long as the operationg parameters are properly set up, with the exception of the Jet Joe Jr. Because of the higher RPM, and Higher temperature's, The ECU for the Jr's have different firmware. Now if other ECU's can have the same parameters, then they will work. But to my knowledge, they don't go that high in RPM and EGT, there are also other issues also, starting RPM being one. Thats the reason the Jr is sold as a set.
Larry E.
SouthEast Model Products
Jet Joe North American Dist.
Old Mar 15, 2013, 07:51 PM
USA, NM, Carlsbad
Joined May 2002
My junior ran perfect with the xicoy ecu
Old Mar 16, 2013, 07:10 AM
BakkerRN is offline
Find More Posts by BakkerRN
Joined Mar 2013
What are the parameters of xicoy ecu?
BakkerRN is offline Find More Posts by BakkerRN
Wanted Jet joe JR turbine littlepiston Aircraft - Fuel - Jets (FS/W) 7 Dec 04, 2012 01:11 PM
Discussion Just pulled the trigger on a Syma S033G Predreadnut Coaxial Helicopters 21 Jul 24, 2012 07:16 AM
Discussion I am about to pull the trigger on the PROEDF F-22 sherlockshah Electric Ducted Fan Jet Talk 29 May 20, 2010 04:18 PM
Discussion I'm about to pull the trigger on this setup.. APdude07 FPV Talk 2 May 14, 2009 05:06 PM
