Old Jan 08, 2013, 04:36 PM
Transplant92 is offline
Find More Posts by Transplant92
Transplant in 1996
United States, NE, Scribner
Joined Aug 2011
Help!
field box plans
I have looked all over the internet looking for downloadable field box plans. PLEASE someone tell me where to go (site) or I could buy your plans.
Let me know what you have.
Transplant92 is offline Find More Posts by Transplant92
Old Jan 08, 2013, 09:07 PM
whiskykid is online now
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
http://www.bing.com/images/search?q=...ans&FORM=IGRE#
BING it'sa wonderfull thing!
whiskykid is online now Find More Posts by whiskykid
Old Jan 08, 2013, 11:13 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Because It;s Not Google
Thermalin is offline Find More Posts by Thermalin
Old Jan 12, 2013, 09:51 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
If you want something a little different, Walmart sells these rolling tool boxes from Stanley. A bunch of guys at my field have modified them into field boxes and they work great!
http://www.walmart.com/ip/Stanley-Mo...enter/14146142
Hemikiller is offline Find More Posts by Hemikiller
Old Jan 12, 2013, 06:59 PM
Transplant in 1996
Joined Aug 2011
Thanks Hemikiller, I will go down tomorrow and check them out.
Old Jan 15, 2013, 02:21 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
get all the gear that you want in your box. stack it as if going into a box. nod as that for dimensions. assuming you have got a decent set if chisels, a vice, mallet, tennon saw and some imagination you can build a box. i knocked mine up in a couple of spare manual arts lessons a couple of years ago. still going strong
scrub monkey is offline Find More Posts by scrub monkey
Old Jan 15, 2013, 07:42 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I searched 'rc field box plans' and this is what I got.
https://www.google.com/search?q=rc+f...w=1420&bih=861
Edwin
edwin1 is offline Find More Posts by edwin1
Old Nov 20, 2013, 07:05 PM
artbykenb is offline
Find More Posts by artbykenb
Dumasarock
United States, AR, Avoca
Joined Sep 2012
Be careful of the Stanley tool box at http://www.walmart.com/ip/Stanley-Mo...enter/14146142. It tends to fall over if the bottom is not weighted HEAVILY. I tried to use one around the house and I gave it away after multiple tip-overs.
artbykenb is offline Find More Posts by artbykenb
Old Nov 20, 2013, 10:41 PM
ken78cvx20 is offline
Find More Posts by ken78cvx20
ken78cvx20's Avatar
United States, CA, Sacramento
Joined Mar 2011
I had the hobbico ultra-Tote field box I liked it fun to build and paint it how ya like. This time around I went with something lighter the Plano Tote More.
But you did ask for a set of plans when I was looking for plans I liked this one.
Ken
ken78cvx20 is offline Find More Posts by ken78cvx20
Old Nov 23, 2013, 02:16 PM
cfircav8r is online now
Find More Posts by cfircav8r
You can't take the sky from me
cfircav8r's Avatar
United States, IA, Hampton
Joined May 2012
12 volt battery and two jugs of glow fuel in the base and its not going anywhere. I put a power panel and fuel pump on the side and fed the fuel lines through the side. You don't even have to open the front if you put a selector for the different fuel jugs. Nice and clean and holds everything I could possibly need.
cfircav8r is online now Find More Posts by cfircav8r
Old Nov 24, 2013, 03:13 PM
ddemu is offline
Find More Posts by ddemu
United States, ID, Shelley
Joined Dec 2011
I still use a wood box I custom built as a kid, keep thinking of building a new one to replace/improve on it, but then keep looking at the Stanley box as mentioned above as a bigger/better replacement WITH WHEELS.
ddemu is offline Find More Posts by ddemu
Old Nov 27, 2013, 04:08 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Here was my simple one for about 15yrs ... back in 80's ...
The panel was set through one face ... the fuel can in one section .. gear in another ... handle was wardrobe metal clothes rail cut short ... most of models could sit in the U tops of the ends ...
Here's another one I had ...
Centre section had the fuel can and motorbike battery ... ends had 1/2 height open tool trays added ... this was 90's
Earlier this year ... I got some plywood ... knocked up a rectangle box ... about 50cms long, 25cms wide and 15cms height. The box was then divided into 3 sections by two high cross bulkheads about 40cms high.... giving a large centre section for fuel can and battery (7A/Hr SLA) .... and ends enough to put starter and tools in. The panel was screwed to the face of the upper part of one high bulkhead. Fuel pump just under it and pipes led through the ply.
Nothing fancy ... and a bit of dowel through as a handle.
Didn't even need a plan ...
Nigel
solentlife is offline Find More Posts by solentlife
Old Nov 27, 2013, 05:51 PM
Transplanted1996 is offline
Find More Posts by Transplanted1996
United States, NE, Hooper
Joined Oct 2013
sounds good nigel, maybe I will give it a chance!
Transplanted1996 is offline Find More Posts by Transplanted1996
Old Nov 27, 2013, 06:39 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Don't overlook coroplast!
Hi,
Couple of tips here from a guy who likes to help out newbies.
Used equipment is often a headache EXCEPT stuff like field boxes IMHO
So look on the for sale sections hewr on RCGroups and ebay cuz often this kind of stuff goes very cheap.
Also don't overlook coroplast. it is a bit heavy for some airplanes but is PERFECT for equipment. Smaller signs that are to small for airplanes are great for boxes and free too.
Google search for em and you find this kind of stuff http://www.rcuniverse.com/forum/s-p-...field-box.html
ozmo01 is offline Find More Posts by ozmo01
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Spadtothebone.com
Question Plans for field boxes crtaylor Fuel Plane Talk 3 Aug 22, 2009 10:01 PM
Question Field Box plans? Arbo Fuel Plane Talk 2 Dec 28, 2005 07:28 PM
Field box plans Valid8r The Builders Workshop 1 Nov 21, 2004 12:10 AM
