Old Jan 08, 2013, 05:06 PM
unialfred is offline
Find More Posts by unialfred
unialfred's Avatar
United Kingdom, England, Milton Keynes
Joined Oct 2009
Mini-HowTo
Multirotor parachute tutorial
So a little while ago I created a parachute recovery system for my Quadcopter. It works so well that I've decided to make a quick tutorial on how to make one, It really is very simple.
Here's the tutorial:
Quadcopter parachute release tutorial (6 min 28 sec)
And here's it in action:
Enjoy
unialfred is offline Find More Posts by unialfred
Old Jan 08, 2013, 07:32 PM
e.Man is offline
Find More Posts by e.Man
Joined Dec 2009
very cool unialfred!
if i may make a suggestion, you might want to look at chutes with less shroud lines...
http://www.the-rocketman.com/chutes.html
more expensive, granted, but think about the equipment you're protecting
trust me, there's nothing more exciting than to see your chute deploy in a big knot and watch thousands of dollars worth of hardware falling to earth at terminal velocity
i used to use those chutes for UAV helicopters and they worked well - less shroud lines = less chance of entanglement
also, i'd think about rubber-banding your shroud lines together so they don't become tangled in the container from normal use/vibration before you deploy
this was my first test with a chute something like yours - later i changed to the rocketman chutes because of deployment failures and refined the system...
parachute recovery system - RC helicopter - heli view (0 min 41 sec)
parachute recovery system - rc helicopter - ground view (0 min 39 sec)
e.Man is offline Find More Posts by e.Man
Old Jan 09, 2013, 12:22 AM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
look at this
vhttp://www.marsparachutes.com/
kelloggair is offline Find More Posts by kelloggair
Old Jan 09, 2013, 12:48 AM
e.Man is offline
Joined Dec 2009
pretty cool - nice and professional looking anyway
unfortunately, after you get done mounting that i don't think you'd have room to mount anything worth protecting doesn't look too light
what is very interesting to me though is how fast that chute is inflating - i could never do that using the packing method they are
Old Jan 09, 2013, 02:40 AM
unialfred's Avatar
Joined Oct 2009
Originally Posted by kelloggair View Post
look at this
You might also want to look at the price tag :P $499, no thanks. I'll stick with my <$10 parachute system which works just fine
With eight lines it works just fine, Haven't had a single line tangle yet or mallfunction. I've even tested opening it while at different angles and fully inverted, It still opens just fine. The size is the only problem I have ,It weighs a little over 150 grams so isn't really much extra weight, especially if you were putting it on a hexa or something. I think If I had a smaller tupperware container I would be able to pack the parachute down smaller but then you run the risk of the chute getting wedged.
Old Jan 09, 2013, 07:24 AM
e.Man is offline
Joined Dec 2009
you could use phenolic or carbon tubing - both are light and readily available from the rocketry industry. this would allow you to pack the chute much tighter into a smaller space
the problem then becomes deployment - you could use a spring like they did (heavy), or a small explosive charge (FF black powder) and an electric match - that is what i did in the heli recovery test video. all this is very inexpensive. also take a look at different materials maybe and see if what you're using is the thinnest and lightest
i didn't realize their systems cost $500 clams - that is insane - you could build a replica for probably less than $50 using all off-the-shelf parts and probably less using the material you're using
Old Jan 09, 2013, 11:44 AM
Hamanu is online now
Find More Posts by Hamanu
Hamanu's Avatar
United States, MI
Joined Nov 2003
I have to agree $500 is a bit high for that system
Hamanu is online now Find More Posts by Hamanu
Old Feb 19, 2013, 02:12 PM
HuttonIt is offline
Find More Posts by HuttonIt
CrashMaster
HuttonIt's Avatar
United Kingdom, Brentwood
Joined Dec 2012
For that price I would expect a fanfare and some fireworks on deployment and a waiting group of firemen to catch my copter should disaster strike.... I like the $10 version.
HuttonIt is offline Find More Posts by HuttonIt
Old Sep 30, 2014, 02:19 AM
AhLee is offline
Find More Posts by AhLee
Joined Jul 2014
Very nicely done mate!! For a 10bucks!!
AhLee is offline Find More Posts by AhLee
Discussion Wamsy's 3D Tutorial Thread wamsy55 3D Flying 1140 Mar 29, 2016 01:33 PM
Discussion Test-Safety parachute for multirotors Brandoonn Multirotor Electronics 6 Mar 26, 2014 05:50 PM
Poll Douglas Skyraider Video Tutorial for a "drawing and tutorial disk" Harpye Foamies (Scratchbuilt) 52 Sep 05, 2012 12:13 PM
For Sale Sea Breeze Parachute 120" Parachute (w/ pics and video) $150 polar8 Aircraft - General - Miscellaneous (FS/W) 7 Mar 14, 2012 09:36 AM
