Old Feb 16, 2013, 11:51 PM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
About 36 inches long ... We run them as spec scale hydros using NAMBA rules, which basically limits us to just a few motors, like the Proboat 1500 or stilleto. Since we also race counterclockwise, we have far more limited prop choices as well. The boats go about 40 give or take a bit. But it does make for pretty evenly matched and competitive races.
cyberhoops is offline Find More Posts by cyberhoops
Old Feb 17, 2013, 03:03 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
It's all looking good Cyber.
Here's a couple of pages of props with quite a few opposite hand pitch props.
Some are de tongued some are 1.8 & 1.9 pitch. Two blade & three blade.
Might broaden your choice a bit. I'm using a couple & they work pretty good.
I know they look expensive, but take out your time for not needing to sharpen, thin, & balance them & it's not so bad. Although I do sharpen the leading edge a bit more.
Free postage too. You'll find these props are very popular across Europe & Asia.
Just a thought.
http://stores.ebay.com/VXperformance...=p4634.c0.m322
Paul.
785boats is offline Find More Posts by 785boats
Old Feb 17, 2013, 06:51 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Sweet!!! Thanks for the tip Paul, I will be ordering some new prop options for sure. I just ordered the 942 2 blade and a 4418 ( 44mm 1.8 pitch) 3 blade .... and looking at a couple more. A lot of options other than the x447.
Old Feb 17, 2013, 07:59 PM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Just a note with the higher pitch props. Some hulls will require some strut adjustment to get them to work properly . They can cavitate quite severely.
I hope some of our European friends can enlighten us a bit on these props.
Steve at Off shore Electrics also sells some. Left & right hand props. Please note. Left & Right terminology is different betreen American & European Props. Totally opposite.
http://www.offshoreelectrics.com/pro...+2+Blade+Props
Cheers.
Paul.
Old Feb 17, 2013, 08:39 PM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Cyber.
With regards to your Exhaust, these guys make a heat shield but I' can't find any actual pipes.
http://www.hydroscalecreations.com/M.../MiscItems.htm
I'm sure if you contact them they will be able to offer some advice on what is commonly used.
But that Filemetal over a thin piece of plastic pipe of the right diameter sounds like a good idea.
Old Feb 18, 2013, 01:04 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Ahh. --- Hydroscale, ie Mitch Dillard, lives just a couple miles from me. I didn't realize he had a web site. I will give him a call, once I get back from my week of vacation here in Maui.
Point taken about high pitch props and cavitation, but it is worth some experimentation.
Old Feb 25, 2013, 10:16 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Turbine Exhaust
Here is the foam version of the turbine exhaust, with a couple wood bits for some strength, and to use as attachment points into the cowling.
Still going with the theory of fiberglassing, then melting out the foam.
Old Feb 26, 2013, 06:37 PM
twofford71 is offline
Find More Posts by twofford71
Joined Aug 2011
http://classicthunder.org/SetUp/TPipe.htm
would this work for you jim?
twofford71 is offline Find More Posts by twofford71
Old Feb 27, 2013, 12:41 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
That is not bad at all. I think I could make that work as well.
Old Feb 27, 2013, 01:04 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Both ideas look pretty cool. I guess 'hot' would be a better terminology since it is a turbine exhaust pipe
I take it that you will still use the Flite Metal tape over which ever one you decide on ? I really like the look of that stuff.
Old Feb 27, 2013, 10:24 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
I do still plan to cover it with Flite Metal - assuming that the sample sheet shows up someday. It has been a couple weeks now and no joy as yet. I have fiberglassed over the pink foam now. There are some little ripples in the epoxy, so I need to get those smoothed out before I dissolve out the foam.
Old Feb 28, 2013, 10:37 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Turbine Exhaust
Well, three layers of lightweight fiberglass cloth, and a bit of bondo later... we have the turbine exhaust. I sanded down the bondo layer to almost nothing, and there are places where the epoxy shows through.
At first I tried nail polish remover to remove the foam, but it didn't work all that well. After a trip to the hardware store for some acetone I was amazed at how it melted down the foam to nearly nothing. There were a couple stringy globs of pink, but it really wiped it out.
It is not all that pretty now, but black paint on the inside of the pipe, along with Flite Metal (aluminum foil) on the outside should make it look pretty good. A screw from inside the cowling into the wood plate at the front of the exhaust will hold it on the boat, and maybe one more screw up through the cowling into the wood plate on the bottom of the exhaust.
I also got the hatch retention bolt in the back of the cowling. It is just a bolt going through to a carbon fiber tab in the hull. I backed the carbon fiber tab with a 1/8" piece of plywood and inserted a blind nut into the plywood. I think that will be enough to hold down the hatch, and once it is painted yellow it will not be a significant distraction.
Old Mar 01, 2013, 05:55 AM
boaterguy is online now
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Looks nice!
Where did you get the foam?
boaterguy is online now Find More Posts by boaterguy
Old Mar 01, 2013, 09:49 AM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Looks like standard closed cell foam insulation. Home Depot sells it in 4'x8' sheets, and sometimes you can get off cuts for cheap (or free) if you ask.
wparsons is online now Find More Posts by wparsons
Old Mar 01, 2013, 09:53 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Exactly correct.
Sold 3- KK Plus Boards plus LCD & USB Programmer Price Lowered Chad2323 Aircraft - Electric - Multirotor (FS/W) 4 Mar 08, 2012 08:18 PM
For Sale NIB T-Rex 450SE V2 Combo Kit #KX015043TA Plus 3 Hitec Cyclic Servos ($310.00 Shipped) helinut4ever Aircraft - Electric - Helis (FS/W) 2 Mar 28, 2010 06:51 PM
Sold 2.3 meter T tail $125 plus shipping thenaz Aircraft - Sailplanes (FS/W) 3 Aug 29, 2006 07:56 PM
Help! X-peak 3 Plus won't charge my Ni-xx H_enke Batteries and Chargers 8 Aug 08, 2006 12:41 PM
