Old Jan 09, 2013, 09:59 AM
RobDog is offline
Find More Posts by RobDog
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
Help!
Need KK 1.6 Tricopter (Agressive) firmware
Just need a download link. I have google'd' and searched forums for it. I can find reference to it all over, but no actual place to download.
It is in the KKMulticopterFlashTool but that one fails every time I use it as where the (Acro) version of the FW works just fine.
Any help is appreciated, or if anyone can link me to information to where I can learn how to set the PID's on a KK 5.5. Might not be able to with a USBasp, in which case I could try to use the header through a USB to seral connection.
Anyway,
Thanks for any help in a advance,
Rob
RobDog is offline Find More Posts by RobDog
Old Jan 09, 2013, 12:31 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
You'll find a version on my blog with stick centering. SS3 is the aggressive version.
To set the PID (PI), set I pot to just above zero (if you set to zero, it enters arming reverse mode) and increase P as high as you can without oscillations - set to 50% to start. Then increase I so that it maintains attitude in forward flight without pitching up but not too high that it oscillates. You can only set P for yaw.
Pots are:
Pitch = I term (pitch and roll)
Roll = P term (pitch and roll)
Yaw = P term (yaw)
Steveis is offline Find More Posts by Steveis
Old Jan 09, 2013, 06:59 PM
RobDog is offline
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
Yep. That does the trick!!!! Thank you!
Old Jan 17, 2013, 08:12 AM
RobDog is offline
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
I would like to report that this is great firmware for the group here flying tri's. Very stable around center, and omg flipping about.
Thank you again!
Rob
Help! Yaw problem with HK KK Board V2.1, KK firmware 4.7 count74 Multirotor Talk 2 Jul 18, 2014 03:37 PM
Discussion Tricopter Firmware 1.6 tarrigo Multirotor Talk 4 Jun 07, 2012 04:38 AM
Found KK board with Y-6 firmware Adidas4275 Aircraft - Electric - Multirotor (FS/W) 0 Apr 27, 2012 01:31 AM
Question Tricopter v1.6 firmware by Kaptein Kuk question Dave8888 Multirotor Talk 5 Apr 09, 2012 10:33 PM
Discussion HH mode KK tricopter firmware available? Daemon Multirotor Talk 12 Dec 04, 2011 04:42 PM
