Old Jan 10, 2013, 11:57 AM
brettbb is offline
Find More Posts by brettbb
Joined Jan 2010
Skywalker X8 catapult
With the amount of equipment in my X8 is on the increase, so is the weight. Its becoming very difficult and somewhat dangerous to hand launch.
Iv decided to build a catapult. I dont like the idea of a bungee launcher because of the amount of flat space required. some places I fly dont have this.(eg: off a cliff =) ) I really wanted something self-contained and foldable.
a fellow RC groups member deTonaTor_NZ designed an amazing catapult for his X8. His catapult gave me the inspiration to build mine and the proof that its actually possible. See his video here
I only have basic tools at home and the whole build only required a drill, grinder, hacksaw and some hand tools.
The main beam is 50mm x 50mm aluminum 2m long.
The smaller square tube is 19mm x 19mm
The bearings are standard scateboard bearings.
I used 10mm latex tube for the bungee
The 2 loops together have a tension of 18KG and my X8 weighs 3.4KG.
brettbb is offline Find More Posts by brettbb
Old Jan 11, 2013, 10:16 AM
FireFlyer451 is offline
Find More Posts by FireFlyer451
FireFlyer451's Avatar
United States, CO, Denver
Joined Jan 2013
brettbb,
Looks like a great design. I've seen CMS video and thought the same thing. An outstanding unit/design.
Will you post more photos, and build details for others to replicate? And do you have any launch videos yet?
Thanks!
FireFlyer451 is offline Find More Posts by FireFlyer451
Old Jan 11, 2013, 12:57 PM
Pinky_d_brain is offline
Find More Posts by Pinky_d_brain
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
What are you using to move the plate?
I just had some ideas and thought I would share them see attached sketch
Pinky_d_brain is offline Find More Posts by Pinky_d_brain
Old Jan 13, 2013, 04:01 AM
brettbb is offline
Joined Jan 2010
I manged to finish my launcher over the weekend so I have uploaded the rest of the pics.
I am first going to try 2 Latex tube loops as shown in the pics. Im getting about 20 kg of pull. I think that should be enough as the motor will be running aswell. If not, Il add more loops and maybe stretch it over the front pulleys and back down down again like Pinky_d_brain's sketch.
I would have tested already but the weather is no good. Just waiting it out now... Will add videos as soon as I have them.
If you want a specific picture of something or more detail then just shout
Old Jan 13, 2013, 02:44 PM
Joined Jan 2013
brett,
Looks great, thanks for more photos. Looking forward to the videos.
Old Jan 13, 2013, 03:30 PM
brettbb is offline
Joined Jan 2010
The weather finally gave me a chance to test my catapult.
X8 catapult (1 min 45 sec)
Old Jan 13, 2013, 05:20 PM
rotccapt is offline
Find More Posts by rotccapt
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
how does your release work?
rotccapt is offline Find More Posts by rotccapt
Old Jan 14, 2013, 12:35 AM
sgrouts is offline
Find More Posts by sgrouts
Vote F5J Gracia for FPV
sgrouts's Avatar
Joined Jun 2012
http://youtu.be/asOPtRD_xgc
Perfect!
Just perfect......!
Pls get into more details.
I must make one.
Thanks for sharing
Sakis
sgrouts is offline Find More Posts by sgrouts
Old Jan 14, 2013, 02:59 PM
brettbb is offline
Joined Jan 2010
I have added more details into the first post.
See attached images of the trigger release.
I basically riveted a 12mm x 12mm aluminum square inside the rail. The12x12 tube has a 6mm bolt through it which you can see exits through a hole in the rail.
The images should be self explanatory.
Old Jan 16, 2013, 09:00 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Can I make a suggestion that you add more tension to the bungee? The first launch looked ok, but on the other ones, it looked like the plane was on the edge of stalling based on how it sank just after leaving the rail. It would only take a small drop in the wind for the plane to fully stall.
I use a similar bungee stretched to 14 meters. The launches the plane, no matter were the wind is coming from.
ashdec87 is offline Find More Posts by ashdec87
Old Jan 18, 2013, 01:24 AM
DJEncore is offline
Find More Posts by DJEncore
Joined Aug 2012
Thanks for sharing this Brett!! I had a nasty accident in August when the prop hit my hand as I was launching my X8. I cut six tendons in my right hand and almost bled to death before I got to the hospital. After two surgeries I have permanent loss of partial movement to 3 of my fingers (I can no longer make a fist or close my hand all the way). Hand launching this plane is more dangerous than people think.
Anyway, I haven't touched my X8 since but have one of my employees building a catapult from your photos & notes. Thanks so much for sharing!
DJEncore is offline Find More Posts by DJEncore
Old Jan 18, 2013, 01:57 AM
n-2-stuff is offline
Find More Posts by n-2-stuff
Scott
n-2-stuff's Avatar
Clovis,Ca.
Joined Sep 2006
Awesome. It goes to show what you can do with simple hand tools. A very clean and simple.
n-2-stuff is offline Find More Posts by n-2-stuff
Old Jan 18, 2013, 03:35 PM
Svede is online now
Find More Posts by Svede
United States, CA, Lemoore
Joined Nov 2008
Svede is online now Find More Posts by Svede
Old Jan 21, 2013, 07:51 AM
brettbb is offline
Joined Jan 2010
After watching the videos at home I also noticed how it dropped just after launch. I have since put the tension up to 22KG and it seems better. there is still alot stretch left in the bungee's though.
The tension will be different for everyone though depending on your X8 weight and power setup.
Mine weighs 3.4KG and is running on 4S at about 800W at WOT.
Sho! very sorry to hear that. Thats one of the main reasons I built the catapult. I once tried to launch the X8 myself on a windy day and its very difficult to balance the X8 on your finger tips with 13" prop spinning behind you were all it takes is a bit of a cross wind for it to go bad. Iv had guys launch it for me which is better but imagine your own X8 cutting your mates hand... not cool.
All the best with your recovery. Dont hesitate to ask questions during your build and please post pics when you are done =)
Old Jan 21, 2013, 10:25 AM
Joined Jan 2013
Brettbb,
Just a clarification question on the trigger release. Referring to your photos in #9, Is the release pin simply held in place by the tension of the pin against the launcher tray/plate? And when you push down on the extension sticking out of the end with your foot, it releases the launcher plate?
How is that foot release tube attached inside the larger, longer rail?
Thank you,
M
Discussion Best FPV Platform : Skywalker V5 vs Skywalker X8 Wing asaak FPV Talk 14 Feb 16, 2013 03:56 AM
Sold Skywalker X8 Flying Wing keithskye FPV Equipment (FS/W) 16 Sep 06, 2012 06:16 AM
Sold Skywalker X8 flying wing keithskye Aircraft - Electric - Airplanes (FS/W) 12 Sep 06, 2012 06:09 AM
Discussion skywalker x8 gravity center nocomp Flying Wings 4 Jul 29, 2012 11:51 PM
