Old Jan 08, 2013, 11:32 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Wicked Powered Tech One Neptune EDF
This is my build thread for the Tech One Neptune EDF.
My Power setup:
Setup B: For 4S lipo (about 600 watts)
Lightweight 4S setup
Wicked 4000 with standoff and EDO plug
http://donsrc.com/cart/index.php?_a=...&product_id=62
EDO type 1 fan unit
http://donsrc.com/cart/index.php?_a=...&product_id=74
Mount and Dynamic balance:
http://donsrc.com/cart/index.php?_a=...&product_id=89
Pentium 40 ESC
http://donsrc.com/cart/index.php?_a=...t&product_id=3
The lipo will be a 4S 2200
The Don is online now Find More Posts by The Don
Old Jan 08, 2013, 11:55 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The stock fan unit is a 64mm unit. The EDO Type 1 or HET 6404 fan will fit into the stock location. The stock fan also uses a mount system to hold the fan down with some small screws. If you wish to use this method, then you want the EDO Type 1 fan as is has side tabs on the outside of the housing. The HET has no such tabs. Typically I use hot melt glue to hold the fans in but some may wish to use the stock method.
The stock motor is a rather short motor and I took a few photos show how longer the Wicked motor stator and Wicked Plus stator is in comparison. The outlet measures 100% FSA which is goo doe thrust not speed so I will be installing a thrust tube. I will be using a 4S 2200 lipo and the photo shows it fits into the cockpit area easily.
More photos to come as I get started!
Don
Old Jan 13, 2013, 03:15 PM
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Trenton
Joined Jan 2004
Don-- are you using the 4000 or the 4000 Plus for this build?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Jan 13, 2013, 04:36 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I am using the regular 4000 to get a benchmark as I am not sure how "draggy" this airframe is, plus I have extra 40 amp ESCs in my spare parts bin I will post some more photos later tonight.
Don
Old Jan 13, 2013, 11:25 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Got some more work done tonight. The fan is mounted (I used hot melt glue). The ESC is soldered to the motor (I used an older Hobbywing 40 amp ESC I had in my spare parts box). I removed some foam to recess the ESC on the lower part of the fuselage and used hot melt glue to hold the ESC in.
The thrust tube is next.
Don
Old Jan 15, 2013, 06:05 AM
Mitchie's Avatar
Canada, QC, Gatineau
Joined Jan 2011
Don,
Let me know what you use for a thrust tube? I have transplanted a 70mm fan with a Cyclone Power 3300kv motor. I think I need a thrust tube as well, but this is my 1st edf and I have no idea what to use.
Mitchie is offline Find More Posts by Mitchie
Old Jan 18, 2013, 03:47 AM
Joined Sep 2012
Hi, I have decided to use the Neptune for an FPV platform. I use stock setup. Managed to fit 2 x 3s Zippy (one 1500mAh and one 2200mAh) in parallel. they feed my fpv as well. Thinking of upgrading the motor to a T2826 4800kv. Current flight times with 670g AUW circa 18 minutes.
simplyg is offline Find More Posts by simplyg
Old Jan 18, 2013, 06:37 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Since Turnigy and Cyclone Power are my competitors, I hope you can understand that I do not provide technical support for my competitors products. Therefore I will only be covering how to build this model using the motor fan combos I sell on my website.
Don
Old Jan 19, 2013, 11:16 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here are photos showing the thrust tube installation. It is an easy installation. The template is included down below in a PDF file. The template shows a centering ring. Lately I have been using a strip of foam instead of making a ring. I cut a 10" piece of 3mm EPP foam about 1/8" wide. The photos show how it is installed, this strip method is quite easy to do and is my preferred method when the gap is only about 1/8" wide. Once installed you see how well it makes the thrust tube stay circular.
Don
Old Jan 19, 2013, 11:21 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The carbon rod is a little short so to make sure you get equal amounts on each wing section you need to measure it. I found mine was centered with 4 3/8" on each side then glued it.
Old Jan 20, 2013, 11:25 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The Neptune is now finished. CG with a 4S 2200 is about 170 mm from the trailing edge. The manual shows a CG of 170-180 so I should be OK!
Old Jan 22, 2013, 04:54 AM
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Thanks for all the info and Good luck with the maiden Don!
If you enjoy slow fly cooldown passes, this plane is amazing at it. I'm stunned at the lack of tip stalling. No throttle, full up into a light wind practically sits still. About the best all-around flier I've ever seen.
I love the canopy snap magnets. Wish I could find a source for them.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jan 22, 2013, 11:54 PM
Today is a good day to fly.
networker's Avatar
United States, TX, Richardson
Joined Nov 2011
Don, your Park Pusher gave my Stryker Wicked power. I'm looking forward to a Wicked Neptune too.
networker is offline Find More Posts by networker
Old Mar 15, 2013, 03:57 PM
I crash fast
United States, CA, Vacaville
Joined Mar 2013
I might have missed it, but what did you use to make the thrust tube? also where did you place the receiver?
caprini83 is offline Find More Posts by caprini83
Old Mar 16, 2013, 02:48 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I use thin (.007") acetate sheet. I buy it by the roll at local art/craft stores. You can also use overhead transparency sheets. The receivers I use are small and are white, you can see it near the battery wires where the solder joints with red heat shrink are.
Build Log Wicked Powered 50mm Screamer EDF The Don Don's RC 88 Mar 09, 2015 05:55 PM
Discussion Any one flew this one before?ASK-21 with Jet power by Art-tech avijiang Electric Warbirds 6 Dec 29, 2012 12:28 AM
Sold Receiver Ready Wicked powered SR-71 twin EDF LPU in Ohio or at Toledo show The Don Aircraft - Electric - Jets (FS/W) 2 Apr 07, 2012 06:23 PM
Sold Dons Wicked EDF 4800KV 55mm EDF unit hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Mar 01, 2012 06:28 PM
Sold Art Tech Jet Tiger airframe kit with Wicked EDF motor The Don Aircraft - Electric - Jets (FS/W) 2 Oct 19, 2010 08:14 PM
