Old Jan 13, 2013, 11:43 AM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Bringing all your experience to the build, that kit will do just fine.
And we're her to see you don't screw it up too badly.
loNslo is offline Find More Posts by loNslo
Old Jan 13, 2013, 12:13 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Thanky...This Nosen kit is the essence of everything that can be wrong with a kit....If I survive the build, The 'Coupe will be my reward.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Jan 13, 2013, 05:57 PM
epoxyearl's Avatar
Joined Oct 2011
Some interesting things have been discovered today. While we were trying to sort out the actual scale reproduction of the 1/4 scale Nosen kit,we learned the Decathlon Xtreme has an airfoiled stabilizer..
The outer ends of it have been squared off,also.
I made some angle brackets for jigging the wings today.Lowes has some aluminum angle,1-1/2 x 1-1/2, x 1/16...and I got a 4' length to cut as upright fixtures. I cut them 1-1/2 " long,and drilled a hole in the center of one side..Aligning the upright edge against the rib marked on the plan,one screw will locate it.
A clamp will hold the rib in position for gluing.
Old Jan 13, 2013, 06:26 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Looks like they "Decathloned" the Scout. Same tail feathers.
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jan 13, 2013, 10:55 PM
sgu is offline
sgu
Find More Posts by sgu
sgu
sgu's Avatar
United States, VA, Centreville
Joined Nov 2011
Subscribed. I now have an A&A Nosen Champ kit. Probably be next winter before i tackle it but I'll enjoy watching your build.
Dave
sgu is offline Find More Posts by sgu
Old Jan 14, 2013, 06:21 AM
epoxyearl's Avatar
Joined Oct 2011
Dave
Hi Dave...Mine is the A&A kit also. I want to build the kit stock,but I wanna build the Xtreme too,so there's only one solution.....1 +1=
Old Jan 14, 2013, 06:30 AM
epoxyearl's Avatar
Joined Oct 2011
Building/storage space.
DUH ! The shop I'm building in is small,(easy to heat with baseboard heaters),and space is at a premium..A friend who restores full size Champs suggested an old chest of drawers as a building table...with drawers to store parts of a model...Now, I have wing ribs in one drawer,fuselage parts in another,stab,rudder,etc.
I elevated it about 4" for toe clearance...it's 1" thick top accepts my clamping screws well. It is severely straight and unwarped and five feet long,by 16" wide.
HOO ruh !
The parts have been removed from the "die-cut" HA! sheets,and repaired as best they can be.I didn't replace any thing (although I desperately wanted to )to try to keep this an "honest" build...Many,many of these have been built from those kits,and fly well.
I have not been 'spoiled' by the laser cut kits, but some of us appear to have been. My joy is building...if it's sometimes more difficult, then the reward is that much sweeter,when it flys.
The right wing is under construction...
Old Jan 15, 2013, 05:34 AM
epoxyearl's Avatar
Joined Oct 2011
Flap'n wings
I can't find a 3 view of the new Xtreme Decathlon, but in one photo taken at Oshkosh, it looks to have flaps.
Does anybody know fer sure?
Old Jan 15, 2013, 10:29 AM
4075aaron is offline
Find More Posts by 4075aaron
United States, MD, Frostburg
Joined Aug 2008
That is a good question...I saw one at Oshkosh and I am pretty sure that it does not have 'em.
Here is a decent picture...can't be certian but it looks like there are none:
http://www.aopa.org/oshkosh/2012/new...upersized.html
Most Decathlon's don't have flaps, right? I could be wrong about that...
4075aaron is offline Find More Posts by 4075aaron
Old Jan 15, 2013, 11:37 AM
epoxyearl's Avatar
Joined Oct 2011
One 'n only
So far, there's only one Xtreme, and I have a picture that I can't paste...It has two marks that look like flap edges,but could be access panels.
They finally put the wobbly tailwheel on Steroids, and hung 210 horsepower on the nose..
The Ailerons have been rehinged at the 29% mark,and the elevators have squared off tips. The Stabilizer area has been increased and given an airfoil not unlike the Extra wing.....A large round leading edge tapering to nothing.
Old Jan 15, 2013, 12:20 PM
sgu is offline
sgu
sgu
sgu's Avatar
Joined Nov 2011
No Flaps on this baby.
Old Jan 15, 2013, 12:48 PM
Joined Aug 2008
That's the one...I am pretty sure it has no flaps...If you wait until early August, I can confirm that for you
Actually...just found this. I can't imagine that I see flaps there:
Old Jan 15, 2013, 02:38 PM
rtibbs is offline
Find More Posts by rtibbs
rtibbetts
rtibbs's Avatar
Central Florida
Joined Mar 2008
http://www.amerchampionaircraft.com/.../NewWings.html
Check out the above website. Flaps available on the 8GCBC and optional on 7GCBC. Al others listed as NA
rtibbs is offline Find More Posts by rtibbs
Old Jan 15, 2013, 02:54 PM
epoxyearl's Avatar
Joined Oct 2011
That's the picture I can't be sure of.....I have it as wallpaper,and just at where a flap outline SHOULD be,there are two lines that COULD be.!
Although I will agree their chord would be much greater than normal.....
I'd be surprised if they did,after reducing the weight by 68 pounds..
It's odd that i'm seeing posted numbers of a 30' wingspan,30.8 .and 31.8 on the only airplane that existed at that time.....Maybe I need to curb my excitement, until some actual numbers are available.
Old Jan 15, 2013, 03:41 PM
epoxyearl's Avatar
Joined Oct 2011
SGU-thanks for the proof of no flaps....but man that wingtip looks difficult to build ! ha ha..
Discussion Bud Nosen 1/4 Scale Citabria Plans?? Keith Smith Giant Scale Airplanes 41 Jun 23, 2016 06:50 PM
Sold Bud Nosen/A&A Ind. Citabria 1/4 scale kit NIB $195shipped nero1156 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 01, 2013 07:21 AM
For Sale Bud Nosen/A&A Ind. Citabria 1/4 scale kit NIB $195shipped nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Dec 25, 2012 07:10 AM
Question Bud nosen 1/4 scale citabria mastmec Scale Fuel Planes 3 Mar 24, 2012 08:15 PM
Power options for a Bud Nosen 1/4 scale Citabria dr.E Scale Kit/Scratch Built 17 Mar 13, 2012 02:38 PM
