Guess what came in the mail today? The vinyl decals from Callie Graphics! See the pics for match-up on plans sheet.
Callie continues to produce impressive work. I'm not using the large NC numbers on my ship. I requested a custom 'N' number and Callie delivered. Matched the same font as the kit graphics and all. EJWash |
I kept thinking about the lower wing ribs. This design does not use capstrips, and I was concerned about the strength of the ribs all by themselves being that I had drilled them to accept the servos leads for a dual servo set-up. I was concerned about the strength of the ribs all by themselves. I epoxied carbon tow on each side of the servo lead drilled ribs except the root ribs which will be sheeted top and bottom, and the servo bay ribs, which will be reinforced for the servo mounting.
EJWash |
I used to add CF tape to everything when I started building planes. I do this less and less now, probably because nothing ever breaks unless I drill it into the ground and and then the CF tape just makes it harder to fix. I am building a couple foamies now where I will be needing some CF however.
The real "weak links" on this plane IMHO seem to be the way the main spar is attached to the center section (CF tape would have been good here but I just didn't feel like adding it given the strange build sequence) , and the rather "light duty" tail feathers and rudder attachment. I didn't even bother to fix this, though I might but probably won't. Most of the damage to my planes occurs while transporting them in or out of the house, garage or car. |
U2,
I'm about to sheet the top of the ailerons. The plans call for mounting a 1/8" ply plate in one of the bays for the control horn. My kit included ply horns to connect the lower ailerons to the upper ailerons. I see in one of your pics that you may have mounted a plate? Are you planning to use a nylon horn here? I was thinking about doing that but didn't see much room for much "bite" of the mounting screw. EJWash |
E.J., You have found a problem with my kit version. I had nylon brackets that were to attach by a small screw. Indeed there was not enough "bite" and I have had to retrofit small bolts. Not a very good system on my plans. Actually I have not finished that "retrofit" yet on the top wing.
My kit contained four small (tiny really) 1/16" ply horns that are glued to the aileron ribs. I'm not too wild about that idea. I'm going to glue balsa in each training edge bay where the aileron slaves struts are mounted. This way I can use regular control horns. I'll take and post a pic of it later.
Thanks! EJWash |
That's a good idea E.J. I made a bit of a mess because I tried to screw my plastic horns in. The screws were way too small and too short and pulled out. I have only sort of tried to fix it. I've been playing with foam FPV planes lately. It is too cold out clearcoat my Waco, so I just like looking at it all together for now.
Aileron slave strut control horn mounting blocks have been glued, planed, and sanded. The ailerons are ready for their top sheeting.
EJWash
| Thread Tools | |
| Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit | spitfire1999 | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jul 16, 2012 09:06 PM |
| Sold 1/5 Scale 72" Pica Waco YMF Model Airplane Kit | LCS | Aircraft - Fuel - Airplanes (FS/W) | 2 | May 15, 2012 09:16 PM |
| Sold Pica 1/5 scale Waco YMF - in the bones | Hemikiller | Aircraft - Fuel - Airplanes (FS/W) | 1 | Apr 10, 2012 06:35 AM |
| Sold Pica Waco YMF3 1/5 scale built | ClayH | Aircraft - Fuel - Airplanes (FS/W) | 3 | Dec 28, 2008 07:11 PM |
| For Sale Pica 1/6 scale YMF3 WACO | p40nut | Aircraft - Fuel - Airplanes (FS/W) | 2 | Nov 08, 2007 12:37 AM |
