Old Jan 08, 2013, 07:26 PM
Helno is online now
Find More Posts by Helno
Canada, ON, Kincardine
Joined Feb 2009
Folding Hquad build
I flew my tricopter quite a bit this summer and decided it is time for a larger more capable machine.
The Hquad seems pretty popular lately so figured that is the way to go.
Current power system is as follows.
RCtimer 2830-14 750kv motors (might replace these with sunnysky 3508's if I need more power)
APC 12x3.8 slowfly props.
Hobbywing quattro ESC
Turnigy 3600 mAh 3s battery
KK2.0 control board
Here is the cad file showing the front/back ends with arm pivots.
I started cutting yesterday and after much finishing and counter boring I have the beginnings of a multirotor.
The frame so far weighs less than I figured (800g)
Starts to get heavy once everything is loaded on top.
Slots of the bottom are for battery straps.
Basic construction is 1/16" G10 plate flush riveted to 1/2"x1/2"x0.058" aluminum tubing. I am debating weather to have the top plate screwed on rather than riveted to avoid lots of drilling when I inevitably need to get access to the innards.
Helno is online now Find More Posts by Helno
Old Jan 08, 2013, 10:02 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
i dont think i can see the pics because they are linked from RCcanada
sirbow2 is offline Find More Posts by sirbow2
Old Jan 09, 2013, 06:50 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Pics are also invisible on RCCanada: http://www.rccanada.ca/rccforum/showthread.php?t=191526
Mortimer is offline Find More Posts by Mortimer
Old Jan 09, 2013, 07:43 PM
Helno is online now
Joined Feb 2009
Something messed up with rccanada's auto image inking thing and I copied the body of the post not realizing it.
Old Jan 10, 2013, 06:49 AM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Yes, and I think it will continue
quadH is easy to build, cheap, great for video, FPV and many place onboard.
Nice one, well done.
eyesonsky is offline Find More Posts by eyesonsky
Old Jan 10, 2013, 07:47 PM
Helno is online now
Joined Feb 2009
Had to find some 3/32 rivets for the Dzus springs.
Video will be here once it is done uploading. They are a bit tough to turn one handed.
Quarter turn release camera mount (0 min 0 sec)
Old Jan 14, 2013, 07:40 AM
BrownOut is offline
Find More Posts by BrownOut
Chasing dreams not d competion
uk
Joined Feb 2009
What is the fuel tubing for?
BrownOut is offline Find More Posts by BrownOut
Old Jan 14, 2013, 08:40 AM
Helno is online now
Joined Feb 2009
Super simple gimbal. http://www.rcgroups.com/forums/showthread.php?t=1793759
The fuel tubing provides a flexible link to the servos and damps vibrations.
Old Jan 14, 2013, 02:02 PM
hcker2000 is offline
Find More Posts by hcker2000
United States, OH, Columbus
Joined Sep 2012
Hey let me know how you get along with those rctimer motors I have the 2836's and plan on running 12x4.5 props on them.
Also where are you getting your stuff cut?
hcker2000 is offline Find More Posts by hcker2000
Old Jan 14, 2013, 08:07 PM
Helno is online now
Joined Feb 2009
I run the 850 kv motors with apc 12x3.8s on a tricopter without overheating. I figure the 750s should work well since the quad will run at a higher average load.
I cut the parts out myself on a Phlatprinter 3. It is pretty light duty so it is not perfect for hard materials like this but it does a pretty good job for the price.
I started to assemble the folding arms and might just install fixed arms if I have to much trouble getting things as solid as I want.
Old Jan 15, 2013, 07:26 AM
BrownOut is offline
uk
Joined Feb 2009
Thanks for your reply and the link
Old Jan 15, 2013, 08:46 PM
macca05 is offline
Find More Posts by macca05
Australia, WA, Yangebup
Joined Sep 2012
Hey mate,
Awesome looking build so far. I too am building a h quad. The design is just from the flight test boys
I am really surprised that your frame weight is nearly 800g. I was worried that my frame was 460g when the flight test frame was only 280g
Have u done anymore. Would love to see how your gimbal works as this is something I was looking at doing once I have it all done.
Macca
macca05 is offline Find More Posts by macca05
Old Jan 15, 2013, 09:04 PM
Helno is online now
Joined Feb 2009
My frame is quite heavy because it is very large. It is meant for 12" props and is 18" motor to motor. I could drastically cut down on the weight by using thinner material but I have to work with what I have.
Old Jan 15, 2013, 10:10 PM
macca05 is offline
Joined Sep 2012
Yeh my frame is 18 inches motor to motor each way and is designed for the 11 inch props but could handle 12.
It's no problem, just makes me feel a bit better as I built one frame with 5mm ply and frame only was 530 grams which I thought was way too heavy so I built another frame with 3mm ply and it only dropped the weight to 460grams. As I will be having fpv gear, the gopro 3 in housing, a 3s 4000 battery Im sure I'm at about 1.6 -1.8 kg. should be good as I am using the dt750's rated at 1000g of thrust on a 4s. That should still put me at about 50% throttle for hover.
Sorry to write so much. Back to your quad. I wish I could afford one of those cnc machines you have. I don't think I would ever leave my shed.
Old Jan 15, 2013, 10:47 PM
BrownOut is offline
uk
Joined Feb 2009
Originally Posted by macca05 View Post
......... a 3s 4000 battery ........ I am using the dt750's rated at 1000g of thrust on a 4s.
Are you carrying two batts or was this a typo?
My quad is also simular dimensions and i was planning on the dt750's as well but i can not get the quadcalc to like any of my choices.
I was planning on getting the quad to a finished state minus the motor's and battery then asking help here for the best choice once i have an exact weight and size.
So i am glad you both (Helno , Macca05) also have simular sizes with simular spec equipment.
What flight times are you both estimating?
2 Pairs of TGS 10x6 Folding Props for 9x6 folding prop Koo Non R/C Items (FS/W) 0 Nov 10, 2012 03:03 PM
Sold 13x6 and 13x9 Folding Props with 40mm Folding Spinner boredom.is.me Aircraft - General - Miscellaneous (FS/W) 0 Oct 07, 2012 08:29 PM
Discussion 600mm Folding Hexacopter Build Xnaron Multirotor Talk 0 Sep 01, 2012 12:03 PM
Building up a Fan Fold Wing. JasonJ Foamies (Kits) 49 May 18, 2008 02:52 PM
I bought some fan-fold foam . . . what to build? emoone Foamies (Kits) 2473 Jul 11, 2003 04:48 PM
