Old Jan 08, 2013, 12:05 PM
DYORD is online now
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Do you need separate battery for your LED lights?!
Hi!
I run my hexcopter with 3s. My LED lights requires 12v. I only have 2 strips (around 25- 30 LEDs). I'm worrying if i will get lower flight time when i run this using the same battery pack. I know that LEDs have very low wattage.. so i'm not sure if i will notice the difference.
Need help! Thanks!
DYORD is online now Find More Posts by DYORD
Old Jan 08, 2013, 01:05 PM
sodaant is offline
Find More Posts by sodaant
United States, WA, Seattle
Joined Dec 2012
Originally Posted by DYORD View Post
Hi!
Need help! Thanks!
Even assuming they are about 0.2 W each (which is REALLY bright, probably more than 5x how bright they actually are), you'd only be using about 6W total, which likely won't make more than a 1 or 2% change in battery life.
sodaant is offline Find More Posts by sodaant
Old Jan 08, 2013, 01:15 PM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
Hi!
Need help! Thanks!
I tested mine - nearly 2m of LED ribbon. Consumed 13mA.h of charge per minute, about 5% of what the motors consume.
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Jan 08, 2013, 01:49 PM
sodaant is offline
Joined Dec 2012
If the calculations I just did in my head are right, that's around 9 watts or so of power, which would be around 4.5W per meter. Not quite sure how many they put per meter, but for my estimates to be correct, that's around one ever 4cm (which isn't really that much when I think about it). Still, how bright are those LEDs? Because a thing of LED strips that bright could almost be used as a flashlight.
Old Jan 08, 2013, 03:04 PM
kallend is offline
kallend's Avatar
Joined Sep 2004
They aren't the super bright LEDS.
I also bought 2 (1 red, 1 white) very bright LED flashers from the local bike store. They are designed to strap on to handlebars or seat pillars (thin silicone rubber straps). Very light, include switch and long life battery, mount easily to the bottom plate. Can see them from long way off.
Old Jan 08, 2013, 07:19 PM
DYORD is online now
Joined Apr 2012
Thanks.... I only have two 5" strips for the front arms. Now I'm thinking of putting some more if that won't cost me 1min. of my flight time.
Old Jan 15, 2013, 12:13 AM
In-Flight is offline
Find More Posts by In-Flight
United States, TX, Arlington
Joined Jan 2013
Anyone have details on how to wire the LED Flasher?
Ive seen notes that you have to add a resistor and a NPN transistor, but the details on what type of resistor and transistor plus the configuration of the wiring has me confused (what leads plug where).
In-Flight is offline Find More Posts by In-Flight
Old Jan 15, 2013, 08:12 AM
DYORD is online now
Joined Apr 2012
I bought 12volt led strips from a motorcycle shop nearby. As long as you use 3s (12.6v when fully charged) battery, you can solder it parallel to the battery.
Old Jan 15, 2013, 08:29 AM
Joined Jan 2013
Yeah, I that's the easy way, but I would like to be able to toggle on and off via TX. I understand the code, just not the proper connections. It's not very well documented.
Discussion Looking for Ideas! How do you keep a log of your batteries? Titus Gordon Batteries and Chargers 11 Sep 14, 2012 10:50 AM
Question How big of battery do you need for 46 glow plane? rlfgary Fuel Plane Talk 36 Apr 06, 2012 08:45 AM
Cool LED lights for your micro plane. LED and battery .8 grams Lammergier Micro Ready-to-Fly 3 Apr 01, 2011 10:16 PM
Discussion Where do you mount your Battery Warning LED ? solentlife Electric Plane Talk 5 Feb 14, 2011 01:22 PM
