Old Jan 24, 2013, 08:51 PM
P31 is offline
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
Originally Posted by JimClark View Post
.150 and .180 .180 is too small for you maybe even .180 you might have to go to .250
Would the 250 be 1/4 inch. I have this cable, but they dont make a coupler, 8mm motor shaft, to this size cable. I guess I could make my own.
P31 is offline Find More Posts by P31
Old Jan 24, 2013, 09:28 PM
JimClark is offline
Find More Posts by JimClark
JimClark's Avatar
United States, WA, Seattle
Joined Apr 2002
yes .250 is 1/4
Octura makes one i am not sure that the .187 might not work also
http://www.offshoreelectrics.com/pro...oct-ocfhe8mm25
JimClark is offline Find More Posts by JimClark
Old Jan 24, 2013, 10:49 PM
P31 is offline
P31
P31
Joined Dec 2011
Thank you, I'll leave you alone now.
Gary
Old Jan 27, 2013, 03:44 PM
P31 is offline
P31
P31
Joined Dec 2011
Progress on my Miss Bardhal. got her all framed up started the planking, I know that most of you do it all in one sheet, but I like this method better. It seems to work better for the big guy's. Roughed in the shaft and strut. Porp. is not the one I'm going to use, just there for setting up.
Motor and Batteries are on there way. (I just love Hobbyking's shipping, what a joke, they have a warehouse not more than 10 miles from me Sheees) I will post Pic's when I get them in.
Gary
Old Jan 28, 2013, 11:28 PM
P31 is offline
P31
P31
Joined Dec 2011
I'm getting ready to install the rudder, Should the rudder be offset or directly behind the prop. It seems to me that the intake on the rudder blade should be on the propwash side, any comments.
Gary
Old Jan 28, 2013, 11:30 PM
JimClark is offline
JimClark's Avatar
Joined Apr 2002
offset for sure for the decking are you going to shape it by sanding then fiberglass it?
Old Jan 28, 2013, 11:41 PM
P31 is offline
P31
P31
Joined Dec 2011
Yes it's a double plank haring bone in opposite directions,( you dont have to fight those sharp curves) and then light glass and Epoxy resin, I have used this on all my Chri Craft very strong. I thought the rudder would be put on that way, but thought I would ask to make sure. Thanks Jim
Just a note only the top portion is done this way, everything else is sheet ply
Old Jan 29, 2013, 12:25 AM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Looks COOL !
Great driver figure, where did you get him ?
Tim B. is offline Find More Posts by Tim B.
Old Jan 29, 2013, 12:38 AM
P31 is offline
P31
P31
Joined Dec 2011
Hey Tim are you taking a break from the saw dust.
Thats Capt Shag Nasty, he's going to pilot this monster.
I got him at a swap meet the uniform on line, helmit is not done yet
Old Jan 30, 2013, 05:10 PM
P31 is offline
P31
P31
Joined Dec 2011
I got the Motor today, very nice product. It's big and I'm sure it's going to push this baby good (not for a longtime but good) I will have to Modify the mount though, the angle is way to steep. Here's some Pic's
Gary
Old Feb 01, 2013, 02:24 AM
P31 is offline
P31
P31
Joined Dec 2011
Well It's obviouse no one realy care's what I'm putting out here, but maybe someone will see what a very large motor it takes to push a 1/8 scale thunder boat.
gary
Old Feb 06, 2013, 11:15 AM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
Looks good. Your motor is forward of where I put mine, but with the larger motor I think it might be about right. Just make sure the balance point with batteries and so forth is somewhere, maybe an inch, behind the back edge of the sponson.
I see you are going with a more modern style turn fin, but the original boats would only have a small tab along the inside of the sponson.
cyberhoops is offline Find More Posts by cyberhoops
Old Feb 06, 2013, 02:30 PM
P31 is offline
P31
P31
Joined Dec 2011
Thank you for your input, I'm kinda doing this on my own by reading what you guy's put out there. I thought that that fin was a bit too big, I'm not going to race the boat so I don't even know if I'll need one. I was also wondering about where the balance point would be, someone said about 30% but I dident get from which end, Bow or transom. I was going to put the motor a little further back but then I would have had to bend the tube. Now it's a straight shot.
Any help welcomed
gary
Old Feb 06, 2013, 03:30 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
That motor looks HOT !
Old Feb 06, 2013, 04:02 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
The motor location could work out fine, but it might be that the batteries are installed more toward the transom. I was thinking that the angle on the drive shaft was angled down a bit more than might be necessary, and maybe a bit deeper than desired.
You might check that the rear flat bottomed section of the hull is basically level to a table when the boat is sitting on the end of the strut ( with no prop) and the back (ride surfaces) of the sponsons. That might be a good starting point for the depth of the strut.
The CG does need to be behind the back of the sponson, and I would guess between 1 and 3 inches. Since the batteries are the main movable weight it is a good idea to plan for a range of motion for battery location that you can use to tweak the CG in that range.
For my skid fin, I just cut some an aluminum plate, about 3" long and 2" deep with a bit of a taper on the leading edge and then screwed that into the inside edge of the sponson. It sticks down about an inch below the ride surface. Since my 1/10th scale runs counter-clockwise, it is on the left sponson. I checked but it does not look like I ever took a picture of it when building the Hallmark Homes, but I do have a picture of the real boat where you can just make out the fin. The boats hardly had any fin at all, but even if you are not racing I think you want a little something there.
Sold AquaCraft U-18 Miss Vegas Deuce viper1216 Boats (FS/W) 1 May 24, 2014 11:59 PM
Sold T-Boat ,1967 Miss Budweiser (not finished) Dyno Don Boats (FS/W) 9 Sep 08, 2012 10:10 PM
U.S. AirCore 40 Trainer Kit .40-.50,64" AJsToyz Non R/C Items (FS/W) 1 Aug 30, 2012 12:03 PM
Sold AquaCraft U-18 Miss Vegas Deuce viper1216 Boats (FS/W) 0 Feb 24, 2012 01:15 PM
Discussion Miss Budwieser Vs Miss Vegas U 18 wpk1941 Racing Boats - Internal Combustion 3 Sep 24, 2007 01:26 AM
