Old Jan 08, 2013, 08:59 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Silly question, but some may want to now...
What's the difference between a "Nurflügel" and a "Flying Wing"? I ask because we have a seperate forum for each.
Since the Nurflügel forum isn't all written in German (or only about German aircraft) it can't be that simple.
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jan 08, 2013, 09:23 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Northrop trademarked the name "flying wing" in 1929. The 1929 "Flying Wing" wasn't tailless in any sense of the term but it did have a thick wing that contained the engine and crew. Apparently this plane's wing was designed to fly without auxiliary surfaces but Northrop attached them just in case it didn't work. To this day most airplanes called flying wings have some vertical surfaces, often quite large vertical surfaces, but never a horizontal stabilizer.
On the other hand most people who use the word "Nurflügel" tend to minimize verticals if not avoid them altogether. It's a much more interesting technical challenge
--Norm
nmasters is offline Find More Posts by nmasters
Old Jan 09, 2013, 02:06 AM
Jon Snow is offline
Find More Posts by Jon Snow
You know nothing....
Jon Snow's Avatar
Joined Sep 2011
--Norm
Thats about it.I believe the word translates as "wing only"
Stuart
Jon Snow is offline Find More Posts by Jon Snow
Old Jan 09, 2013, 02:49 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Stuart
It does:
"nur" = only
"Flügel" = wing
... I'd never thought about that distinction before ...
perttime is offline Find More Posts by perttime
Old Jan 09, 2013, 10:35 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
I don't know if it's really technically correct because we do have wings in the flying wing forum without vertical surfaces (Assasin) and we do have wings in the Nurflugel forum with fairly large vertical surfaces.
The primary difference I see is the high aspect ratio wings which are typical here and low aspect ratio wings which are typical in the flying wing forum.
I guess one reason a separate flying wing forum was needed was because the builds of typical Nurflugels (the majority of which are balsa) could not be posted in the flying wing forum because it's under the foamies, electric category. Previously balsa wing builds were posted all over the place on RCG and you had to look hard to find them.
I'm not sure I speak for the majority or if it's only my feeling but when I voted for the creation of this forum it was because the flying wing forum is swamped with all the Zagis, Assasins, Widowmakers etc - short, stout, fast wings and any posting about high performance gliders or pure Hortens or other historical scale wings like the Dunne quickly sinks to page 3 within 24 hours. I wanted a forum about flying wings that wasn't all pusher jets.
slebetman is offline Find More Posts by slebetman
Old Jan 09, 2013, 10:58 AM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
That sums things up.When I first came on rcgroups my main interest was stuff on the Luft46 site,particularly the Hortens and other flying wings.I too got tired looking everywhere for Horten and other high ar stuff.
Old Jan 09, 2013, 12:09 PM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
Slebetman, pretty much nails it.
Nurflügel is just the german term for flying wing, so the distinction between both forums is not obvious by names.
In rcg the term flying wing has been used predominantly for the stubby chevron type epp models with electric drive.
In the german forum www.rc-network.de there has been a quite busy nurflügel section for years now, where the above mentioned electric epp models are appropriate, but actually get rarely discussed.
The focus is more on higher aspect ratio, performance, elaborate design, aero science related to all kinds of tailless aircraft.
A number of people on rgc sought a place for just that sort of stuff, that would get buried in heaps of epp in the (electric) flying wing section on this board.
And that's why this section got created.
I'm not a big fan of the forum description, though:
"For Horten style aircraft, be it powered or glider. Typically Flying Wings without rudders."
We had that discussion at length, already.
I guess the rcg administration does not want monthly changes to forum descriptions for obvious reasons.
So it is ok, as it is, but may be a bit misleading, in ecxessively narrowing down the scope.
For me Nurflügel includes planks, swept with or without winglets, c-wings, bwb, deltas, etc.
Regardless of construction techniques and whether powered or not.
biber
biber is offline Find More Posts by biber
Old Jan 11, 2013, 10:45 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
biber
I agree 100%. Although those are my words, I was misinformed at the time.
A new description of "Flying Wings of all kinds" would be my proposal. I would like to see it changed. Changed to anything than what it is now.
I'm sure a description change is possible. The Admin. of RCG has been very supportive of any request that I have made. I'm sure that they would be delighted to spend 2 minutes and change the description. At the very worst case, in order to be fair, it may require another proposal and 50 votes to get changed.
I'll support anyone who steps forward to fix this. It's free. All you'll have to do is send an email to them from the contacts page.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Jan 11, 2013, 11:08 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
Unless you want to combine the current Nurflügel and Flying Wings forums, you might want to come up with something that differentiates this one from the other one:
Flying Wings
Discussion of RC flying wings and other tail-less RC aircraft.
What about:
Nurflügel
High aspect ratio flying wings
Old Jan 11, 2013, 11:21 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
As biber mentioned, there is a fairly lengthy discussion of this topic elsewhere, but I would not think that we'll be overrun with Zagi's if it were to be labeled with the very general all inclusive "Flying Wings of all kinds". My complaint about the other flying wing forums that exist on RCG is that they are too specialized. For example, the Flying Wing forum is a sub-forum in the Airplace-Electric forum.......so that cuts me out.....I fly gliders.
So far we have encouraged all types of flying wings and still no Zagi's.....they already have a forum and they seem quite happy there.
Kent
Old Jan 11, 2013, 11:24 AM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Since the other forum's description is "Discussion of RC flying wings and other tail-less RC aircraft" how would that description differentiate this forum from the other flying wing forum? This ambivalence concerning purpose is why I didn't vote for it in the first place. It has drawn off most of the interesting projects but that's not what you said was your intent. The older forum is now practically devoid of real airplanes that fly on the wing. There are still a few designers of dynamic lifting airplanes using the other forum but for the most part it's big motors with fins. This is where the tailless fans with an interest in actually flying hang out
Old Jan 11, 2013, 11:25 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
A very general description may be fine for someone who --- already knows what is what (and doesn't need to read the description). Something with a bit more information might be useful for a newcomer.
Old Jan 11, 2013, 11:37 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
We double posted Norm. But just to be clear, the Nurflúgel forum includes all flying wings and all other flying wing forums that currently exist on RCG are sub-sets of Nurflügel forum. Some may electric, other combat wings.
The value of such a Nurflügel forum for posters and lurkers a like is the freedom and diversity it allows.....(can you tell that I live in California? )
Kent
Old Jan 11, 2013, 11:41 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
If it's not broken - why try to fix it?
From my rather limited point of view it seems to be working pretty well with Kent's somewhat arcane title. If anything, perhaps a minor adjustment to the sub-title would be in order, but anyone who is interested enough to view the threads should get a good feel for the range and diversity of the posts. IMHO of course
HerkS is offline Find More Posts by HerkS
Old Jan 11, 2013, 12:27 PM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
I'm with Herks on this one.I can see Norms point,but the problem I had when I first joined was that,as Slebetman says,any wings that I found interesting were quickly absorbed by a mass of zagi types.Or were scattered through other forums.This still happens of course and always will.As time goes on the forum will get more understood for what it is.
I still visit the"other place"daily,and try to point what I think would be relevant in this direction.
Question I have a tail mold, now some questions GaryO Composites Fabrication 33 Jan 31, 2013 08:04 PM
Discussion Maybe silly but I have to ask! abieex Power Systems 4 Feb 24, 2012 01:03 PM
Discussion The FPV thread got me REALLY wanting a RC truck! But I have some questions wolfcopter Off-road Cars 6 Feb 03, 2010 08:53 PM
Discussion A question that - for many reasons - may be a little silly. Sensiblenick Slope 59 Feb 19, 2008 05:47 PM
Silly question but..... FX1SUB Power Systems 3 Aug 11, 2002 01:00 PM
