Old Jan 07, 2013, 09:22 PM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Pinning the firewall - 50cc SBach
I've seen many recommendations on pinning the firewall. When I first heard about it I had no idea what was involved, and it wasn't until I got a giant scale airplane that I saw the light. I knocked this job off in about fifteen minutes (including time for photos).
Step 1 - Mark the locations for the pins
Using a ruler and eyeballing from diagonal corners of adjacent tenons, I made an X between each.
Next, I used an awl to mark the points for drilling.
grosbeak is offline Find More Posts by grosbeak
Old Jan 07, 2013, 09:27 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Step 2 - Drilling the holes
I saw a recommendation for bamboo skewers as pins - I picked up a package of 100 at a local supermarket. Before I could drill the holes I needed the diameter:
I marked the drill bit at 15mm and drilled the holes.
Old Jan 07, 2013, 09:33 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Step 3 - Prepping the pins and the holes
For the six holes I cut six pins, each about 20mm long. I cut the tip off the skewer first.
I opted for Chair Doctor glue from Lee Valley, designed to swell the wood in the joints.
I little squeeze in each hole did the trick.
Old Jan 07, 2013, 09:37 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Step 4 - Installing the pins
I used a wooden mallet to tap the pins into place.
Once they were in, out came the trusty flush cut saw.
Presently the job was done...
... with skewer to spare.
Old Jan 07, 2013, 09:43 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Summary
A fast, easy and almost free modification. The items involved are listed below; those with an accompanying price I didn't already own and had to purchase.
Parts
- Skewers ($1.99)
Tools
- Pencil
- Ruler
- Awl
- Drill
- 7/64" drill bit
- Mallet
- Flush cut saw
Supplies
- Sandpaper
- Glue
Old Jan 08, 2013, 06:27 AM
rjstrickjr is offline
Find More Posts by rjstrickjr
rjstrickjr's Avatar
United States, NC, Faison
Joined Jan 2011
Welcome to giant scale and thanks for the thread.
This should also be done even on the smaller planes. The folks at my flying club pin all their firewalls, just makes sence. A 15 minute job can save a an airplane from dropping like a rock and destroying your hard work and pride!
rjstrickjr is offline Find More Posts by rjstrickjr
Old Jan 08, 2013, 08:30 AM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
grosbeak,
Have a look in the other thread "pinning firewall" where you posted a link to this thread.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jan 08, 2013, 11:03 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Originally Posted by Zor View Post
grosbeak,
Zor
Zor, done and replied - thanks!
Old Jan 11, 2013, 01:09 AM
GeetarJoe is offline
Find More Posts by GeetarJoe
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
great writeup, and good job.
you can also use toothpicks, servo screws, bits of carbon rod, hardwood dowel, etc. whatever strikes your fancy. i use toothpicks. i just drill a 1/16 hole, dip the toothpick in gorilla glue, and then shove it in. let the glue cure and cut them off. same thing for the hardwood dowel. for the carbon rod, rough it up and then use epoxy. for servo screws, you can drill a 1/16 hole, dip the screw in titebond, and then screw that puppy in.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Jan 11, 2013, 05:32 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
One mountain, many paths. Thanks Joe!
Build Log 50cc Sbach 342 scratch build roger2525 Giant Scale Airplanes 34 Aug 17, 2014 08:09 PM
Question Pull Pull System for SDS Hobby 50cc Sbach paphman Giant Electric Planes 7 May 08, 2012 03:53 AM
Sold PRICE REDUCED SBach 50cc no RX or TX w/DLE 55 edge_pilot Aircraft - Fuel - Airplanes (FS/W) 1 Jun 22, 2011 08:47 AM
Discussion Gold Wing RC SBACH-342 50CC Yardbee Giant Electric Planes 47 May 03, 2011 07:06 PM
Sold Pilot Sbach 342 50cc 87" oregonrc Aircraft - Fuel - Airplanes (FS/W) 3 Nov 03, 2010 10:17 AM
