Old Jan 09, 2013, 12:54 AM
Evercopter4 is offline
Find More Posts by Evercopter4
Closed Account
Joined Dec 2012
SPEAKING OF GEARS, anybody try helical?
The helical gears look good and claim to perform better in the advertising. Are they really better? I know, just opened another can of worms!
Stevo
Evercopter4 is offline Find More Posts by Evercopter4
Old Jan 09, 2013, 01:36 AM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Main gears?
The stock gear on my 450 pro v2 is helical, I like it. It seems to me to be a lot less noisy and mesh smoother altogether. I have a straight main gear on my exi, but the whole gear setup is align, and the mesh doesn't seem as smooth to me. Still not worth changing out to me unless I ruin my main gear, then I might switch to helical on the exi one day.
finguz is offline Find More Posts by finguz
Old Jan 09, 2013, 02:26 AM
Hajile is offline
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
In airsoft, we use them to make the gears less noisy and it supposedly does a better job transferring power from the motor. The contact point slides along the length of the tooth and you can have more than one tooth in contact at once, so it's probably stronger too. Does all that actually matter? I have no idea, i just run and shoot.
Hajile is offline Find More Posts by Hajile
Old Jan 09, 2013, 03:09 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I have helical gears in my RJX's. Can't say they are any better, since they have only had the helical gears. Can say they are quiet, smooth, and no issues so far.
Roto Rob is offline Find More Posts by Roto Rob
Old Jan 09, 2013, 03:37 AM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
there not bad but they put more torque on the motor shaft so youll want a bearing supported pinion if your using them
and setting the lash must be done carefully
Elios000 is offline Find More Posts by Elios000
Old Jan 09, 2013, 07:39 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I briefly owned a T-Rex 600 EFL/Pro with helical/slant gears and was amazed at how quiet it was compared to my other straight-cut geared helis. Not like they are loud of course but with the helical-geared heli, you could hear the motor and blade noise over the gears.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Jan 09, 2013, 08:29 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Helical Gears
Advantage Ė they are quieter. Thatís the main reason that manufacturers are putting them in new kits. It also keeps you from purchasing pinion gears from other venders.
Disadvantages:
1. From a mechanical engineering standpoint they are slightly less efficient. Thatís why some racing motorcycles and racecars have transmissions with straight cut gears.
2. They create a side loading on the ball bearings.
3. You are stuck with getting pinions from the same manufacturer.
RC Man is online now Find More Posts by RC Man
Old Jan 09, 2013, 08:44 AM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Originally Posted by RC Man View Post
Advantage – they are quieter. That’s the main reason that manufacturers are putting them in new kits. It also keeps you from purchasing pinion gears from other venders.
Disadvantages:
1. From a mechanical engineering standpoint they are slightly less efficient. That’s why some racing motorcycles and racecars have transmissions with straight cut gears.
I have slate helical gears on both 450 tarot helis. Same quality as Align. I've checked both. The pinion gears are $3 each and the main gears are 2 for 1.27 so if you want to try them, its no big expense. Totally interchangeable with Align.
I was just thinking, the new Align has 3.5mm motor shaft so with the 450mx motor you have to buy Align.
barnstorm100 is offline Find More Posts by barnstorm100
Discussion Anybody want to try this Calc ? VooDoo Child High Performance 28 Nov 18, 2012 02:19 PM
Discussion Did anybody try convert a F3J fuse into an electric one? VirTus Electric Sailplanes 2 Sep 27, 2012 11:03 AM
Discussion Anybody try one of these? - P-47 Ultra Micro 4CH 400mm (RTF) Vbluguitar Micro Ready-to-Fly 1 Mar 27, 2012 12:48 PM
For Sale Align 600L motor with 11T helical pinion and 188T helical main gear ddierking Aircraft - Electric - Power Systems (FS/W) 2 Jul 13, 2010 08:59 PM
Anybody try a geared mini-Ac16-20 on 10 cells? sukhoi26mx Parkflyers 2 Jan 21, 2003 09:40 AM
