Old Jan 09, 2013, 03:29 PM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
Build Log
1992/3 Miss T-Plus
It is getting late in the boat building season, given that the season kicks off in March, but I am going to try to have a new 1/10th scale modern hull ready for the 2013 campaign.
The plan: The 1992/3 Miss T-Plus twin wing. Craig Bradshaw at West Coast Custom Boats is currently building up a carbon fiber and epoxy hull for the twin wing design, and Mike at Thunderboat Graphics has a decal set that I plan to use. The vac-u-formed canopy "glass" will be made by Mitch Dillard, who has molds for a variety of cowlings, canopies and inserts.
My job will be to add ride pads, cut out the cockpit area in the cowling, strap on the hardware and do the paint. The power system will be a Proboat 1500kv motor on 4s with an Turnigy 120 speed controller.
The original boat was designed by Ron Jones Jr. and Dave Villwock who ran the hull as the Coors Dry in 1992. In San Diego, Dave scored an upset victory and became the first driver since Howie Benns in 1974 to win his first-ever Unlimited race.
The T-Plus team started with the hull design in 1992, and with Steve David as the driver the boat had some success. In the Honolulu race of 1992, the team ran conservatively in the preliminary heats, but David had the speed when it counted in the finale. The result was a clear-cut victory for Miss T-Plus over Miss Budweiser in the final heat, as the boat set a world record speed of 154.025 miles per hour for the 12.5-mile distance.
With the introduction of fuel restrictions the hull was coverted to a more standard configuration in 1994 and that was pretty much the end of the two wing design in Unlimited racing, but I have always been a fan of that design.
I am still waiting for the hull to be completed somewhere in the next week or so and then it will be time to start the finishing process.
cyberhoops is offline Find More Posts by cyberhoops
Old Jan 12, 2013, 12:10 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Looks good, & a nice back story too.
Looking forward to the rest of the build.
Paul
785boats is offline Find More Posts by 785boats
Old Jan 12, 2013, 11:09 PM
JimClark is offline
Find More Posts by JimClark
JimClark's Avatar
United States, WA, Seattle
Joined Apr 2002
Craig is getting really good at building boats now that should be a great boat JIm
JimClark is offline Find More Posts by JimClark
Old Feb 07, 2013, 11:48 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
In house
I have my new T-Plus hull in my shop now, ready for me to start work on ride pads, the cockpit, hardware and paint.
Attached are some pictures. There is a horizontal wing, but I didn't put that in the photos.
There is a huge amount of space in the hull - and batteries could even fit left to right across the nose and go into the front wing and sponson area. That is one nice change from my 1/12th scale wood twin wing where there were no openings into the wing area.
The cowling is has a metal pin in the front and some magnets at the rear of the hatch. The magnets are sufficient for display purposes, but not enough to hold things down during a race, so I have a bit to do there as well.
Overall the finish is really nice and I am quite excited to get to work. First up will be doing the ride pads.
Old Feb 08, 2013, 01:27 AM
P31 is offline
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
P31 is offline Find More Posts by P31
Old Feb 09, 2013, 03:51 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Cockpit
I sketched and taped the outlines for the cockpit on the T-Plus, which might be the scariest part of this build - cutting holes in the cowling. If I get something wrong here it will be hard to fix.
I do need to leave about 10mm from the bottom of the cowling so that it gets above the fiberglass and plywood rail that runs around the bottom edge of the cowling. That will make the windows a bit shorter than what might be perfect scale, but it will be close.
Old Feb 09, 2013, 07:05 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Cutting
With a bit of cleanup to go to make the edges nice and straight....
I did stay above the plate, which eventually will be the mounting surface for the driver in some form.
Old Feb 09, 2013, 10:44 PM
P31 is offline
P31
P31
Joined Dec 2011
Very nice work.
Gary
Old Feb 10, 2013, 06:54 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Looking good cyber.
I know how you feel. I always take a big deep breath before cutting into a perfectly good fiberglass cowling or hull.Only one chance to get it right & a hundred chances of getting it wrong.
Old Feb 10, 2013, 06:37 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Ride pad #1
First ride pad - just a wedge of plywood, 2 inches wide, trimmed to fit in the slightly recessed slot built into the sponson. The sponson out of the mold has a depression of about 1/8" where it needs a ride surface. My plywood bit is about 1/4" thick so it raises the ride surface about 1/8" higher than the basic surface of the sponson, and does make for nice sharp edges which is difficult to achieve out of a mold. I did use a bit of epoxy/mico balloons filler on the front edge to make sure there were no gaps for water to get under the wood. Eventually all of the wood will be protected with a thin coat of 20min epoxy.
The ride pad slot on the opposite sponson was a tad deeper than this one, but it will use the same basic technique.
Old Feb 13, 2013, 10:48 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Hardware
I am into what is very often my least favorite part of building a boat... hardware.
It always seems you have this tiny little area tucked under around and behind every structural member of the hull where you need to reach in to get nuts on bolts. The T-Plus is no exception. I always manage to drop some nut or washer which seems to tunnel out of the universe. Due in part to the law regarding conservation of matter when the current nut leaves the universe something else returns, so I always find some other nut I lost about 2 years prior, but never the nut I need.
Anyway, I am mounting a Speedmaster strut pointed backward so that the strut is under the boat, and a Speedmaster rudder as far over to the edge of the transom as I can get it. I am using blind T-nuts for the rudder bolts, and locking nuts for the strut.
One of the hardest parts will be to position and tighten down the bolt that holds the strut to the bracket. There is just very little room to get any kind of wrench into the space, and then to turn it maybe a 1/16th of a turn.
Hence my least favorite part of building.
I did do a very crude weight and balance check, and I think the batteries are going to end up going left to right in the very nose of the boat (just under where they are in the pictures). There is plenty of room to run them out into the front wing/sponson area and that would seem to be necessary to get the CG to be just a couple inches behind the sponson. There is certainly plenty of room to move the CG aft, but not much wiggle room forward. I think the motor will go near the wood frame, ESC forward of the motor, batteries in the nose.
Old Feb 14, 2013, 04:10 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Wing braces
The T-Plus is going to cross braces from the transom to the vertical wings, and I was going to try something new for the connection on the wing. Craig Bradshaw at West Coast Custom Boats pointed out a fitting from Sails Etc, which while intended for sail boats could be a nice option for the wing.
The rumor is the hole is the perfect size for a snap linkage - so I am thinking a 4-40 rod with one end threaded snapping into the eyebolt... we shall see.
Old Feb 14, 2013, 07:38 PM
twofford71 is offline
Find More Posts by twofford71
Joined Aug 2011
wow jim , gonna have competition this year
twofford71 is offline Find More Posts by twofford71
Old Feb 15, 2013, 01:23 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Turbine Exhaust
The molded hull has a bit that looks like the exhaust, but I am working toward the "Northwest" version of the T-Plus, which has a different exhaust tube that you can see on the picture below.
This brings up the question of how to create a turbine exhaust for the boat. I am thinking I will try to create a fiberglass tube using the "lost foam" process. I considered trying to bend some metal, but I have no skills along those lines.
In theory I would carve some pink foam into the proper shape, cover it with a layer of packing tape, apply some wax, then a couple layers of fiberglass and resin. Once it is all dry you use acetone to melt the foam, pull out the tape and you have a part. I think I would incorporate a couple plywood pieces in the front and along the bottom help secure it to the hull and help provide some shape guidelines. It would seem that trying to make it smooth and round could be fairly challenging since fiberglass will show any imperfections.
The rest of the plan would be to paint the inside black and cover the outside of the exhaust with "FliteMetal", which is an adhesive backed metal foil. I ordered the 12x6" sample piece for $5, which should be enough for this project.
http://www.flitemetal.com/
If anyone has a better method I would be interested since I have never done "lost foam" molding before, so this would be a new experience.
Old Feb 16, 2013, 11:10 AM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
A 4S setup in a 1/10 boat? How big is it?
boaterguy is offline Find More Posts by boaterguy
Sold 3- KK Plus Boards plus LCD & USB Programmer Price Lowered Chad2323 Aircraft - Electric - Multirotor (FS/W) 4 Mar 08, 2012 08:18 PM
For Sale NIB T-Rex 450SE V2 Combo Kit #KX015043TA Plus 3 Hitec Cyclic Servos ($310.00 Shipped) helinut4ever Aircraft - Electric - Helis (FS/W) 2 Mar 28, 2010 06:51 PM
Sold 2.3 meter T tail $125 plus shipping thenaz Aircraft - Sailplanes (FS/W) 3 Aug 29, 2006 07:56 PM
Help! X-peak 3 Plus won't charge my Ni-xx H_enke Batteries and Chargers 8 Aug 08, 2006 12:41 PM
