Old Jan 08, 2013, 01:52 PM
J. Wydronek is offline
Find More Posts by J. Wydronek
J. Wydronek's Avatar
United States, AZ, Buckeye
Joined Mar 2010
Build Service
I have decided to offer build service for people. I offer a very affordable price for a great build.
all planes are built to customer specs. If you would like more info please contact me @ iconflyer@gmail.com
Joe
Here is what one customer has already said.
I own the Orange Xplorer4 that Joe has pictured in the above post. I was refered to Joe though a mutual flying friend. Joe did charge me a fair and modest price for the build but he did it more as of a favor to a new limited experience builder. The build was completed in a day and a half and he even programed my radio too. The test flights were spot on with only a few trim adjustments and the Xplorer is great. It cg's at 119 with no lead. His build was neat clean and mechanicaly simple. I would recomend his service. I used all MKS servos and a JR 921rx. Battery is a AA 4cell eneloops sold by Soaring USA. Brad
J. Wydronek is offline Find More Posts by J. Wydronek
Old Jan 08, 2013, 01:53 PM
Joined Mar 2010
Here are some more photos..
Old Jan 09, 2013, 12:13 PM
Joined Mar 2010
Special Pricing from now until the Southwest Classic $150 for a standard molded build $170 for an electric build. This price will be honored until after the Classic. If you get your name on the list now and pre order a build for after the classic you will get the same price.
Joe
Old Jan 09, 2013, 12:27 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Hi Joe, just a hint to get a stiffer setup you can do as pictured below and tie at least one end of the wing skins together and/or even the spar. A side benefit is not having to use the thrid screw so you can have one of the tabs under the wing skin making easier access.
http://www.rcgroups.com/forums/showp...postcount=5399
fnnwizard is offline Find More Posts by fnnwizard
Old Jan 09, 2013, 09:36 PM
Joined Mar 2010
That looks like a great suggestion.
joe
Old Jan 09, 2013, 10:16 PM
Francesco is offline
Find More Posts by Francesco
Francesco's Avatar
United States, CA, Mountain View
Joined Apr 2001
An even more effective way to tie the servo and the skins together, has better leverage and reduces both slop and risk of flutter. Can be done with a pre-cured carbon strip or plywood. Credit goes to Joe Wurts:
The main disadvantage is that if you need to remove the servo, you need to break the bond between the skin and the carbon/plywood, which is why the best way to glue it is with a few small drops of CA.
Francesco is offline Find More Posts by Francesco
Old Jan 10, 2013, 02:30 AM
cianokol is offline
Find More Posts by cianokol
Joined Mar 2007
where must be glued carbon/plywood plate with CA?
only "a" or "b" too?
thx
cianokol is offline Find More Posts by cianokol
Old Jan 10, 2013, 02:37 AM
Francesco's Avatar
Joined Apr 2001
It needs to be glued to both the wing skin and the servo, otherwise its purpose is defeated.
Old Feb 05, 2013, 10:57 AM
Joined Mar 2010
Guys thanks for that bit of info.
Here are pictures of a project i just finished its an electric Orion for SUSA
Old Mar 28, 2013, 01:03 AM
Joined Mar 2010
Ok even though this is not a glider it is my most recent build. Am also working on a 3.5 xplorer
For Sale Custom R/C Airplane Building Service radioCtlAddict Aircraft - Fuel - Airplanes (FS/W) 8 Nov 12, 2012 07:43 AM
Data LASER Cutting/Build Services and Aircraft Plans Vendors List Murocflyer Balsa Builders 6 Oct 18, 2012 12:48 PM
Cool DreamFactory Custom Build service Sale 10% off! Keenan smith Other Websites 0 Jul 13, 2012 03:13 PM
Question building service for a craft golden eagle xrx1113 Sailplane Talk 0 May 04, 2012 12:18 PM
Discussion Building service from Kennedy Composites? nph Hand Launch 6 May 03, 2012 04:14 PM
