Old Jan 09, 2013, 10:31 PM
Wrice4 is offline
Find More Posts by Wrice4
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
Help!
ESC Problem with Turnigy 9x
I have the Eflite 30AMp Pro SB Brushless ESC and I am having some problems with it. I have it hooked up to my pop wing and I am running a turnigy 9x with frsky module and receiver with it. I have had the esc hooked up to my t-28s and it works perfect, but when I have it hooked up to my pop wing, the end point to the throttle is way off. WHen the throttle stick is all the way down (neutral), it is showing a negative point. Meaning, when I put the throttle stick (left stick) in the center, which is usually 50% throttle, it reads the throttle is 0 %. I was told to trim the throttle all the way out and see if that would help, but its not enough. I have also went through the manual tney have online and tried to program it using mode 4, that does not work either. Is there anyway to fix this so I can fly my wing?
Wrice4 is offline Find More Posts by Wrice4
Old Jan 10, 2013, 12:04 AM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
I don't have that setup, but usually when this happens I'll rebind, then do a throttle calibration. On most ESC's it's as simple as putting throttle in highest position, then plugging the power into the esc. Once ESC goes into programming, bring throttle all the way down to the lowest point.
I do have that ESC, but not the 9x. if you can't get it to work, I'll make the effort to pull it out and test.
I did a google seach for that ESC and calibration, but came up empty. what surprises me is that, that ESC isn't cheap by any means, yet it only features a 700mA BEC...and nothing on calibration.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Jan 10, 2013, 08:20 AM
Wrice4 is offline
Wrice4's Avatar
Joined Nov 2012
I have tried doing every test that I have researched. Still nothing I dont want to fly spektrum with this because I was going to use my popwing for fpv.
Help! Turnigy 9X 9ch transmeter ( Problem with servos ) Adil95 Electric Plane Talk 21 Dec 17, 2012 11:45 AM
Help! Problem connecting servos with tx of Turnigy 9x jaimevent Radios 6 Jun 23, 2012 11:39 PM
Discussion Problems with brand new Turnigy 9X transmitter philtyphil Australia 10 Jun 14, 2012 11:55 AM
Discussion Problem with Turnigy 9x Firmware wiring bbberrey Radios 1 May 13, 2012 01:26 PM
Question Turnigy 9x problem with servo Skypodx Radios 9 Apr 03, 2011 08:58 AM
