Asturias, Spain
Joined Mar 2001
Nice high torque servo
http://www.rcmart.com/sanwa-ers962-t...o-p-36087.html Looks ideal (apart from price) for larger models. The torque rating would, I calculate, still be over 20 kg/cm (about 290 oz/inch - 195 Newton/cm) at 6.0 V. Waterproof as well and weighing only 62 gms (2 oz approx.)
Wow! that is one strong servo! Wonder if this would make a good sail servo? My favorite Futaba S 3801 as you know is no longer produced - The one you point out is a lot stronger! Might brake something if you weren't careful but it would sure pull in the sails!! Looks like they are sold out! here are it's specs to the S 3801 Futaba S3801 Analog 3.77 oz (107.0 g) 2.32×1.14×1.97 in (58.9×29.0×50.0 mm) 4.8V:156.0 oz-in (11.2 kg-cm) 6.0V: 194.0 oz-in (14.0 kg-cm) 4.8V:0.30 sec/60° 6.0V:0.26 sec/60° 3-pole Dual Bearings Hybrid |
Asturias, Spain
Joined Mar 2001
The original link seems to have died. It's also on http://www.rcmart.com/savox-sb2273sg...o-p-36113.html as the Savox SB-2273SG It's also about twice as fast as your Futaba S 3801. $119 for a servo's still a bit pricy though.
| Thread Tools | |
| Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo | DPage | Aircraft - General - Radio Equipment (FS/W) | 0 | Aug 19, 2012 03:46 PM |
| Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo | DPage | Aircraft - General - Radio Equipment (FS/W) | 2 | Aug 05, 2012 03:12 PM |
| Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo | DPage | Aircraft - General - Radio Equipment (FS/W) | 0 | Jul 16, 2012 04:47 AM |
| Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo | DPage | Aircraft - General - Radio Equipment (FS/W) | 0 | Jul 03, 2012 05:30 PM |
| Sold NIP Futaba FPS9402 Dual Ball Bearing High Torque High Speed Metal Gear Coreless Servo | DPage | Aircraft - General - Radio Equipment (FS/W) | 0 | Jun 18, 2012 06:12 PM |
