Old Mar 10, 2013, 04:33 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Thinking about the Aeromaster gives me an appreciation for your desire to build in a scale that fits in your car fully assembled. The Aeromaster fit inside my Honda Accord (seen at the left side of the pic) with a little room to spare.
Yes E.J. , especially with Bipes I can get a decent size plane, relatively speaking, to fit without any disassembly. That saves time at the field, makes it convenient to store hanging like a bat from the prop in the garage, and eliminates the possibility of things like wiring the ailerons backwards.
Plus, what I seem to notice, maybe because I want it to be so, is that the smaller the plane the closer in you can fly it, and so my planes looks just about as big to me as some of the Giant scale planes that are flying twice as big (or more) a pattern. Anyway, its my "perspective". The Aeromaster is a very convenient size but the Waco will fit wings on too in the back of my old Volvo "airplane car".
u2builder is offline Find More Posts by u2builder
Old Mar 10, 2013, 05:46 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
One of the coolest "airplane cars" I've seen was back in the '70s. An older gent had a Morris Woodie wagon. An airplane car with a lot of character.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Mar 10, 2013, 09:37 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
My LHS had some pretty nice 6" wide 1/8" balsa, so I built a new vert stab. This time I extended the tail post an inch beyond the bottom of the fuselage. I'll trim it to length when I mount the stab. Took a few hours to build, mostly eating for glue to dry.
I also got a chance to square-up and use a couple of the taller building board fixtures and presses.
EJWash
Old Mar 11, 2013, 07:19 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
A nice thing about building our own models, is that "do overs" are possible. If we build something that we don't like, we can try again, and again, until we are satisfied.
TomCrump is offline Find More Posts by TomCrump
Old Mar 11, 2013, 08:26 AM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
True Tom. One of the reasons I'm gravitating towards plans building. A longer process, but you're your own quality control department.
EJWash
Old Mar 11, 2013, 10:17 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I think you made a wise choice build a new V stab. Yes a little more work but you will be happy in the end knowing it is as strong as it can be.
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old Mar 16, 2013, 07:00 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Put down the fuselage crutch on the building board.
Just like building the wings started with the main spars and everything being attached from there, so it is with the fuselage. A balsa frame (called a "crutch") that follows the outside shape (birds-eye view - looking straight down) of the fuselage is built over the plans. The bottom fuselage formers are attached to crutch. The fuselage is then turned over and the top formers attached.
Thought I'd post a few picks of the new toy I found at MicroMark. The fuselage crutch framework has cross-pieces attached. Being that the sides of the fuselage are curved, the ends of these cross-pieces are angled. With the use of my new measuring tool I am able to determine the exact angle of the cross-pieces. I can then sand each piece to this angle with my mitre sander.
EJWash
Old Mar 16, 2013, 08:07 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
That is a very cool sanding tool and perfect for this type of construction. I have always been frustrated trying to get a perfect angled joint. Fantastic work as usual.
Old Mar 16, 2013, 10:02 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thanks U2.
At a base of just 5-1/4" X 7-1/2", the angle sander is too small. I want to make an enlarged version of it.
EJWash
Old Mar 17, 2013, 11:05 AM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
The fuselage crutch (so aptly named) is finished and is ready to receive the fuselage components.
The magnetic building board system shows a real advantage here. Very small chance at building a banana
EJWash
Old Mar 17, 2013, 12:36 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Forgot to taper the outside front (nose) area of the crutch before I took the pic. NOW the crutch is complete and ready to receive the fuselage components.
You've seen me replace several of the kit supplied parts. In most cases, I'm not satisfied with the die-cutting (die-smashing) of a part, or the quality of the kit-supplied wood. In order to duplicate the parts that I replace, I make a photocopy of the part I'm replacing from the plan sheet. I compare the photocopy to the plan sheet to make sure the copy matches the replacement part on the plan (some copiers do not provide an exact 1-to-1 copy).
I used to own a copier that would accept card-stock weight paper (80#) but my current copier does not. Card-stock makes a great trace-around template. What I do now is glue the photocopy of the part to card-stock using photo mounting spray glue. This grade of glue sprays finer from the can than the multi-purpose spray glues. I roll-out the photocopy on the card-stock using a veneer roller to get it nice and flat. I give the glue about 10-15 minutes to dry and then trim the outline of the part. Now I have a template of the part I want to replace. I use a fine-tip roller-ball type ink pen to draw my outline on the wood. This type of pen does not indent the wood, and the fine-tip allows the ink to get right up close to the template.
EJWash
Old Mar 17, 2013, 01:28 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Nice progress, EJ.
I enjoyed building the fuselage on mine. I'm sure that you will, too.
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
IIRC, there are sizing controls within the flatbed scanner and/or printer with which we might fine tune output size. Already having 2 sets of plans for the Cub, I haven't yet tried duplicating sections of the plans but now I'll look for an excuse to do that.
I have a photo printer (Canon ip8500) whose paper transport handles heavy photo paper very well so should do just fine on a manila folder (my go to for small patterns), though I have to test that.
Ordinarily, when I have to replace a kit part, I just use the part as a template for the new one.
Others have mentioned transferring an image from the copy directly to the wood by heating the reversed image's toner using a covering iron. Got to try that one, too.
loNslo is offline Find More Posts by loNslo
Old Mar 17, 2013, 01:33 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
In my case, I'd end-up with a duplicate of a badly "cut" die-cut part.
I tried that out a couple of years ago using a clothes iron. It does work fine.
EJWash
Old Mar 17, 2013, 01:34 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thanks Tom!
EJWash
Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 16, 2012 09:06 PM
Sold 1/5 Scale 72" Pica Waco YMF Model Airplane Kit LCS Aircraft - Fuel - Airplanes (FS/W) 2 May 15, 2012 09:16 PM
Sold Pica 1/5 scale Waco YMF - in the bones Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Apr 10, 2012 06:35 AM
Sold Pica Waco YMF3 1/5 scale built ClayH Aircraft - Fuel - Airplanes (FS/W) 3 Dec 28, 2008 07:11 PM
For Sale Pica 1/6 scale YMF3 WACO p40nut Aircraft - Fuel - Airplanes (FS/W) 2 Nov 08, 2007 12:37 AM
