Old Jan 08, 2013, 02:51 PM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Line off the exhaust - what's it for?
One of the first things I noticed when I removed the cowl on my SBach was this line connected to the exhaust - it disappears into the fuse near the canister.
Not sure what this is for - could it be smoke? Any insight is welcome!
Judging by the direction of the arrow on the fitting I figure whatever it is feeds into the exhaust.
grosbeak is offline Find More Posts by grosbeak
Old Jan 08, 2013, 03:00 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
I would assume it's a smoke line... is there a smoke tank on the other end?
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jan 08, 2013, 03:21 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Two lines fuel systems have one line from the fuel tank to the carburetor and a second line from the exhaust going to the fuel tank to provide tank pressue to push the fuel to the carburetor via the other line.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jan 08, 2013, 03:25 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Zor
That would make sense for glow, but with gas the engine draws the fuel and the tank is not pressurized.
Old Jan 08, 2013, 03:26 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Not that I've seen - I'm going to have to get a closer look inside that canister tunnel - that's where the line goes.
Old Jan 08, 2013, 03:51 PM
whiskykid is online now
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
actually should go to some sort of pump, then to a tank, I am 99.9% shure it's a smoke line, and secound pic is of a 1 way check valve!
whiskykid is online now Find More Posts by whiskykid
Old Jan 08, 2013, 03:52 PM
AMA 537620
Joined Oct 2008
Ahh yes, that's true, it does need some method of actually getting from the tank to the header.
Old Jan 08, 2013, 04:53 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
My apoloiges fellows as the first post did not tell me it was a gasoline engine.
You are sure correct about a smoke system.
Zor
Old Jan 08, 2013, 06:27 PM
AMA 537620
Joined Oct 2008
No offense intended here Zor, but he said it had a 50cc in the other thread that you replied to about pinning firewalls.
Old Jan 09, 2013, 08:56 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
No worries, Zor. I should have specified.
The mystery, such as it is, has been solved buy a gentle pull on the line.
I did get a picture inside the tunnel too.
No room for smoke stuff in there - and there's no evidence that a tank or a pump was ever installed for smoke. If I had to guess I'd say the original owner installed the line to keep his options open.
Since I'm new to giant scale I'll already have my hands full - I have no intention of dealing with the added complexity and weight of a smoke system at this point.
Old Jan 09, 2013, 01:28 PM
AMA 537620
Joined Oct 2008
I was wondering if you would find that. Just make sure you cap that bung so that you don't create an exhaust leak.
Old Jan 09, 2013, 03:06 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
I think the check valve will take care of any backflow.
Old Jan 10, 2013, 08:29 AM
AMA 537620
Joined Oct 2008
Oh yeah dur, I misread your post... thought you were taking the line out for some reason.
Old Jan 10, 2013, 11:01 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
If I do remove the line I will certainly cap the bung - thanks for the tip.
Old Jan 10, 2013, 04:03 PM
FloridaFlyBob is online now
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
Must be nice to have planes so big you loose stuff in them. lol
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Sold In-line On/Off Switch Y-Connector Power Cord for 12V/24V PSU by Solid Hobby jocanon Aircraft - Electric - Batteries & Chargers (FS/W) 107 May 15, 2013 09:40 PM
Sold In-line On/Off Switch Y-Connector Power Cord for 12V/24V PSU by Solid Hobby jocanon Aircraft - Electric - Batteries & Chargers (FS/W) 4 Nov 16, 2012 01:57 AM
Discussion Thatís Racist! A guide to whatís off limits MtnGoat Life, The Universe, and Politics 52 Sep 01, 2012 09:05 PM
