Old Jan 10, 2013, 01:01 AM
granooch is offline
Find More Posts by granooch
Joined Jan 2013
Help!
Hoverfly Gimbal help
Hi I am having trouble with one axis of my hoverflygimbal controller (tilt) on a Photoship one 2xpt gimbal. The controller reacts properly, but I cannot get it to stop after it reacts to movement. If I tilt the heli forward, the camera compensates backwards continuously and the same for the other direction. It also seems to be worse in one direction than the other.
Any help would be great
granooch is offline Find More Posts by granooch
Old Jan 10, 2013, 03:27 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Sounds like the Hoverfly is not located on the camera mount. What axis is it on?
Roto Rob is offline Find More Posts by Roto Rob
Old Jan 10, 2013, 03:47 PM
granooch is offline
Joined Jan 2013
The hoverfly WAS mounted on the pan axis of my gimbal. Late last night I stumbled across a thread saying it had to be mounted to the camera tray when used with 360 degree servos (slightly confusing in the actual directions) & now it works as intended.
Could someone share some basic PID settings for there pan and tilt axis's? Tilt is good but not so smooth and pan is smooth but overshoots a little and is slow.
Old Jan 10, 2013, 06:37 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Yes, you would have to use a standard servo, or an external pot on the continous rotation servo, to locate it off the camera mount. I don't have one, but it looks interesting. So hope you post on how you like it.
Old Jan 15, 2013, 03:44 PM
granooch is offline
Joined Jan 2013
I'm having a little trouble getting things to work on the bench and then in the field. I've had to redo my center points a couple of times, otherwise this thing is really cool and seems to work well. The only real issues with this are coming from me, not the design of the product.
Could someone shed some insight into what values I might play with to fix these following issues?
Pan- works the best, but under hard movement will move a little to far. I'd also like to smooth the reaction to slow movement as if I move really slow, it has a slight lag.
Tilt- Tilt is too slow in general and also has trouble keeping up under fast movement.
Lastly, with 360 servos, can I limit the angle which it moves in the pan axis?
Old Jan 15, 2013, 07:11 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Not having that controller its hard for me to help on values.
For tilt motion it is a question as to if the gimbal is physically able to rotate fast enough. If the camera is removed and the gimbal speeds up, the camera might not have its weight balanced on the center of rotation.
To limit the angle of rotation an external pot is an option.
For Sale Cinestar 8 w Mikrocopter FC & 360 Gimbal w Hoverfly Gimbal Capo Creative Aircraft - Electric - Multirotor (FS/W) 6 Oct 10, 2012 01:34 AM
Discussion Hoverfly pro and gps = hoverfly gimbal? Capy-Norway Hoverfly Technologies 25 Aug 20, 2012 11:12 AM
Discussion Does the hoverfly pro support Photohigher camera gimbals? babanan Hoverfly Technologies 12 Nov 02, 2011 01:14 AM
