Old Jan 09, 2013, 05:40 PM
imacswd is offline
Find More Posts by imacswd
imacswd's Avatar
Newark, Ca
Joined Jun 2005
Yellow Air A 4
I currently have a Yellow Aircraft A 4 Skyhawk that has been in my hanger for many years. I have been getting the motivation to complete this thing but instead of running a Glow Motor I would like to convert it to electric. I have the Airframe built and is almost ready to shoot color.
I like to know if anybody has converted one of these Skyhawks into Electric and how was the performance? Also did the over all weight come out lighter than the Glow version? I have a Dynamax Fan already and would like to use it if possible. If anyone can forward pics of there setup that would be a great help.
imacswd is offline Find More Posts by imacswd
Old Jan 09, 2013, 06:55 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
they convert very well. best is to use a 90mm set as you can cut the weight way down. But the dynamax will work. I am sure one of the guys that have one will check in and fill you in.
turbonut is online now Find More Posts by turbonut
Old Jan 09, 2013, 07:59 PM
imacswd is offline
imacswd's Avatar
Newark, Ca
Joined Jun 2005
I'll post some pics, thanks
Old Jan 10, 2013, 11:54 AM
imacswd is offline
imacswd's Avatar
Newark, Ca
Joined Jun 2005
Heres a pic of the project
Old Jan 10, 2013, 12:13 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice..It will make a great edf jet
Old Jan 10, 2013, 01:06 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i just finished doing some detail, and painting this one for PDAWG. this model is perfect for 90-100mm fans, in the 2700-4000w range.
corsair nut is offline Find More Posts by corsair nut
Old Jan 10, 2013, 02:30 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
This is the yellow A-4?
nice...
Looks larger
erh7771 is online now Find More Posts by erh7771
Joined Nov 2005
Did you make the table?
regards
Old Jan 10, 2013, 03:23 PM
imacswd is offline
imacswd's Avatar
Newark, Ca
Joined Jun 2005
Very Nice, your A4 looks like a YA. What type of DF/Motor combo are you going to use and do you have any pics of the inside?
Old Jan 10, 2013, 03:30 PM
imacswd is offline
imacswd's Avatar
Newark, Ca
Joined Jun 2005
I picked the Table up from a friend of mine. The table is made from two solid core doors and are clamped together. Laminated a new surface and put a glass top on it. I have built many IMAC planes on it and has served me very well. Believe or not it stay's straight even with 300 pounds of weight on the wing panels.
regards
Old Jan 10, 2013, 05:41 PM
tehachapi, CA
Joined Jan 2006
its not my A-4,.its pdawgs, i just painted it for him. its a first generation YA A-4.i believe he is going to run a jetfan 90, with a HET 700-68-1680 motor on 8s 6000mah. should be about 3kw, and the weight will be under 11 lbs, with 9 lbs of thrust
Old Jan 11, 2013, 02:11 PM
Doug Cronkhite is online now
Find More Posts by Doug Cronkhite
TimeShare
Doug Cronkhite's Avatar
United States, UT, Tooele
Joined Feb 2002
If you're using the stock inlets you're going to want to stick with the 120mm fans like the E-Turbax or Dyn-E-Max. They'll fly the hell out of that little jet on 12s. You'll have to get a little creative on battery placement inside the fuse though, but no worries. I've seen the Yellow A-4 fly at over 18 pounds and it flies VERY well.
Doug Cronkhite is online now Find More Posts by Doug Cronkhite
Old Jan 11, 2013, 03:21 PM
tehachapi, CA
Joined Jan 2006
18 lbs! good grief, i hope it had the sport wing! :O
Old Jan 11, 2013, 08:53 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
18lbs...Yikes..My biddies turbine is only 11lbs
Old Jan 11, 2013, 09:10 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Jeeez, he might be old, but I doubt he's gonna like you calling him "biddie". hahahahahaha.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Discussion 1/4 scale dogfight, air to air video, FPV camera tenacious101010 Electric Warbirds 1 Nov 15, 2012 04:59 AM
For Sale Awesome Gas Yellow Air P-40 Warhawk- LPU UncleDonsHobbies Aircraft - Fuel - Airplanes (FS/W) 3 Jul 12, 2012 01:50 AM
For Sale Yellow Air F-16, Rossi, servos, retracts: 350! morgusmax Aircraft - Electric - Jets (FS/W) 5 Jul 08, 2012 11:35 PM
Found Yellow Aircraft A-4 or Starfire marvmattporsche Aircraft - Fuel - Jets (FS/W) 3 Apr 11, 2012 04:24 PM
Sold 4 - NIB World Models Yellow Mini Midget Mustang EP - $74 each with Worldwide Shipping gabrielisrael Aircraft - Electric - Airplanes (FS/W) 2 Mar 09, 2012 11:46 AM
