Old Jan 10, 2013, 08:25 PM
dmbaerry is offline
Find More Posts by dmbaerry
dmbaerry's Avatar
United States, NC, Burlington
Joined May 2012
Looking for a good .10 size trainer
I have a Magnum .10 and would like to find a good trainer kit. Any suggestions?
dmbaerry is offline Find More Posts by dmbaerry
Old Jan 10, 2013, 08:46 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Look in "outerzone'? for a Pilot 10 plan. (saw it in there not long ago)
Mid 70's kits out of Japan. All their works were Very Good fliers actually
Bare is offline Find More Posts by Bare
Old Jan 10, 2013, 08:51 PM
Scirocco14 is offline
Find More Posts by Scirocco14
Scirocco14's Avatar
Asheville, NC
Joined Mar 2009
Prairie Bird 50 is another option. They can be found on RCGroups occasionally and on the 'bay.
Scirocco14 is offline Find More Posts by Scirocco14
Old Jan 11, 2013, 04:40 PM
Moeregaard is offline
Find More Posts by Moeregaard
United States, CA, Thousand Oaks
Joined Sep 2010
The Prairie Bird would be an excellent choice for a .10-sized trainer. Regarding the Pilot designs mentioned above, Pilot produced another kit called the Junior 100 and that plan is also on Outerzone.
Moeregaard is offline Find More Posts by Moeregaard
Old Jan 11, 2013, 06:33 PM
ZAGNUT is online now
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
the "tooter" plans can be had here: http://www.airagestore.com/plans/rc-...rs/tooter.html
about the same as sticking the engine on something like a sig riser or CG gentle lady. maybe chop a foot or so off the wing span.
ZAGNUT is online now Find More Posts by ZAGNUT
Old Jan 11, 2013, 06:49 PM
dmbaerry is offline
dmbaerry's Avatar
Joined May 2012
thanks everyone... I am aware of Pilot Kits.. wish i could find one but I may have to scratch build one. How hard would that be. I have only built kits and I have not built anything in abiut 18 yrs.
Old Jan 11, 2013, 06:56 PM
dmbaerry is offline
dmbaerry's Avatar
Joined May 2012
I like the Tooter too!... Does anyone cut a kit of this, even a short kit would be good
Old Jan 11, 2013, 07:07 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Actually a two meter glider is a great trainer with a .10 if there is enough room in the fuse for a tank and servos etc.
aspeed is offline Find More Posts by aspeed
Old Jan 12, 2013, 08:18 PM
dmbaerry is offline
dmbaerry's Avatar
Joined May 2012
I looked today via rc Groups and RC universe and Ebay.. no luck
Old Jan 13, 2013, 07:13 AM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
Are you looking for a real beginners airplaine or a trainer with 4 channels?
The "Stick" type of planes are great fun, even as you improve on your skills, and the Chea-pass should work well on a .10 engine.
surfer_kris is offline Find More Posts by surfer_kris
Old Jan 13, 2013, 06:03 PM
dmbaerry is offline
dmbaerry's Avatar
Joined May 2012
Hey thanks... I am looking for something a little more forgiving, but that is something I was looking for as a second plane also.. thanks alot... will put that one on the second plane build.
I am just getting back into flying after 20 yr absence.
Old Jan 13, 2013, 06:55 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
Randy Randolph's "Dime" is exactly what you need. AMA has the plans, and Lazerworks cuts a short kit if you want it. It is quite large for a .10 size plane but it's very light. Randy designed good airplanes and had a ton of experience by the time he did this one. It would be very easy to fly and it's a pretty simple build, even simpler with the short kit.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Jan 13, 2013, 10:22 PM
dmbaerry is offline
dmbaerry's Avatar
Joined May 2012
[QUOTE=buzzard bait;23805047]Randy Randolph's "Dime" is exactly what you need. AMA has the plans, and Lazerworks cuts a short kit if you want it. It is quite large for a .10 size plane but it's very light. Randy designed good airplanes and had a ton of experience by the time he did this one. It would be very easy to fly and it's a pretty simple build, even simpler with the short kit.
Jim[/QUOTE
Yes, I like that and I found the Lazer Works short Kit... and it looks like it is 4 channel... Just what I was looking for... thanks so much
Old Jan 15, 2013, 07:59 PM
dmbaerry is offline
dmbaerry's Avatar
Joined May 2012
I am trying to decide between the RCM Basic Trainer and the Randy Randolph's Dime.. Both are Short Kits from LazerWorks...
Old Jan 16, 2013, 12:00 PM
Bare is offline
Canada
Joined Nov 2000
Seriously? If after a First time trainer. Suggest you fit a cheap electric power system. To an almost Free foamboard 'aeroplane'..pretty well indestructible.contraptions when slapped together from EPP foam bits..
Big on training abilities... not so great on looks though.
Look in the 'Scratchbuilt Foamies' forum for massive help
Easy reliable and hassle free.. so you can concentrate on avoiding the ground, without the additional distraction of starting and keeping the motor running... or long and involved crash repairs :-)
Lotsa time later to build your glo model
Wanted Looking for NIB .40 sized trainers for my High School flight club. Opus44 Aircraft - Fuel - Airplanes (FS/W) 5 Oct 06, 2012 04:58 PM
Discussion Looking for a good first medium sized electric electricrc68 Electric Plane Talk 55 May 12, 2012 04:26 PM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
Question Looking for a good 30-40 size sport trainer ShuRugal Fuel Plane Talk 6 Jun 21, 2011 01:33 PM
Discussion Looking for a Good (Looking) 4ch Trainer HELP! ShokWaveRider Beginner Training Area (Aircraft-Electric) 2 Oct 27, 2006 10:18 AM
