Old Jan 08, 2013, 02:57 PM
tyoung560 is offline
Find More Posts by tyoung560
Joined Dec 2011
Help!
How to remove prop shaft - Mini Vapor
I did a killer nose dive with my mini vapor into the hardwood floor and snapped the prop shaft just after the drive gear. How do I remove the prop shaft from the gearbox assembly? It looks like there's a small plastic nut on the backside of the prop shaft but unscrewing it isn't helping me.
tyoung560 is offline Find More Posts by tyoung560
Old Jan 08, 2013, 03:13 PM
Mattfly is offline
Find More Posts by Mattfly
Mattfly's Avatar
Champaign. Illinois
Joined Jun 2003
The nut on the backside of the gearbox is reverse thread. Try unscrewing the nut the other direction to remove it.
Hope that helps.
Matt Andren
Parkzone/Hobbyzone
Horizon Hobby
Mattfly is offline Find More Posts by Mattfly
Site Sponsor
Old Feb 06, 2013, 08:51 PM
canderson88 is offline
Find More Posts by canderson88
Joined Dec 2003
I did the same thing. I got the shaft off but gear wont come off shaft now. Is it CA'd on the shaft? How do i pull it?
canderson88 is offline Find More Posts by canderson88
Old Feb 07, 2013, 09:04 AM
Steve 0 is offline
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
Me, three! Prop shaft and extra props arrive Friday.
Steve 0 is offline Find More Posts by Steve 0
Old Feb 07, 2013, 09:46 AM
ronaldj is offline
Find More Posts by ronaldj
Winter - Tavares, Florida
Canada, ON, Ottawa
Joined Jan 2012
I replaced mine a few weeks ago. I was surprised that the gear didn't come already on the shaft as it does with the night vapor.
I ended up supporting the gear on two sides and pressing the shaft out. It was the same process to press the new shaft onto the gear. Care must be taken to push straight, because the shaft could bend easily if pressed on an angle. I don't think there should be any ca, the shaft is knurled to hold the gear.
ronaldj is offline Find More Posts by ronaldj
Old Feb 08, 2013, 10:24 AM
Joined Dec 2003
Thanks. I'll try that.
Old Feb 10, 2013, 12:50 AM
Steve 0 is offline
Slope-a-Dope
Steve 0's Avatar
Joined Dec 2012
Changed mine out today. I used a dremel collet that fit close to the shaft diameter, slipped it over the long end and then pushed down . Not much force and it slid right off. E Z greasy! Back to flying . No more inverted flights for me ...at least not the intentional ones that caused my failure.
Discussion How to remove prop and prop adapter without damaging motor shaft & props? jaybad Power Systems 12 Jul 31, 2015 04:53 PM
Discussion How to remove motor shaft on the RC Timer 1300kv's signal15 Multirotor Talk 1 Jul 23, 2012 12:15 AM
Discussion i ca glued the prop shaft and motor shaft to the coupler ? How to remove coupler ? mortonj69 Dock Talk 26 Feb 22, 2010 07:47 PM
Question How to remove the WD4 prop w/out pulling shaft? catman529 Electric Plane Talk 13 Jan 04, 2008 07:03 PM
How do remove the GWS prop shafts Leafy GWS (Grand Wing Servo) 2 Sep 28, 2004 07:47 PM
