Old Jan 11, 2013, 08:47 PM
Disco Stew is offline
Find More Posts by Disco Stew
I ask a lot of questions.
Canada, AB, Airdrie
Joined Aug 2012
Originally Posted by bobdaeronort View Post
I went through almost a eleven bundles (1200 sqft) last year or about 3 1/4 sqft per day which is almost half a sheet since I use at least two sheets per plane that would be a plane or project every four days which is about right. About what it would take to skin a 1200 sqft house.
It's getting much harder to find around here unless pink is your color.
That sounds like you have CDO like me...it's like OCD (But the letters are in the right order as they are suppose to be)
Disco Stew is offline Find More Posts by Disco Stew
Old Jan 11, 2013, 10:10 PM
bobdaeronort is offline
Find More Posts by bobdaeronort
"Five Easy Pieces"
United States, IN, Terre Haute
Joined Sep 2011
LOL.
I dunno bout that.
I know I don't have a full-time job or at the moment any job so this keeps me sane. Believe it or not.
bobdaeronort is offline Find More Posts by bobdaeronort
Old Jan 12, 2013, 08:23 AM
Dickeroo is online now
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
Have there been any reports of a flying saucer in your area?
Bob...
That video was terrific!
~ Dick
Dickeroo is online now Find More Posts by Dickeroo
Old Jan 12, 2013, 11:27 AM
"Five Easy Pieces"
Joined Sep 2011
Originally Posted by Dickeroo View Post
Bob...
~ Dick
Thanks.
She flies great on you wing design. The forward 40% of the disk is your airfoil. looks like a scimitar moon. The wind was 10 mph gusting over 20 and was really pushing that 40" disk around till I got her pointed into the wind and up to speed and then your wing effect took over and she flew fine.
No vid of the crash though. Minor damage to the left leading edge. All fixed now.
I reconfigured her control set-up so I have a separate and larger elevator and ailerons.
Gonna take her back up as time and weather permits.
Old Jan 12, 2013, 11:55 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Flies well... But sans Marvin it's looking more as a Nutball rather than Marvin the Martians' Saucer :-)
Bare is offline Find More Posts by Bare
Old Jan 12, 2013, 12:43 PM
"Five Easy Pieces"
Joined Sep 2011
Thanks, but, Marvin's rather shy actually.
What is a "Nutball"?
No.
Wait I found it.
LOL well it is round but my motor is just behind the KFM4 airfoil and the AC.
The Li-po is upfront and my rudderage is ventral. But other than that.....
Old Jan 13, 2013, 02:01 PM
"Five Easy Pieces"
Joined Sep 2011
I was rechecking my CoG, after reconfiguring her control set-up and adding a servo to her tail to move her elevator, and decided I'd made my X-2 to neutral originally which could have been the main reason that I had so much trouble in a 10 mph wind on the maiden. So I made some adjustments so now she's decidedly nose heavy. I took the X-2 glider and added another bolt to it's nose and she flies better too. Oh well.
So I weighed her with my spring scale and she is at 34 oz. RTF.
Old Jan 14, 2013, 10:35 AM
"Five Easy Pieces"
Joined Sep 2011
Took her back out this morning and found out right away that I had the CoG all wrong. Majorly tail heavy with the new tail mods. The elevator was way to big too. I'm going back to her original two servo elevon set-up to lighten the tail and then to refigure her CoG. I was closer on the first go than with the changes. The 18" diameter test glider proves that she flies much better nose heavy I just need to find that point.
X 2 Trials (1 min 32 sec)
Old Jan 14, 2013, 08:02 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Ooch, owch, ouchie, Now cut that out Bob...
foamdave is offline Find More Posts by foamdave
Old Jan 14, 2013, 08:56 PM
"Five Easy Pieces"
Joined Sep 2011
I know, I know. No Actually I don't know. I don't know how to find this things CoG.
I'm just guessing. Oh well, trial and error.
Old Jan 15, 2013, 12:00 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
CG at 25% on the flying disc always doing better job
just a humble suggestion
regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Jan 15, 2013, 06:29 AM
"Five Easy Pieces"
Joined Sep 2011
regards
Sam
No, That a Great suggestion.
THANK YOU Sam!!
This is my first flying disk and I think I'm behind on the curve.
I will make that adjustment.
Old Jan 15, 2013, 09:22 AM
"Five Easy Pieces"
Joined Sep 2011
SO Sam from Taiwan here on RCGroups wrote me and suggested a 1/4 of the wing centerline back from the LE to the balance point or CoG which is what he uses on his flying disks?
Well, I tried this but it was pretty severe.
SO, I checked the CoG (which I had not done) on my 1/2 scale glider disk (which has done so well especially since I added 1/3 more nose weight) and she balances perfectly at 1/3 back but not at all at 1/4 back.
Hmmmmm.
Well at least I'm making progress as I originally had the SMJv3 set just forward of the 40" diameter disk's center or about 16" from LE to the motor's center mass.
So I removed the SMJv2 and rebalanced the X-II with the motor centered on this 1/3 point about
13 1/3" on this 40" disk back from the LE and the 2250 mah Li-Po upfront, still with some wiggle room, and .....success.
She balances there with her nose down 10 degrees just like the glider does.
So now to rebuild and reconfigure the disk again.
More Later.
Oh, and Thanks again Sam.
Old Jan 15, 2013, 09:39 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Turns out there are really two CGs , one for best Glide , and one slightly forward for Flying ... Due to design/construction differences , each disk must be tested with different CGs to see what Flies best .... Most of the time the flying disk CG is ~ 25% , depending how you like to fly ...
We fly the plane first upright , then inverted to see the difference , then just adjust the Cg accordingly .. Once you find the correct CG , your disk should be as stable as a Piper Cub on Mars ...
gpw is offline Find More Posts by gpw
Old Jan 15, 2013, 12:53 PM
"Five Easy Pieces"
Joined Sep 2011
Ahhh. I see.
So in this instance I have a margin - from 10" back from the LE (25%) to 13 1/3" (30%), or about 3 " one way or the other area where the CoG lies.
Thanks.
Did not know this.
Alert OT: Flying Saucers are REAL! Kmot Dock Talk 27 Dec 08, 2014 03:59 PM
Discussion A IR flying saucer mini quadcopter not much larger then an outstretched palm goodluckbuy Multirotor Talk 5 Jul 06, 2012 11:04 AM
Discussion Newbie Q's on flying saucer coaxialnewbie Power Systems 13 Apr 27, 2012 02:44 AM
Found Flying Saucer wing881 Aircraft - Fuel - Airplanes (FS/W) 3 Apr 05, 2012 01:29 PM
Cool Hovercraft + Helicopter = Geoff's Flying Saucer tangel Micro Helis 4 Apr 11, 2007 07:22 PM
