Old Jan 29, 2013, 03:11 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Just go to the 1st page of your build thread and highlight the address at the top of the page by left-clicking it. Press "Ctrl" and the letter "C" simultaneously; that copies the page address. Then in your post, here, place the cursor where you want the link to appear and press "Ctrl" and the letter "V" simultaneously. The link will magically appear:
http://www.rcgroups.com/forums/showthread.php?t=1806149
loNslo is offline Find More Posts by loNslo
Old Jan 29, 2013, 04:04 PM
epoxyearl is online now
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Thank you-I getting so smart. I just downloaded a basic cad drawing program..
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: "Everything OLD is New...
Old Jan 30, 2013, 06:31 PM
epoxyearl's Avatar
Joined Oct 2011
The 2nd right wing
I got that stupid Monocoupe wing out the fixture today,and I'm inserting the ribs for the Xtreme symmetrical wing for tomorrow.
I drilled wing tube holes in all the ribs and made a few 1/4" lite ply ribs to fit near the root, for easy mounting. 90" tip to tip,as opposed to 105" for the Citabria.The extra holes will be used for wiring.
The plans have flaps shown for the Citabria, but no deal here.-Can't prove they had .them.
Old Jan 30, 2013, 07:33 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Are you referring to just the Xtreme?
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jan 31, 2013, 05:57 AM
epoxyearl's Avatar
Joined Oct 2011
EJWash
Yes-I'm having trouble authenticating which airplane had flaps. The Xtreme does not..
I'm not sure about Citabrias (yes?) and Decathlons,yet.
I'm not installing them.....just wondering.
Old Jan 31, 2013, 07:54 AM
epoxyearl's Avatar
Joined Oct 2011
Man- that clipped wing looks short, compared to the stock Citabria one.
The extreme wing is about 15" shorter-ain't no wonder it'll roll faster.-90", compared to 105.75"
Don't get out your measuring stick....we already discussed the discrepancies, and accepted them.
Shorter wing, larger ailerons of a different design, HOO ruh !
Old Jan 31, 2013, 10:40 AM
sgu is offline
sgu
Find More Posts by sgu
sgu
sgu's Avatar
United States, VA, Centreville
Joined Nov 2011
Hey Earl, I've flown several full size Citabs and Decathlons and none of them had flaps installed. I did however find some pics of Citabrias fitted with flaps. Couldn't find any of a Decathlon (except RC)...
Dave
sgu is offline Find More Posts by sgu
Old Jan 31, 2013, 11:45 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
The 7GCBC and the 8GCBC Citabrias had flaps. The 7KCAB and 8KCAB Decathlons did not.
I flew one 7GCBC. One of the pics sgu posted showed the "Johnson Bar" flap handle. Never needed them at the airport I operated out of - long paved runways. Never thought of using them to see the long/short performance with them.
Here's a site that will untangle all the number/letter designations:
http://www.8kcab.com/index.html
Looking at the pics (as few as there are) of the Xtreme, it looks like American Champion took a Scout, ditched the flaps, and put it on steroids. I don't see it offered on their web site, so maybe its a one-of-a-kind mod?
EJWash
Old Jan 31, 2013, 02:08 PM
epoxyearl's Avatar
Joined Oct 2011
The (second) right wing.
The prototype is going to Australia ( already sold) ...They hope to sell/produce 20-odd a year.
It's built as an advanced aerobatics trainer, suitable for preparing trainees for the next step up..
Should see a couple more directly.
I framed up the right symmetrical wing this morning, and it's an awesome devil !
I took liberties with the Aileron size, increasing both length and chord.The full size ones are hinged 29% back from the aileron leading edge....It dips into the air stream creating a "spade" effect, as the aileron is deflected upwards.
Slight deflection is not overly sensitive, but full throw lowers the leading edge to get a real "bite" of air, greatly increasing the roll rate.
I added wider sheeting at the leading edge by moving the spars back.The additional sheeting at the root makes this wing strong against twisting. It has shear webbing on both spars.Built like a 'tank' light like a 'blimp'.....
Old Feb 01, 2013, 06:41 AM
epoxyearl's Avatar
Joined Oct 2011
Thanks to the guys with "flap" input....we need to know what we're talking about,and I still put a foot in my mouth once in a while.
I've decided to Ultracote the Xtreme,as it'll probably go on the auction block after testing.
I don't want to put a lot of custom scale work into it.
Back to the aileron construction.I'm thinking brass tubing, nested,for hinges, with nylon landing gear straps as hinge blocks on each end.The brass tubing has excellent clearances eliminating any slop.
Old Feb 02, 2013, 07:17 AM
epoxyearl's Avatar
Joined Oct 2011
Rolling over
The newer aileron design on the Xtreme is a take on the original "Frise" theory, and is a serious boon to the newer roll rate.
As an aileron is deflected, the leading edge drops into the airstream and air is directed from below the wing through the aileron slot,and out the top.
Designers have been doing this for years, but not to this "Xtreme". (pun intended)
The result is 'exponential'-soft around neutral, but powerful when deflected.
Old Feb 02, 2013, 07:06 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
The ailerons came out nicely. I know you mentioned using brass tubing for the hinging, any pics of the attach points?
EJWash
Old Feb 02, 2013, 07:40 PM
epoxyearl's Avatar
Joined Oct 2011
EJWash
I'm about ready to do some pics, and ask for feed back on what I think is a novel idea.
Old Feb 02, 2013, 08:13 PM
epoxyearl's Avatar
Joined Oct 2011
Prose and 'cons'
The ailerons are hinged at 29% back on the full size, but I toned it back to 25% on the model.
The pictures will help clear up my point, where I want to use brass tubing, nested ,as hinges.
The inboard tube will be trapped in the outer housings,so as not to move.
The tip inner tube(the hinge"pin") will be screwed in place with a tab, to facilitate removal/installation.
This will either 'work' or be exciting when it departs the wing.
Ailerons will be controlled by 80oz servos, heavy duty arms, and 4-40 rods, with ball links connecting them.
With the hinge pins relocated, the ailerons are very nearly balanced....I could do, with a little lead in the LE.
Old Feb 02, 2013, 10:40 PM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
Very interesting design concept.
Discussion Bud Nosen 1/4 Scale Citabria Plans?? Keith Smith Giant Scale Airplanes 40 Dec 03, 2015 09:53 AM
Sold Bud Nosen/A&A Ind. Citabria 1/4 scale kit NIB $195shipped nero1156 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 01, 2013 07:21 AM
For Sale Bud Nosen/A&A Ind. Citabria 1/4 scale kit NIB $195shipped nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Dec 25, 2012 07:10 AM
Question Bud nosen 1/4 scale citabria mastmec Scale Fuel Planes 3 Mar 24, 2012 08:15 PM
Power options for a Bud Nosen 1/4 scale Citabria dr.E Scale Kit/Scratch Built 17 Mar 13, 2012 02:38 PM
